[mapserver-commits] r7692 - trunk/mapserver
Wed Jun 18 14:24:27 EDT 2008
Author: dmorissette
Date: 2008-06-18 14:24:26 -0400 (Wed, 18 Jun 2008)
New Revision: 7692
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/configure
   trunk/mapserver/configure.in
Fixed libiconv detection in configure for OSX 10.5 64 bit (#2396)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-06-18 18:07:15 UTC (rev 7691)
+++ trunk/mapserver/HISTORY.TXT	2008-06-18 18:24:26 UTC (rev 7692)
@@ -13,11 +13,15 @@
 Current Version (SVN trunk):
+- Fixed libiconv detection in configure for OSX 10.5 64 bit (#2396)
 - mapstring.c: possible buffer overflow in msGetPath (#2649)
-- maputil.c: Correct expression evaluation with text containing apostrophes (#2641)
+- maputil.c: Correct expression evaluation with text containing
+  apostrophes (#2641)
-- mapwfs.c: Genrate possibly an error message when applying filter encoding (#2444)
+- mapwfs.c: Possibly generate an error message when applying filter
+  encoding (#2444)
 - Added MS_LABEL_BINDING constants for SWIG MapScript (#2643)
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure	2008-06-18 18:07:15 UTC (rev 7691)
+++ trunk/mapserver/configure	2008-06-18 18:24:26 UTC (rev 7692)
@@ -5886,6 +5886,7 @@
 unset ac_cv_lib_iconv_libiconv_open
+unset ac_cv_lib_iconv_iconv_open
 unset ac_cv_lib_c_iconv_open
@@ -6046,9 +6047,74 @@
   ICONV_LIB="-L$ICONV_LIBDIR -liconv"
 fi
+  { echo "$as_me:$LINENO: checking for iconv_open in -liconv" >&5
+echo $ECHO_N "checking for iconv_open in -liconv... $ECHO_C" >&6; }
+if test "${ac_cv_lib_iconv_iconv_open+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  ac_check_lib_save_LIBS=$LIBS
+LIBS="-liconv "-L$ICONV_LIBDIR" $LIBS"
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+/* Override any GCC internal prototype to avoid an error.
+   Use char because int might match the return type of a GCC
+   builtin and then its argument prototype would still apply.  */
+#ifdef __cplusplus
+extern "C"
+#endif
+char iconv_open ();
+int
+main ()
+return iconv_open ();
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (ac_try="$ac_link"
+case "(($ac_try" in
+  *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
+  *) ac_try_echo=$ac_try;;
+esac
+eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5
+  (eval "$ac_link") 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  cat conftest.err >&5
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); } && {
+	 test -z "$ac_c_werror_flag" ||
+	 test ! -s conftest.err
+       } && test -s conftest$ac_exeext &&
+       $as_test_x conftest$ac_exeext; then
+  ac_cv_lib_iconv_iconv_open=yes
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+	ac_cv_lib_iconv_iconv_open=no
 fi
+rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \
+      conftest$ac_exeext conftest.$ac_ext
+LIBS=$ac_check_lib_save_LIBS
+fi
+{ echo "$as_me:$LINENO: result: $ac_cv_lib_iconv_iconv_open" >&5
+echo "${ECHO_T}$ac_cv_lib_iconv_iconv_open" >&6; }
+if test $ac_cv_lib_iconv_iconv_open = yes; then
+  ICONV_LIB="-L$ICONV_LIBDIR -liconv"
+fi
+fi
 if test -n "$ICONV_LIB" ; then
   if test -n "$ICONV_INCDIR"; then
      ICONV_INC="-I$ICONV_INCDIR"
@@ -6213,7 +6279,72 @@
   ICONV_LIB="-liconv"
 fi
+else
+LIBS="-liconv  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+int
+main ()
+  return 0;
+_ACEOF
+esac
+  ac_status=$?
+else
+fi
+fi
+  ICONV_LIB="-liconv"
+fi
     { echo "$as_me:$LINENO: result:         using libiconv from system libs." >&5
 echo "${ECHO_T}        using libiconv from system libs." >&6; }
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in	2008-06-18 18:07:15 UTC (rev 7691)
+++ trunk/mapserver/configure.in	2008-06-18 18:24:26 UTC (rev 7692)
@@ -384,6 +384,7 @@
 dnl ---------------------------------------------------------------------
 AC_ARG_WITH(libiconv,
@@ -410,6 +411,7 @@
   dnl Just doing the AC_CHECK_LIB(iconv ...) last does the trick.
   AC_CHECK_LIB(c, iconv_open, ICONV_LIB="-L$ICONV_LIBDIR -lc",,"-L$ICONV_LIBDIR")
   AC_CHECK_LIB(iconv, libiconv_open, ICONV_LIB="-L$ICONV_LIBDIR -liconv",,"-L$ICONV_LIBDIR")
+  AC_CHECK_LIB(iconv, iconv_open, ICONV_LIB="-L$ICONV_LIBDIR -liconv",,"-L$ICONV_LIBDIR")
 fi
@@ -428,6 +430,7 @@
   AC_CHECK_LIB(c, iconv_open, ICONV_LIB="-lc",,)
   AC_CHECK_LIB(iconv, libiconv_open, ICONV_LIB="-liconv",,)
+  AC_CHECK_LIB(iconv, iconv_open, ICONV_LIB="-liconv",,)
     AC_MSG_RESULT([        using libiconv from system libs.])
