[mapserver-commits] r7698 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Jun 18 21:19:20 EDT 2008
Author: tomkralidis
Date: 2008-06-18 21:19:20 -0400 (Wed, 18 Jun 2008)
New Revision: 7698
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapgml.c
trunk/mapserver/mapogcsos.c
trunk/mapserver/mapsde.c
trunk/mapserver/mapserver.h
trunk/mapserver/mapstring.c
add srsName support for GetObservation (#2414)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2008-06-18 22:45:02 UTC (rev 7697)
+++ trunk/mapserver/HISTORY.TXT 2008-06-19 01:19:20 UTC (rev 7698)
@@ -13,6 +13,8 @@
Current Version (SVN trunk):
+- mapogcsos.c: support srsName in GetObservation (#2414)
- Filter Encoding: Modify DWithin definition (#2564)
- Added webObj legendformat and browseformat mapping in PHP MapScript (#2309)
Modified: trunk/mapserver/mapgml.c
--- trunk/mapserver/mapgml.c 2008-06-18 22:45:02 UTC (rev 7697)
+++ trunk/mapserver/mapgml.c 2008-06-19 01:19:20 UTC (rev 7698)
@@ -1582,17 +1582,17 @@
free(pszTmp);
- pszTmp = msDoubleToString(minx);
+ pszTmp = msDoubleToString(minx, MS_TRUE);
pszTmp = msStringConcatenate(pszTmp, " ");
- pszTmp2 = msDoubleToString(miny);
+ pszTmp2 = msDoubleToString(miny, MS_TRUE);
pszTmp = msStringConcatenate(pszTmp, pszTmp2);
psSubSubNode = xmlNewChild(psSubNode, NULL, BAD_CAST "lowerCorner", BAD_CAST pszTmp);
free(pszTmp);
free(pszTmp2);
- pszTmp = msDoubleToString(maxx);
+ pszTmp = msDoubleToString(maxx, MS_TRUE);
- pszTmp2 = msDoubleToString(maxy);
+ pszTmp2 = msDoubleToString(maxy,MS_TRUE);
psSubSubNode = xmlNewChild(psSubNode, NULL, BAD_CAST "upperCorner", BAD_CAST pszTmp);
free(pszTmp);
@@ -1640,9 +1640,9 @@
free(pszTmp);
- pszTmp = msDoubleToString(x);
+ pszTmp = msDoubleToString(x, MS_TRUE);
- pszTmp = msStringConcatenate(pszTmp, msDoubleToString(y));
+ pszTmp = msStringConcatenate(pszTmp, msDoubleToString(y, MS_TRUE));
psSubNode = xmlNewChild(psNode, NULL, BAD_CAST "pos", BAD_CAST pszTmp);
free(pszTmp);
Modified: trunk/mapserver/mapogcsos.c
--- trunk/mapserver/mapogcsos.c 2008-06-18 22:45:02 UTC (rev 7697)
+++ trunk/mapserver/mapogcsos.c 2008-06-19 01:19:20 UTC (rev 7698)
@@ -347,7 +347,7 @@
/* from gmlWriteGeometry_GML2. Should be merged at one point if */
/* possible. */
-void msSOSAddGeometryNode(xmlNsPtr psNsGml, xmlNodePtr psParent, layerObj *lp, shapeObj *psShape,
+void msSOSAddGeometryNode(xmlNsPtr psNsGml, xmlNodePtr psParent, mapObj *map, layerObj *lp, shapeObj *psShape,
const char *pszEpsg)
char *pszTmp = NULL;
@@ -357,6 +357,11 @@
if (psParent && psShape)
+ if (msProjectionsDiffer(&map->projection, &lp->projection) == MS_TRUE)
+ msProjectShape(&lp->projection, &map->projection, psShape);
+ pszEpsg = msOWSGetEPSGProj(&(map->projection), &(lp->metadata), "SO", MS_TRUE);
switch(psShape->type)
case(MS_SHAPE_POINT):
@@ -423,10 +428,10 @@
for(j=0; j<psShape->line[i].numpoints; j++)
- msDoubleToString(psShape->line[i].point[j].x));
+ msDoubleToString(psShape->line[i].point[j].x, MS_TRUE));
pszTmp = msStringConcatenate(pszTmp, ",");
- msDoubleToString(psShape->line[i].point[j].y));
+ msDoubleToString(psShape->line[i].point[j].y, MS_TRUE));
psNode = xmlNewChild(psNode, NULL, BAD_CAST "coordinates", BAD_CAST pszTmp);
@@ -492,11 +497,11 @@
pszTmp =
pszTmp =
@@ -796,14 +801,17 @@
/*bbox*/
#ifdef USE_PROJ
- pszEpsg = msOWSGetEPSGProj(&(map->projection), &(map->web.metadata), "SO", MS_TRUE);
if (!pszEpsg)
pszEpsg = msOWSGetEPSGProj(&(lp->projection), &(lp->metadata), "SO", MS_TRUE);
+ msProjectRect(&lp->projection, &map->projection, &sShape.bounds);
#endif
psNode = xmlAddChild(psLayerNode, msGML3BoundedBy(psNsGml, sShape.bounds.minx, sShape.bounds.miny, sShape.bounds.maxx, sShape.bounds.maxy, pszEpsg));
/*geometry*/
- msSOSAddGeometryNode(psNsGml, psLayerNode, lp, &sShape, pszEpsg);
+ msSOSAddGeometryNode(psNsGml, psLayerNode, map, lp, &sShape, pszEpsg);
/*attributes */
/* TODO only output attributes where there is a sos_%s_alias (to be discussed)*/
@@ -2044,6 +2052,64 @@
map->extent.maxy = sBbox.maxy;
+ if (sosparams->pszSrsName) { /* validate against MAP.WEB.METADATA.sos_srs */
+ int iUnits = -1;
+ char **tokens = NULL;
+ const char *pszSRSList = NULL;
+ int n = 0;
+ int bFound = 0;
+ int k;
+ char srsbuffer[100];
+ projectionObj po;
+ pszSRSList = msOWSLookupMetadata(&(map->web.metadata), "SO", "srs");
+ if (pszSRSList) {
+ tokens = msStringSplit(pszSRSList, ' ', &n);
+ if (tokens && n > 0) {
+ for (k=0; k<n; k++) {
+ if (strcasecmp(sosparams->pszSrsName, tokens[k]) == 0) { /* match */
+ bFound = 1;
+ /* project MAP.EXTENT to this SRS */
+ msInitProjection(&po);
+ sprintf(srsbuffer, "+init=epsg:%.20s", sosparams->pszSrsName+5);
+ if (msLoadProjectionString(&po, srsbuffer) != 0) {
+ msSetError(MS_SOSERR, "Could not set output projection to \"%s\"", "msSOSGetObservation()", sosparams->pszSrsName);
+ return msSOSException(map, "mapserv", "NoApplicableCode");
+ if (msProjectionsDiffer(&map->projection, &po) == MS_TRUE) {
+ msProjectRect(&map->projection, &po, &map->extent);
+ sBbox = map->extent;
+ /* set map->projection to this SRS */
+ if (msLoadProjectionString(&(map->projection), srsbuffer) != 0) {
+ iUnits = GetMapserverUnitUsingProj(&(map->projection));
+ if (iUnits != -1)
+ map->units = iUnits;
+ msFreeProjection(&po);
+ break;
+ msFreeCharArray(tokens, n);
+ if (bFound == 0) {
+ msSetError(MS_SOSERR, "srsName value \"%s\" unsupported / invalid", "msSOSGetObservation()", sosparams->pszSrsName);
+ return msSOSException(map, "srsName", "InvalidParameterValue");
/* apply filter */
if (sosparams->pszResult) {
psFilterNode = FLTParseFilterEncoding(sosparams->pszResult);
@@ -2155,14 +2221,34 @@
char **tokens;
int n;
- pszTmp2 = msOWSGetEPSGProj(&(lp->projection), &(lp->metadata), "SO", MS_TRUE);
+ rectObj envelope;
+ pszTmp2 = msOWSGetEPSGProj(&(map->projection), &(lp->metadata), "SO", MS_TRUE);
tokens = msStringSplit(pszTmp, ',', &n);
if (tokens==NULL || n != 4) {
msSetError(MS_SOSERR, "Wrong number of arguments for offering_extent.",
"msSOSGetCapabilities()");
return msSOSException(map, "offering_extent", "InvalidParameterValue");
- psNode = xmlAddChild(psRootNode, msGML3BoundedBy(psNsGml, atof(tokens[0]), atof(tokens[1]), atof(tokens[2]), atof(tokens[3]), pszTmp2));
+ envelope.minx = atof(tokens[0]);
+ envelope.miny = atof(tokens[1]);
+ envelope.maxx = atof(tokens[2]);
+ envelope.maxy = atof(tokens[3]);
+ if (map && msProjectionsDiffer(&map->projection, &lp->projection) == MS_TRUE) {
+ if (msProjectRect(&lp->projection, &map->projection, &envelope) == MS_FAILURE){
+ msSetError(MS_SOSERR, "Coordinates transformation failed. Raised in msProjectRect() of file %s line %d", "msSOSGetCapabilities()", __FILE__, __LINE__);
+ return msSOSException(map, "offering_extent", "InvalidParameterValue");
+ //msSetError(MS_SOSERR, "%f %f %f %f", "msSOSGetCapabilities()", envelope.minx, envelope.miny, envelope.maxx, envelope.maxy);
+ //return msSOSException(map, "offering_extent", "InvalidParameterValue");
+ //psNode = xmlAddChild(psRootNode, msGML3BoundedBy(psNsGml, atof(tokens[0]), atof(tokens[1]), atof(tokens[2]), atof(tokens[3]), pszTmp2));
+ psNode = xmlAddChild(psRootNode, msGML3BoundedBy(psNsGml, envelope.minx, envelope.miny, envelope.maxx, envelope.maxy, pszTmp2));
@@ -2803,7 +2889,7 @@
xmlXPathFreeObject(psXPathTmp);
/* check for eventTime (chunk of XML) */
- psXPathTmp = msLibXml2GetXPath(doc, context, (xmlChar *)"/sos:GetObservation/sos:eventTime/ogc:TM_Equals/gml:TimeInstant|/sos:GetObservation/sos:eventTime/ogc:TM_Equals/gml:TimePeriod");
+ psXPathTmp = msLibXml2GetXPath(doc, context, (xmlChar *)"/sos:GetObservation/sos:eventTime/*/gml:TimeInstant|/sos:GetObservation/sos:eventTime/*/gml:TimePeriod");
if (psXPathTmp) {
sosparams->pszEventTime = (char *)msLibXml2GetXPathTree(doc, psXPathTmp);
Modified: trunk/mapserver/mapsde.c
--- trunk/mapserver/mapsde.c 2008-06-18 22:45:02 UTC (rev 7697)
+++ trunk/mapserver/mapsde.c 2008-06-19 01:19:20 UTC (rev 7698)
@@ -688,7 +688,7 @@
(short)(i+1),
&floatval);
if(status == SE_SUCCESS)
- shape->values[i] = msDoubleToString(floatval);
+ shape->values[i] = msDoubleToString(floatval, MS_FALSE);
else if(status == SE_NULL_VALUE)
shape->values[i] = strdup(MS_SDE_NULLSTRING);
else {
@@ -703,7 +703,7 @@
(short) (i+1),
&doubleval);
- shape->values[i] = msDoubleToString(doubleval);
+ shape->values[i] = msDoubleToString(doubleval, MS_FALSE);
else {
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2008-06-18 22:45:02 UTC (rev 7697)
+++ trunk/mapserver/mapserver.h 2008-06-19 01:19:20 UTC (rev 7698)
@@ -1602,7 +1602,7 @@
MS_DLL_EXPORT char **msStringSplit(const char *string, char cd, int *num_tokens);
MS_DLL_EXPORT int msCountChars(char *str, char ch);
MS_DLL_EXPORT char *msLongToString(long value);
-MS_DLL_EXPORT char *msDoubleToString(double value);
+MS_DLL_EXPORT char *msDoubleToString(double value, int force_f);
MS_DLL_EXPORT char *msIntToString(int value);
MS_DLL_EXPORT void msStringToUpper(char *string);
MS_DLL_EXPORT void msStringToLower(char *string);
Modified: trunk/mapserver/mapstring.c
--- trunk/mapserver/mapstring.c 2008-06-18 22:45:02 UTC (rev 7697)
+++ trunk/mapserver/mapstring.c 2008-06-19 01:19:20 UTC (rev 7698)
@@ -244,10 +244,13 @@
return(strdup(buffer));
-char *msDoubleToString(double value) {
+char *msDoubleToString(double value, int force_f) {
char buffer[256]; /* plenty of space */
- sprintf(buffer, "%g", value);
+ if (force_f == MS_TRUE)
+ sprintf(buffer, "%f", value);
+ else
+ sprintf(buffer, "%g", value);
More information about the mapserver-commits
