[mapserver-commits] r8370 - trunk/docs/output
Wed Dec 31 15:32:02 EST 2008
Author: tomkralidis
Date: 2008-12-31 15:32:02 -0500 (Wed, 31 Dec 2008)
New Revision: 8370
   trunk/docs/output/flash.txt
   trunk/docs/output/imagemaps.txt
use internal referencing
Modified: trunk/docs/output/flash.txt
--- trunk/docs/output/flash.txt	2008-12-31 20:21:15 UTC (rev 8369)
+++ trunk/docs/output/flash.txt	2008-12-31 20:32:02 UTC (rev 8370)
@@ -99,7 +99,7 @@
 How to Output SWF Files from MapServer
-SWF output is specified by using the OUTPUTFORMAT object in the `mapfile`_.
+SWF output is specified by using the :ref:`OUTPUTFORMAT <outputformat>` object.
 There are 2 possible output types:
 1. A single movie containing the raster output for all the layers. To enable this,
@@ -357,6 +357,5 @@
 .. _`MS4W`: http://www.maptools.org/ms4w/
 .. _`Ming library`: http://www.libming.org/
 .. _`here`: http://www2.dmsolutions.ca/mapserver/dl/ming-0.2a.zip
-.. _`mapfile`: http://mapserver.gis.umn.edu/docs/reference/mapfile/outputformat
 .. _`Produce FDB files`: http://www.opaque.net/wiki/index.php?MingFAQ
 .. _`ticket`: http://trac.osgeo.org/mapserver/
Modified: trunk/docs/output/imagemaps.txt
--- trunk/docs/output/imagemaps.txt	2008-12-31 20:21:15 UTC (rev 8369)
+++ trunk/docs/output/imagemaps.txt	2008-12-31 20:32:02 UTC (rev 8370)
@@ -128,7 +128,7 @@
 You also see shpxy template formatting options 'xf' and 'yf'.  'xf=","
 tells MapServer to place a comma after the x coordinate.  'yf=",7" after
 the y coordinate.  This is done to specify a radius of 7 pixels for the
-circle.  More options can be found in the `MapServer Template Reference`_ .
+circle.  More options can be found in the :ref:`Template Reference <template>`.
 The query footer template simply adds the closing tag for the html imagemap
@@ -175,6 +175,4 @@
 .. #### rST Link Section ####
-.. _`MapServer Template Reference`: http://mapserver.gis.umn.edu/docs/reference/templatereference/templatereference#query
 .. _`Steve Lime's SHPXY Example`: http://maps.dnr.state.mn.us/cgi-bin/mapserv48?map=/usr/local/www/docs_maps/eco/rsg/search/search_example.map&qlayer=county&mode=nquery&searchmap=true
