[mapserver-commits] r7280 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Jan 18 09:09:11 EST 2008
Author: tomkralidis
Date: 2008-01-18 09:09:11 -0500 (Fri, 18 Jan 2008)
New Revision: 7280
trunk/mapserver/mapogcsos.c
- more SOS 1.0.0 compliance fixes (#2246)
- OM namespaces
- XML validity
Modified: trunk/mapserver/mapogcsos.c
--- trunk/mapserver/mapogcsos.c 2008-01-18 01:24:28 UTC (rev 7279)
+++ trunk/mapserver/mapogcsos.c 2008-01-18 14:09:11 UTC (rev 7280)
@@ -52,7 +52,7 @@
const char *pszSOSVersion = "1.0.0";
const char *pszSOSNamespaceUri = "http://www.opengis.net/sos/1.0";
const char *pszSOSNamespacePrefix = "sos";
-const char *pszOMNamespaceUri = "http://www.opengis.net/om/0.0";
+const char *pszOMNamespaceUri = "http://www.opengis.net/om/1.0";
const char *pszOMNamespacePrefix = "om";
const char *pszSOSDescribeSensorMimeType = "text/xml; subtype=sensorML/1.0.0";
const char *pszSOSGetObservationMimeType = "text/xml; subtype=om/1.0.0";
@@ -322,7 +322,7 @@
pszValue = msOWSLookupMetadata(&(lp->metadata), "S",
"observedProperty_id");
if (pszValue)/*should always be true */
- xmlNewNsProp(psNode, psNsGml,
+ xmlNewNsProp(psCompNode, psNsGml,
BAD_CAST "id", BAD_CAST pszValue);
@@ -332,7 +332,7 @@
BAD_CAST "name", BAD_CAST pszValue);
/* add componenets */
- /* Componenets are exposed
+ /* Components are exposed
using the metadata sos_%s_componenturl "url value" where
the %s is the name of the attribute. */
@@ -354,10 +354,10 @@
else
xmlNewNsProp(psNode, NULL, BAD_CAST "name", BAD_CAST lp->items[i]);
- //xmlNewNsProp(psNode, xmlNewNs(NULL, BAD_CAST "http://www.w3.org/1999/xlink", BAD_CAST "xlink"), BAD_CAST "href", BAD_CAST pszValue);
xmlNewNsProp(psNode, psNsXLink, BAD_CAST "href", BAD_CAST pszValue);
+ xmlNewNsProp(psCompNode, NULL, BAD_CAST "dimension", BAD_CAST msIntToString(i));
@@ -1205,7 +1205,7 @@
/* name spaces */
xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST "http://www.opengis.net/gml", BAD_CAST "gml"));
- xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST "http://www.opengis.net/om", BAD_CAST "om"));
+ xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST "http://www.opengis.net/om/1.0", BAD_CAST "om"));
psNsOws = xmlNewNs(psRootNode, BAD_CAST "http://www.opengis.net/ows/1.1", BAD_CAST "ows");
xmlSetNs(psRootNode, psNsOws );
@@ -1222,6 +1222,8 @@
/*version fixed for now*/
xmlNewProp(psRootNode, BAD_CAST "version", BAD_CAST pszSOSVersion);
+ //xmlNewProp(psRootNode, BAD_CAST "updateSequence", BAD_CAST "1234567890");
/*schema fixed*/
schemalocation = msEncodeHTMLEntities( msOWSGetSchemasLocation(map) );
xsi_schemaLocation = strdup(pszSOSNamespaceUri);
@@ -1352,8 +1354,13 @@
/* srsName */
- psNode = xmlNewChild(psOfferingNode, psNsGml, BAD_CAST "srsName", BAD_CAST "EPSG:4326");
+ value = msOWSGetEPSGProj(&(lp->projection), &(lp->metadata), "SO", MS_TRUE);
+ if (value)
+ psNode = xmlNewChild(psOfferingNode, psNsGml, BAD_CAST "srsName", BAD_CAST value);
+ else
+ xmlAddSibling(psNode, xmlNewComment(BAD_CAST "WARNING: Optional metadata \"sos_srs\" missing for gml:srsName"));
/*bounding box */
/*TODO : if sos_offering_extent does not exist compute extents
Check also what happen if epsg not present */
@@ -1577,50 +1584,8 @@
free(papszProperties[j]);
free(papszProperties);
- /*TODO <sos:featureOfInterest> : we will use the offering_extent that was used
- for the bbox. I Think we should generate a gml:FeatureCollection which
- gathers the extents on each layer associate with the offering : something like :
- <sos:featureOfInterest>
- <gml:FeatureCollection>
- <gml:featureMember xlink:href="foi_ahlen">
- <om:Station xsi:type="om:StationType">
- <om:position>
- <gml:Point srsName="EPSG:31467">
- <gml:coordinates>342539 573506</gml:coordinates>
- </gml:Point>
- </om:position>
- <om:procedureHosted xlink:href="urn:ogc:def:procedure:ifgi-sensor-1b"/>
- </om:Station>
- </gml:featureMember>
- <gml:featureMember xlink:href="foi_ahlen_2">
- </gml:FeatureCollection>
- </sos:featureOfInterest> */
- value = msOWSLookupMetadata(&(lp->metadata), "S", "offering_extent");
- if (value)
- char **tokens;
- int n;
- tokens = msStringSplit(value, ',', &n);
- if (tokens==NULL || n != 4) {
- msSetError(MS_SOSERR, "Wrong number of arguments for offering_extent.",
- "msSOSGetCapabilities()");
- return msSOSException(map, "offering_extent", "InvalidParameterValue");
- value = msOWSGetEPSGProj(&(lp->projection),
- &(lp->metadata), "SO", MS_TRUE);
- if (value)
- psNode = xmlNewChild(psOfferingNode, NULL, BAD_CAST "featureOfInterest",
- NULL);
- psTmpNode = xmlAddChild(psNode, msGML3BoundedBy(psNsGml, atof(tokens[0]), atof(tokens[1]), atof(tokens[2]), atof(tokens[3]), value));
- msFreeCharArray(tokens, n);
+ psNode = xmlNewChild(psOfferingNode, NULL, BAD_CAST "featureOfInterest", NULL);
+ xmlNewNsProp(psNode, psNsXLink, BAD_CAST "href", BAD_CAST "urn:ogc:def:feature:OGC-SWE:3:transient");
psNode = xmlNewChild(psOfferingNode, NULL, BAD_CAST "responseFormat",
BAD_CAST pszSOSGetObservationMimeType);
@@ -2143,14 +2108,14 @@
xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_PREFIX));
xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_W3C_XSI_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_W3C_XSI_NAMESPACE_PREFIX));
xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST pszSOSNamespaceUri, BAD_CAST pszSOSNamespacePrefix));
xmlNewNsProp(psRootNode, psNsGml, BAD_CAST "id", BAD_CAST sosparams->pszOffering);
/*schema fixed*/
schemalocation = msEncodeHTMLEntities(msOWSGetSchemasLocation(map));
/*TODO : review this*/
- xsi_schemaLocation = strdup("http://www.opengis.net/om ");
+ xsi_schemaLocation = strdup("http://www.opengis.net/om/1.0 ");
xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, schemalocation);
xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, "/om/1.0.0/om.xsd");
xmlNewNsProp(psRootNode, NULL, BAD_CAST "xsi:schemaLocation", BAD_CAST xsi_schemaLocation);
More information about the mapserver-commits
