[mapserver-commits] r7360 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Feb 6 22:03:34 EST 2008
Author: tomkralidis
Date: 2008-02-06 22:03:34 -0500 (Wed, 06 Feb 2008)
New Revision: 7360
trunk/mapserver/mapserver.h
trunk/mapserver/mapstring.c
add utility function for testing strings as ints (#2384)
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2008-02-06 19:46:37 UTC (rev 7359)
+++ trunk/mapserver/mapserver.h 2008-02-07 03:03:34 UTC (rev 7360)
@@ -1620,6 +1620,7 @@
MS_DLL_EXPORT int msGetNextGlyph(const char **in_ptr, char *out_string);
MS_DLL_EXPORT int msGetNumGlyphs(const char *in_ptr);
MS_DLL_EXPORT int msGetUnicodeEntity(const char *inptr, int *unicode);
+MS_DLL_EXPORT int msStringIsInteger(const char *string);
MS_DLL_EXPORT int msUTF8ToUniChar(const char *str, int *chPtr); /* maptclutf.c */
#ifdef NEED_STRDUP
Modified: trunk/mapserver/mapstring.c
--- trunk/mapserver/mapstring.c 2008-02-06 19:46:37 UTC (rev 7359)
+++ trunk/mapserver/mapstring.c 2008-02-07 03:03:34 UTC (rev 7360)
@@ -1429,3 +1429,30 @@
return 0;
+ * msStringIsInteger()
+ * determines whether a given string is an integer
+ * @param string the string to be tested
+ * @return MS_SUCCESS or MS_FAILURE
+int msStringIsInteger(const char *string) {
+ int length, i;
+ length = strlen(string);
+ if (length == 0)
+ return MS_FAILURE;
+ for(i=0;i<length;i++) {
+ if (!isdigit(string[i]))
+ return MS_SUCCESS;
More information about the mapserver-commits
