[mapserver-commits] r8364 - trunk/docs/mapscript/php
svn at osgeo.org
svn at osgeo.org
Wed Dec 31 10:28:03 EST 2008
Author: tomkralidis
Date: 2008-12-31 10:28:03 -0500 (Wed, 31 Dec 2008)
New Revision: 8364
trunk/docs/mapscript/php/by_example.txt
remove link to old site
Modified: trunk/docs/mapscript/php/by_example.txt
--- trunk/docs/mapscript/php/by_example.txt 2008-12-31 15:25:37 UTC (rev 8363)
+++ trunk/docs/mapscript/php/by_example.txt 2008-12-31 15:28:03 UTC (rev 8364)
@@ -100,7 +100,7 @@
language without MapScript, plus access to almost all of the MapServer C API, the
level of completeness of MapServer API support varies a bit with the language you
choose, but I think it is my duty to tell you almost every available flavor of
-MapScript is usable. This `API`_, exposed now in your scripting language through the
+MapScript is usable. This API, exposed now in your scripting language through the
MapScript module, allows you to do many GIS-like operations on spatial data,
including read-write access to shapefiles, reprojection of data, and many others.
For more information on the API, click over the link above. For other flavors,
@@ -554,10 +554,9 @@
.. _`HTML`: http://www.w3.org/MarkUp/
.. _`shapefile`: http://shapelib.maptools.org/
.. _`PostGIS`: http://postgis.refractions.net/
-.. _`API`: http://ms.gis.umn.edu/docs/reference/phpmapscript-class
.. _`list archives`: http://lists.osgeo.org/pipermail/mapserver-users/
.. _`mapserver-dev list`: http://lists.osgeo.org/mailman/listinfo/mapserver-dev/
.. _`GMap demo`: http://www.mapsherpa.com/gmap/
.. _`here`: http://dl.maptools.org/dl/
.. _`MS4W packaged application`: http://www.maptools.org/ms4w/index.phtml?page=downloads.html
-.. _`MapTools site`: http://www.maptools.org/
\ No newline at end of file
+.. _`MapTools site`: http://www.maptools.org/
More information about the mapserver-commits
