[mapserver-commits] r8368 - trunk/docs/installation
Wed Dec 31 12:58:43 EST 2008
Author: jmckenna
Date: 2008-12-31 12:58:42 -0500 (Wed, 31 Dec 2008)
New Revision: 8368
   trunk/docs/installation/php.txt
add more internal referencing, and add readable labels for the references
Modified: trunk/docs/installation/php.txt
--- trunk/docs/installation/php.txt	2008-12-31 16:41:30 UTC (rev 8367)
+++ trunk/docs/installation/php.txt	2008-12-31 17:58:42 UTC (rev 8368)
@@ -6,7 +6,8 @@
 :Author: Jeff McKenna
 :Contact: jmckenna at gatewaygeomatics.com
-:Last Updated: 2007/09/11
+:Revision: $Revision$
+:Date: $Date$
 .. contents:: Table of Contents
     :depth: 2
@@ -26,7 +27,8 @@
 support the PHP language, the module has to be maintained separately and may
 not always be in sync with the Perl version.
-The PHP module was developed and is currently maintained by `DM Solutions Group`_.
+The PHP module was developed by `DM Solutions Group`_ and is currently
+maintained by `Mapgears`_.
 This document assumes that you are already familiar with certain aspects of
 your operating system:
@@ -54,13 +56,13 @@
 - For a list of all classes, properties, and methods available in the module
-  see the :ref:`php`.
+  see the :ref:`php` reference document.
 - More information on the PHP/MapScript module can be found on the
   `PHP/MapScript page`_ on MapTools.org.
-- The old `MapServer Wiki`_ also has PHP/MapScript build and installation notes
-  and some php code snippets.
+.. - The old `MapServer Wiki`_ also has PHP/MapScript build and installation notes
+   and some php code snippets.
 - Questions regarding the module should be forwarded to the :ref:`MapServer mailing list <lists>`.
@@ -107,8 +109,8 @@
     When setting up PHP on Windows, make sure that PHP is configured as a CGI and not
     as an Apache module because php_mapscript.dll is not thread-safe and does not work
-    as an Apache module (See the `Example Steps of a Full Windows Installation section`_
-    of this document).
+    as an Apache module (See the :ref:`Example Steps of a Full Windows Installation
+    <php_install_example_steps>` section of this document).
 Build/Install the PHP/MapScript Module
@@ -116,7 +118,8 @@
 **Building on a Linux Box**
-NOTE: For UNIX users, see the README.CONFIGURE file in the MapServer source, or see the :ref:`unix`.
+NOTE: For UNIX users, see the README.CONFIGURE file in the MapServer source, or
+see the :ref:`unix` HowTo.
 - The main MapServer configure script will automatically setup the main makefile
   to compile php_mapscript.so if you pass the *--with-php=DIR* argument to the configure script.
@@ -140,7 +143,7 @@
 **Building on Windows**
 - For Windows users, it is recommended to look for a precompiled binary for your
-  PHP version on the `MapServer download page`_ or on `MapTools.org`_.
+  PHP version on the :ref:`MapServer download page <download>` or on `MapTools.org`_.
 - If for some reason you really need to compile your own Windows binary then see the
   README.WIN32 file in the MapServer source (good luck!).
@@ -182,6 +185,8 @@
 displayed on your page, and 'MapScript' should be listed in the 'Extensions'
 table.
+.. _php_install_example_steps:
@@ -209,7 +214,8 @@
 2. Download `PHP4`_ and extract it to your Apache folder (eg. D:/Apache/PHP4).
 3. Create a temp directory to store MapServer created GIFs. NOTE: This directory
-   is specified in the IMAGEPATH parameter of the WEB Object in the :ref:`mapfile`.
+   is specified in the IMAGEPATH parameter of the WEB Object in the :ref:`mapfile`
+   reference.
    For this example we will call the temp directory "ms_tmp" (eg. E:/tmp/ms_tmp).
 4. Locate the file *httpd.conf* in the conf directory of Apache, and open it
@@ -252,7 +258,7 @@
 **Installation Using Microsoft's IIS**
-(please see the `MapServer IIS Setup howto`_ for uptodate steps)
+(please see the :ref:`iis` document for uptodate steps)
 1. Install IIS if required (see the `IIS 4.0 installation procedure`_).
@@ -304,16 +310,16 @@
 :Q: **Is there any documentation available?**
-:A: The main reference document is the :ref:`php`,
+:A: The main reference document is the :ref:`PHP MapScript reference <php>`,
     which describes all of the current classes, properties and methods
     associated with the PHP/MapScript module.
     To get a more complete description of each class and the meaning of
-    their member variables, see the :ref:`mapscript`
-    and the :ref:`mapfile`.
+    their member variables, see the :ref:`MapScript reference <mapscript>`
+    and the :ref:`MapFile reference <mapfile>`.
-    The `MapServer Wiki`_ also has PHP/MapScript build and installation
-    notes and some php code snippets.
+    .. The `MapServer Wiki`_ also has PHP/MapScript build and installation
+       notes and some php code snippets.
@@ -324,7 +330,7 @@
     *test_draw_map.phtml*: it's a very simple script that just draws a map,
     legend and scalebar in an HTML page.
-    A good intermediate example is the :ref:`php_example`
+    A good intermediate example is the :ref:`PHP MapScript By Example guide <php_example>`
     (note that this document was created for an earlier MapServer version
     but the code might be still useful).
@@ -368,8 +374,8 @@
        AddType application/x-httpd-php .phtml
-    For a more detailed explanation, see the `Example Steps of a Full Windows Installation section`_
-    section of this document.
+    For a more detailed explanation, see the :ref:`Example Steps of a Full Windows
+    Installation <php_install_example_steps>` section of this document.
@@ -447,24 +453,21 @@
 .. _`SWIG`: http://www.swig.org/
 .. _`DM Solutions Group`: http://www.dmsolutions.ca/
+.. _`Mapgears`: http://www.mapgears.com
 .. _`PHP/MapScript page`: http://www.maptools.org/php_mapscript/
 .. _`MapServer Wiki`: http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScript
-.. _`MapServer mailing list`: http://mapserver.gis.umn.edu/community/mailinglists/
 .. _`PHP web site`: http://www.php.net/
 .. _`Installation on Unix systems`: http://php.net/manual/en/install.unix.php
 .. _`MS4W (MapServer For Windows)`: http://www.maptools.org/ms4w/
 .. _`Installing Apache, PHP and MySQL on Windows tutorial`: http://www.php-mysql-tutorial.com/install-apache-php-mysql.php
 .. _`php.net's howto`: http://www.php.net/manual/en/install.iis.php
-.. _`Example Steps of a Full Windows Installation section`: http://mapserver.gis.umn.edu/docs/howto/phpmapscript-install/#example-steps-of-a-full-windows-installation
 .. _`extension_loaded()`: http://www.php.net/manual/en/function.extension-loaded.php
-.. _`MapServer download page`: http://mapserver.gis.umn.edu/download/current/windows/
 .. _`MapTools.org`: http://www.maptools.org/php_mapscript/index.phtml?page=downloads.html
 .. _`MS4W base package`: http://www.maptools.org/ms4w/index.phtml?page=downloads.html
 .. _`MS4W download page`: http://www.maptools.org/ms4w/index.phtml?page=downloads.html
 .. _`Apache Web Server`: http://httpd.apache.org/
 .. _`PHP4`: http://www.php.net/
 .. _`IIS 4.0 installation procedure`: http://support.microsoft.com/support/iis/install/install_iis4.asp
-.. _`MapServer IIS Setup howto`: http://mapserver.gis.umn.edu/docs/howto/setupiis
 .. _`MapTools.org download page`: http://www.maptools.org/dl/
 .. _`GMap demo`: http://www.mapsherpa.com/gmap/
 .. _`PHP/MapScript CGI page`: http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptCGI
