[mapserver-commits] r7674 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Jun 13 12:58:20 EDT 2008
Author: tomkralidis
Date: 2008-06-13 12:58:20 -0400 (Fri, 13 Jun 2008)
New Revision: 7674
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapwfs.c
- mapwfs.c: set layer extent to map extent for default
GetFeature requests with no spatial predicates (#1287)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2008-06-13 00:56:47 UTC (rev 7673)
+++ trunk/mapserver/HISTORY.TXT 2008-06-13 16:58:20 UTC (rev 7674)
@@ -13,6 +13,8 @@
Current Version (SVN trunk):
+- mapwfs.c: set layer extent to map extent for default
+ GetFeature requests with no spatial predicates (#1287)
Version 5.2.0-beta1 (2008-06-11):
Modified: trunk/mapserver/mapwfs.c
--- trunk/mapserver/mapwfs.c 2008-06-13 00:56:47 UTC (rev 7673)
+++ trunk/mapserver/mapwfs.c 2008-06-13 16:58:20 UTC (rev 7674)
@@ -1080,7 +1080,8 @@
if (msWFSIsLayerSupported(lp) && lp->name && strcasecmp(lp->name, layers[k]) == 0) {
const char *pszThisLayerSRS;
+ char szBuf[32];
+ rectObj ext;
bLayerFound = MS_TRUE;
lp->status = MS_ON;
@@ -1113,8 +1114,29 @@
"msWFSGetFeature()");
return msWFSException(map, "typename", "InvalidParameterValue", paramsObj->pszVersion);
+ /* set the map extent to the layer extent */
+ /* get the extent of the layer (bbox will get further filtered later */
+ /* if the client specifies BBOX or a spatial filter */
+ if (msOWSGetLayerExtent(map, lp, "FO", &ext) == MS_SUCCESS) {
+ sprintf(szBuf, "init=epsg:%.10s", pszMapSRS+5);
+ if (szBuf != NULL) {
+ if (msLoadProjectionString(&(map->projection), szBuf) != 0) {
+ msSetError(MS_WFSERR, "msLoadProjectionString() failed2: %s", "msWFSGetFeature()", szBuf);
+ return msWFSException(map, "mapserv", "NoApplicableCode", paramsObj->pszVersion);
+ if (msProjectionsDiffer(&map->projection, &lp->projection) == MS_TRUE) {
+ msProjectRect(&lp->projection, &map->projection, &(ext));
+ bbox = map->extent = ext;
if (!bLayerFound) {
More information about the mapserver-commits
