[mapserver-commits] r7689 - trunk/mapserver
Wed Jun 18 09:35:26 EDT 2008
Author: Assefa
Date: 2008-06-18 09:35:26 -0400 (Wed, 18 Jun 2008)
New Revision: 7689
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapwfs.c
Generate error message when applying filter encoding #2444
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-06-17 20:35:33 UTC (rev 7688)
+++ trunk/mapserver/HISTORY.TXT	2008-06-18 13:35:26 UTC (rev 7689)
@@ -13,6 +13,8 @@
 Current Version (SVN trunk):
+-  mapwfs.c: Genrate possibly an error message when applying filter encoding (#2444)
 - Added MS_LABEL_BINDING constants for SWIG MapScript (#2643)
 - mapogcsos.c: fix POST support (#2379)
Modified: trunk/mapserver/mapwfs.c
--- trunk/mapserver/mapwfs.c	2008-06-17 20:35:33 UTC (rev 7688)
+++ trunk/mapserver/mapwfs.c	2008-06-18 13:35:26 UTC (rev 7689)
@@ -1224,6 +1224,7 @@
       FilterEncodingNode *psNode = NULL;
       int iLayerIndex =1;
       char **paszFilter = NULL;
+      errorObj   *ms_error;
       /*      Validate the parameters. When a FILTER parameter is given,      */
@@ -1311,7 +1312,16 @@
         /* run filter.  If no results are found, do not throw exception */
         /* this is a null result */
-	FLTApplyFilterToLayer(psNode, map, iLayerIndex, MS_FALSE);
+        if( FLTApplyFilterToLayer(psNode, map, iLayerIndex, MS_FALSE) != MS_SUCCESS )
+            ms_error = msGetErrorObj();
+            if(ms_error->code != MS_NOTFOUND)
+                msSetError(MS_WFSERR, "FLTApplyFilterToLayer() failed", "msWFSGetFeature()", pszFilter);
+                return msWFSException(map, "mapserv", "NoApplicableCode", paramsObj->pszVersion);
         FLTFreeFilterEncodingNode( psNode );
         psNode = NULL;
