[mapserver-commits] r7379 - trunk/mapserver
Wed Feb 13 12:16:39 EST 2008
Author: tomkralidis
Date: 2008-02-13 12:16:39 -0500 (Wed, 13 Feb 2008)
New Revision: 7379
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapwcs.c
support COVERAGE lists for DescribeCoverage (#2508)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-02-13 01:48:39 UTC (rev 7378)
+++ trunk/mapserver/HISTORY.TXT	2008-02-13 17:16:39 UTC (rev 7379)
@@ -13,6 +13,8 @@
 Current Version (5.1-dev, SVN trunk):
+- mapwcs.c: support COVERAGE lists for DescribeCoverage (#2508)
 - mapwcs.c: fix lonLatEnvelope/@srsName (#2507)
 - mapwcs.c: omit VendorSpecificCapabilities (#2506)
Modified: trunk/mapserver/mapwcs.c
--- trunk/mapserver/mapwcs.c	2008-02-13 01:48:39 UTC (rev 7378)
+++ trunk/mapserver/mapwcs.c	2008-02-13 17:16:39 UTC (rev 7379)
@@ -1090,8 +1090,10 @@
 static int msWCSDescribeCoverage(mapObj *map, wcsParamsObj *params)
-  int i,j;
+  int i = 0,j = 0, k = 0;
   const char *updatesequence=NULL;
+  char **coverages=NULL;
+  int numcoverages=0;
 /*      1.1.x is sufficiently different we have a whole case for        */
@@ -1105,19 +1107,21 @@
   if(params->coverages) { /* use the list */
-    for( j = 0; params->coverages[j]; j++ ) {
-      i = msGetLayerIndex(map, params->coverages[j]);
-      if(i == -1) {
-        msSetError( MS_WCSERR,
-                "COVERAGE %s cannot be opened / does not exist",
-                "msWCSDescribeCoverage()", params->coverages[j]);
-        return msWCSException(map, "CoverageNotDefined", "coverage",
+      for( j = 0; params->coverages[j]; j++ ) {
+          coverages = msStringSplit(params->coverages[j], ',', &numcoverages);
+          for(k=0;k<numcoverages;k++) {
+              i = msGetLayerIndex(map, coverages[k]);
+              if(i == -1) { // one coverage
+                  msSetError( MS_WCSERR,
+                      "COVERAGE %s cannot be opened / does not exist",
+                      "msWCSDescribeCoverage()", coverages[k]);
+                       return msWCSException(map, "CoverageNotDefined", "coverage",
                               params->version );
   updatesequence = msOWSLookupMetadata(&(map->web.metadata), "CO", "updatesequence");
   if (!updatesequence)
     updatesequence = strdup("0");
@@ -1137,17 +1141,21 @@
          "   xmlns:gml=\"http://www.opengis.net/gml\" \n"
          "   xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\"\n"
          "   xsi:schemaLocation=\"http://www.opengis.net/wcs %s/wcs/%s/describeCoverage.xsd\">\n", params->version, updatesequence, msOWSGetSchemasLocation(map), params->version);
-      msWCSDescribeCoverage_CoverageOffering((GET_LAYER(map, i)), params);
+        msWCSDescribeCoverage_CoverageOffering((GET_LAYER(map, i)), params);
   } else { /* return all layers */
     for(i=0; i<map->numlayers; i++)
   /* done */
   msIO_printf("</CoverageDescription>\n");
