[mapserver-commits] r7310 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Jan 25 07:32:31 EST 2008
Author: tomkralidis
Date: 2008-01-25 07:32:31 -0500 (Fri, 25 Jan 2008)
New Revision: 7310
trunk/mapserver/mapogcsos.c
more fixes for SOS 1.0.0 support (#2246)
Modified: trunk/mapserver/mapogcsos.c
--- trunk/mapserver/mapogcsos.c 2008-01-24 14:11:10 UTC (rev 7309)
+++ trunk/mapserver/mapogcsos.c 2008-01-25 12:32:31 UTC (rev 7310)
@@ -312,7 +312,7 @@
const char *pszValue = NULL, *pszFullName = NULL;
xmlNodePtr psCompNode, psNode;
- int i;
+ int i, j=0;
char szTmp[256];
if (psParent && lp)
@@ -349,15 +349,16 @@
/* check if there is an alias/full name used*/
sprintf(szTmp, "%s_alias", lp->items[i]);
pszFullName = msOWSLookupMetadata(&(lp->metadata), "S", szTmp);
- if (pszFullName)
- xmlNewNsProp(psNode, NULL, BAD_CAST "name", BAD_CAST pszFullName);
- else
- xmlNewNsProp(psNode, NULL, BAD_CAST "name", BAD_CAST lp->items[i]);
+ //if (pszFullName)
+ // xmlNewNsProp(psNode, NULL, BAD_CAST "name", BAD_CAST pszFullName);
+ //else
+ // xmlNewNsProp(psNode, NULL, BAD_CAST "name", BAD_CAST lp->items[i]);
xmlNewNsProp(psNode, psNsXLink, BAD_CAST "href", BAD_CAST pszValue);
+ j++;
- xmlNewNsProp(psCompNode, NULL, BAD_CAST "dimension", BAD_CAST msIntToString(i));
+ xmlNewNsProp(psCompNode, NULL, BAD_CAST "dimension", BAD_CAST msIntToString(j));
@@ -1052,7 +1053,6 @@
else
msSOSAddPropertyNode(psNsSwe, psNsXLink, psObsNode, lpfirst, psNsGml);
/* result definition*/
psNode = xmlNewChild(psObsNode, NULL, BAD_CAST "resultDefinition", NULL);
msSOSAddDataBlockDefinition(psNsSwe, psNode, lpfirst);
@@ -2155,27 +2155,27 @@
/* time */
- pszTmp = msOWSLookupMetadata(&(lp->metadata), "S","offering_timeextent");
- if (pszTmp)
- char **tokens;
- int n;
- char *pszEndTime = NULL;
- tokens = msStringSplit(pszTmp, '/', &n);
- if (tokens==NULL || (n != 1 && n!=2)) {
- msSetError(MS_SOSERR, "Wrong number of arguments for offering_timeextent.",
- "msSOSGetCapabilities()");
- return msSOSException(map, "offering_timeextent", "InvalidParameterValue");
- if (n == 2) /* end time is empty. It is going to be set as "now*/
- pszEndTime = tokens[1];
+ //pszTmp = msOWSLookupMetadata(&(lp->metadata), "S","offering_timeextent");
+ //if (pszTmp)
+ // char **tokens;
+ // int n;
+ // char *pszEndTime = NULL;
+ // tokens = msStringSplit(pszTmp, '/', &n);
+ // if (tokens==NULL || (n != 1 && n!=2)) {
+ // msSetError(MS_SOSERR, "Wrong number of arguments for offering_timeextent.",
+ // "msSOSGetCapabilities()");
+ // return msSOSException(map, "offering_timeextent", "InvalidParameterValue");
+ // if (n == 2) /* end time is empty. It is going to be set as "now*/
+ // pszEndTime = tokens[1];
//psNode = xmlAddChild(psRootNode, msSOSAddTimeNode(xmlNewNs(NULL, BAD_CAST pszOMNamespaceUri, BAD_CAST pszOMNamespacePrefix), tokens[0], pszEndTime));
- psNode = xmlAddChild(psRootNode, msSOSAddTimeNode(psNsOm, psNsGml, tokens[0], pszEndTime));
- msFreeCharArray(tokens, n);
+ // psNode = xmlAddChild(psRootNode, msSOSAddTimeNode(psNsOm, psNsGml, tokens[0], pszEndTime));
+ // msFreeCharArray(tokens, n);
if (sosparams->pszResultModel && strcasecmp(sosparams->pszResultModel, "om:Measurement") != 0 &&
strcasecmp(sosparams->pszResultModel, "om:Observation") != 0)
More information about the mapserver-commits
