[mapserver-commits] r7416 - in trunk/msautotest/wxs: . expected
svn at osgeo.org
svn at osgeo.org
Wed Feb 27 15:57:58 EST 2008
Author: tomkralidis
Date: 2008-02-27 15:57:58 -0500 (Wed, 27 Feb 2008)
New Revision: 7416
trunk/msautotest/wxs/expected/sos_se7.xml
trunk/msautotest/wxs/sos.map
s/sensorid/procedure/g for DescribeSensor (#2467)
Modified: trunk/msautotest/wxs/expected/sos_se7.xml
--- trunk/msautotest/wxs/expected/sos_se7.xml 2008-02-27 20:56:54 UTC (rev 7415)
+++ trunk/msautotest/wxs/expected/sos_se7.xml 2008-02-27 20:57:58 UTC (rev 7416)
@@ -2,7 +2,7 @@
<?xml version="1.0" encoding="ISO-8859-1"?>
<ows:ExceptionReport xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ows="http://www.opengis.net/ows/1.1" version="1.0.0" xml:lang="en-US" xsi:schemaLocation="http://www.opengis.net/ows/1.1 http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd">
- <ows:Exception exceptionCode="InvalidParameterValue" locator="sensorid">
- <ows:ExceptionText>msSOSDescribeSensor(): SOS server error. sensorid 20147 not found.</ows:ExceptionText>
+ <ows:Exception exceptionCode="InvalidParameterValue" locator="procedure">
+ <ows:ExceptionText>msSOSDescribeSensor(): SOS server error. procedure 20147 not found.</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Modified: trunk/msautotest/wxs/sos.map
--- trunk/msautotest/wxs/sos.map 2008-02-27 20:56:54 UTC (rev 7415)
+++ trunk/msautotest/wxs/sos.map 2008-02-27 20:57:58 UTC (rev 7416)
@@ -37,13 +37,13 @@
# RUN_PARMS: sos_se3.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&service=SOS&version=1.1.0&request=DescribeSensor" > [RESULT]
# RUN_PARMS: sos_se4.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&service=SOS&version=1.0.0&request=DescribeSensor" > [RESULT]
-# RUN_PARMS: sos_se5.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&service=SOS&version=1.0.0&request=DescribeSensor&sensorid=2147" > [RESULT]
-# RUN_PARMS: sos_se6.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&service=SOS&version=1.0.0&request=DescribeSensor&sensorid=2147&outputFormat=XML" > [RESULT]
-# RUN_PARMS: sos_se7.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&service=SOS&version=1.0.0&request=DescribeSensor&sensorid=20147&outputFormat=text/xml; subtype=sensorML/1.0.0" > [RESULT]
+# RUN_PARMS: sos_se5.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&service=SOS&version=1.0.0&request=DescribeSensor&procedure=2147" > [RESULT]
+# RUN_PARMS: sos_se6.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&service=SOS&version=1.0.0&request=DescribeSensor&procedure=2147&outputFormat=XML" > [RESULT]
+# RUN_PARMS: sos_se7.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&service=SOS&version=1.0.0&request=DescribeSensor&procedure=20147&outputFormat=text/xml; subtype=sensorML/1.0.0" > [RESULT]
# Valid
-# RUN_PARMS: sos_describe.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&service=SOS&version=1.0.0&request=DescribeSensor&sensorId=35&outputFormat=text/xml; subtype=sensorML/1.0.0" > [RESULT]
+# RUN_PARMS: sos_describe.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&service=SOS&version=1.0.0&request=DescribeSensor&procedure=35&outputFormat=text/xml; subtype=sensorML/1.0.0" > [RESULT]
# GetObservation
More information about the mapserver-commits
