[mapserver-commits] r7696 - trunk/mapserver
Wed Jun 18 18:43:53 EDT 2008
Author: Assefa
Date: 2008-06-18 18:43:53 -0400 (Wed, 18 Jun 2008)
New Revision: 7696
   trunk/mapserver/mapogcfilter.c
   trunk/mapserver/mapquery.c
   trunk/mapserver/mapserver.h
Filter Encoding: Modify DWithin definition (#2564)
Modified: trunk/mapserver/mapogcfilter.c
--- trunk/mapserver/mapogcfilter.c	2008-06-18 21:40:51 UTC (rev 7695)
+++ trunk/mapserver/mapogcfilter.c	2008-06-18 22:43:53 UTC (rev 7696)
@@ -88,8 +88,7 @@
       return MS_GEOS_TOUCHES;
      else if (strcasecmp(pszValue, "Crosses") == 0)
       return MS_GEOS_CROSSES;
-     else if (strcasecmp(pszValue, "Within") == 0 ||
-              strcasecmp(pszValue, "DWithin") == 0)
+     else if (strcasecmp(pszValue, "Within") == 0)
       return MS_GEOS_WITHIN;
      else if (strcasecmp(pszValue, "Contains") == 0)
       return MS_GEOS_CONTAINS;
@@ -97,6 +96,8 @@
       return MS_GEOS_OVERLAPS;
      else if (strcasecmp(pszValue, "Beyond") == 0)
       return MS_GEOS_BEYOND;
+    else if (strcasecmp(pszValue, "DWithin") == 0)
+      return MS_GEOS_DWITHIN;
     return -1;
@@ -318,7 +319,8 @@
     else if (bPointQuery && psQueryShape && psQueryShape->numlines > 0
              && psQueryShape->line[0].numpoints > 0) /* && dfDistance >=0) */
-        if (bUseGeos)
+      if (bUseGeos)
             if ((strcasecmp(psNode->pszValue, "DWithin") == 0 ||
                  strcasecmp(psNode->pszValue, "Beyond") == 0 ) &&
Modified: trunk/mapserver/mapquery.c
--- trunk/mapserver/mapquery.c	2008-06-18 21:40:51 UTC (rev 7695)
+++ trunk/mapserver/mapquery.c	2008-06-18 22:43:53 UTC (rev 7696)
@@ -1217,7 +1217,7 @@
 /*                            msQueryByOperator                         */
-/*      uary using a shape and a valid operator : all queries are       */
+/*      query using a shape and a valid operator : all queries are       */
 /*      done using geos.                                                */
 int msQueryByOperator(mapObj *map, int qlayer, shapeObj *selectshape,
@@ -1227,11 +1227,12 @@
     int start, stop=0, l;
     shapeObj shape;
     layerObj *lp;
-    char status;
+    int status;
     rectObj searchrect;
     int nclasses = 0;
     int *classgroup = NULL;
+    double dfValue;
     msInitShape(&shape);
@@ -1394,16 +1395,24 @@
               status = MS_FALSE;
             break;
-            /*beyond is opposite of dwith use in filter encoding
-              see ticket 2105*/
+            /*beyond is opposite of dwithin use in filter encoding
+              see ticket 2105, 2564*/
           case MS_GEOS_BEYOND:
-            status = msGEOSWithin(&shape, selectshape);
-            if (status != MS_TRUE && status != MS_FALSE)
-              status = MS_FALSE;
-            else
-              status = !status;
+            status = MS_FALSE;
+            dfValue = msGEOSDistance(&shape, selectshape);
+            if (dfValue > 0.0)
+               status = MS_TRUE;
           break;
+          /*dwithin is used with filter encoding (#2564)*/
+          case MS_GEOS_DWITHIN:
+            if (dfValue == 0.0)
+              status = MS_TRUE;
+          break;
           default:
             msSetError(MS_QUERYERR, "Unknown GEOS Operator.", "msQueryByOperator()");
             return(MS_FAILURE);
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2008-06-18 21:40:51 UTC (rev 7695)
+++ trunk/mapserver/mapserver.h	2008-06-18 22:43:53 UTC (rev 7696)
@@ -350,7 +350,7 @@
 enum MS_RETURN_VALUE {MS_SUCCESS, MS_FAILURE, MS_DONE};
 enum MS_IMAGEMODE { MS_IMAGEMODE_PC256, MS_IMAGEMODE_RGB, MS_IMAGEMODE_RGBA, MS_IMAGEMODE_INT16, MS_IMAGEMODE_FLOAT32, MS_IMAGEMODE_BYTE, MS_IMAGEMODE_NULL };
-enum MS_GEOS_OPERATOR {MS_GEOS_EQUALS, MS_GEOS_DISJOINT, MS_GEOS_TOUCHES, MS_GEOS_OVERLAPS, MS_GEOS_CROSSES, MS_GEOS_INTERSECTS, MS_GEOS_WITHIN, MS_GEOS_CONTAINS, MS_GEOS_BEYOND};
+  enum MS_GEOS_OPERATOR {MS_GEOS_EQUALS, MS_GEOS_DISJOINT, MS_GEOS_TOUCHES, MS_GEOS_OVERLAPS, MS_GEOS_CROSSES, MS_GEOS_INTERSECTS, MS_GEOS_WITHIN, MS_GEOS_CONTAINS, MS_GEOS_BEYOND, MS_GEOS_DWITHIN};
 #define MS_FILE_DEFAULT MS_FILE_MAP
 #ifndef SWIG
