[mapserver-commits] r7393 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Feb 18 17:17:01 EST 2008
Author: tomkralidis
Date: 2008-02-18 17:17:01 -0500 (Mon, 18 Feb 2008)
New Revision: 7393
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapogcsos.c
- handle invalid XML POST requests (#2521)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2008-02-18 17:03:02 UTC (rev 7392)
+++ trunk/mapserver/HISTORY.TXT 2008-02-18 22:17:01 UTC (rev 7393)
@@ -13,6 +13,8 @@
Current Version (5.1-dev, SVN trunk):
+- mapogcsos.c: handle invalid POST requests (#2521)
- mapogcsos.c: handle ACCEPTVERSIONS parameter (#2515)
- mapwcs.c/mapwcs11.c: s/neighbour/neighbor/g (#2518)
Modified: trunk/mapserver/mapogcsos.c
--- trunk/mapserver/mapogcsos.c 2008-02-18 17:03:02 UTC (rev 7392)
+++ trunk/mapserver/mapogcsos.c 2008-02-18 22:17:01 UTC (rev 7393)
@@ -62,7 +62,7 @@
xmlNodePtr psResultNode;
} SOSProcedureNode;
-void msSOSParseRequest(cgiRequestObj *request, sosParamsObj *sosparams);
+int msSOSParseRequest(mapObj *map, cgiRequestObj *request, sosParamsObj *sosparams);
void msSOSFreeParamsObj(sosParamsObj *sosparams);
@@ -2530,7 +2530,8 @@
int returnvalue = MS_DONE;
sosParamsObj *paramsObj = (sosParamsObj *)calloc(1, sizeof(sosParamsObj));
- msSOSParseRequest(req, paramsObj);
+ if (msSOSParseRequest(map, req, paramsObj) == MS_FAILURE)
+ return MS_FAILURE;
/* SERVICE must be specified and be SOS */
if (paramsObj->pszService && strcasecmp(paramsObj->pszService, "SOS") == 0) { /* this is an SOS request */
@@ -2597,7 +2598,7 @@
#if defined(USE_SOS_SVR) && defined(USE_LIBXML2)
-void msSOSParseRequest(cgiRequestObj *request, sosParamsObj *sosparams) {
+int msSOSParseRequest(mapObj *map, cgiRequestObj *request, sosParamsObj *sosparams) {
int i;
xmlDocPtr doc;
xmlXPathContextPtr context;
@@ -2649,18 +2650,21 @@
/* load document */
doc = xmlParseDoc((xmlChar *)request->postrequest);
if (doc == NULL ) {
- return;
+ msSetError(MS_SOSERR, "Invalid POST request. XML is not well-formed", "msSOSParseRequest()");
+ return msSOSException(map, "request", "NoApplicableCode");
/* load context */
context = xmlXPathNewContext(doc);
if (context == NULL) {
- return;
+ msSetError(MS_SOSERR, "Could not create context (xmlXPathNewContext)", "msSOSParseRequest()");
/* register namespaces */
if(xmlXPathRegisterNs(context, (xmlChar *)"sos", (xmlChar *)"http://www.opengis.net/sos/1.0") != 0 || xmlXPathRegisterNs(context, (xmlChar *)"ows", (xmlChar *)"http://www.opengis.net/ows/1.1") != 0) {
- return;
+ msSetError(MS_SOSERR, "Could not register namespaces (xmlXPathRegisterNs)", "msSOSParseRequest()");
/* check for service */
@@ -2795,7 +2799,7 @@
xmlFreeDoc(doc);
xmlCleanupParser();
- return;
+ return MS_SUCCESS;
void msSOSFreeParamsObj(sosParamsObj *sosparams) {
More information about the mapserver-commits
