[mapserver-commits] r7663 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Jun 11 14:03:24 EDT 2008
Author: dmorissette
Date: 2008-06-11 14:03:23 -0400 (Wed, 11 Jun 2008)
New Revision: 7663
trunk/mapserver/HISTORY.TXT
Minor formatting changes
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2008-06-11 17:07:03 UTC (rev 7662)
+++ trunk/mapserver/HISTORY.TXT 2008-06-11 18:03:23 UTC (rev 7663)
@@ -10,9 +10,13 @@
For a complete change history, please see the Subversion log comments.
-Current Version (5.2.0-beta1, SVN trunk):
+Current Version (SVN trunk):
+Version 5.2.0-beta1 (2008-06-11):
- WMS/WFS layers can now specify a proxy servert (#571)
- mapwmslayer.c: set QUERY_LAYERS correctly (#2001)
@@ -23,15 +27,15 @@
- mapwcs.c: advertise temporal support in GetCapabilities (#2487)
-- Fixed flaw in findTag() in maptemplate.c that prevented multiple tags on the same line
- being processed under certain conditions. (#2633)
+- Fixed flaw in findTag() in maptemplate.c that prevented multiple tags
+ on the same line being processed under certain conditions. (#2633)
- Return results even when extents are missing (#2420)
- Avoid displaying OGR connection strings in error messages (#2629)
-- WCS: respect wcs_name metadata for GetCoverage and DescribeCoverage requests
- (#2036)
+- WCS: respect wcs_name metadata for GetCoverage and DescribeCoverage
+ requests (#2036)
- CGI: added -nh option to allow for the suppression of content headers from
the command line (#2594)
@@ -46,7 +50,8 @@
- AGG: enable offset lines of type x -99 (#2588)
-- AGG: use an agg specific label size calculation function where possible (#2357)
+- AGG: use an agg specific label size calculation function where
+ possible (#2357)
- mapogcsld.c: fetch TextSymbolizer/Label/ogc:PropertyName correctly (#2611)
@@ -136,11 +141,13 @@
- completed implementation of RFC24 (#2442, #2032)
-- mapwcs.c: require VERSION parameter for DescribeCoverage and GetCoverage (#2473)
+- mapwcs.c: require VERSION parameter for DescribeCoverage and
+ GetCoverage (#2473)
- mapwcs.c: change error token to MS_WCSERR instead of MS_WMSERR (#2474)
-- mapwcs.c: set exception MIME type to application/vnd.ogc.se_xml for 1.0.0 (#2470)
+- mapwcs.c: set exception MIME type to application/vnd.ogc.se_xml
+ for 1.0.0 (#2470)
- mapwcs.c: Generate a decently formatted exception if an WCS XML POST request
is received (#2476).
@@ -229,7 +236,8 @@
- don't remove points that are checked as being colinear (#2366)
-- add initial(?) support for reading a pie chart's size from an attribute (#2136)
+- add initial(?) support for reading a pie chart's size from an
+ attribute (#2136)
- don't bail out in map parsing if the outputformat had to be modified
(bug #2321)
@@ -245,8 +253,8 @@
- AGG: allow for fast and aliased rendering of simple lines and polygons
thick lines and patterns (i.e. dashes)aren't supported.
- this is triggered when the symbol is of TYPE SYMBOL *and* its ANTIALIAS is off
- (wating to find a better solution to trigger this).
+ this is triggered when the symbol is of TYPE SYMBOL *and* its ANTIALIAS
+ is off (wating to find a better solution to trigger this).
- AGG: the pixmap of pixmap symbols is now cached in an agg-compatible state
the first time it is accessed. this avoids rereading and retransforming
More information about the mapserver-commits
