[mapserver-commits] r7715 - trunk/mapserver
Thu Jun 19 22:18:05 EDT 2008
Author: Assefa
Date: 2008-06-19 22:18:05 -0400 (Thu, 19 Jun 2008)
New Revision: 7715
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapogcfilter.c
Generate error for  some invalid filters #2604
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-06-20 01:05:35 UTC (rev 7714)
+++ trunk/mapserver/HISTORY.TXT	2008-06-20 02:18:05 UTC (rev 7715)
@@ -12,6 +12,8 @@
 Current Version (SVN trunk):
+- SOS: generate error for some invalid filters (#2604)
 - SLD: Use style's width paramater when generating sld (#1192)
 Version 5.2.0-beta2 (2008-06-18):
Modified: trunk/mapserver/mapogcfilter.c
--- trunk/mapserver/mapogcfilter.c	2008-06-20 01:05:35 UTC (rev 7714)
+++ trunk/mapserver/mapogcfilter.c	2008-06-20 02:18:05 UTC (rev 7715)
@@ -1750,7 +1750,7 @@
             if (FLTIsBinaryComparisonFilterType(psXMLNode->pszValue))
                 psTmpNode = CPLSearchXMLNode(psXMLNode,  "PropertyName");
-                if (psTmpNode &&  psXMLNode->psChild &&
+                if (psTmpNode &&  psTmpNode->psChild &&
                     psTmpNode->psChild->pszValue &&
                     strlen(psTmpNode->psChild->pszValue) > 0)
@@ -1760,66 +1760,44 @@
                       strdup(psTmpNode->psChild->pszValue);
                     psTmpNode = CPLSearchXMLNode(psXMLNode,  "Literal");
-                        psTmpNode->psChild &&
-                        psTmpNode->psChild->pszValue &&
-                        strlen(psTmpNode->psChild->pszValue) > 0)
+                    if (psTmpNode)
                         psFilterNode->psRightNode = FLTCreateBinaryCompFilterEncodingNode();
                         psFilterNode->psRightNode->eType = FILTER_NODE_TYPE_LITERAL;
-                        psFilterNode->psRightNode->pszValue =
-                          strdup(psTmpNode->psChild->pszValue);
-                        /*check if the matchCase attribute is set*/
-                        if (psXMLNode->psChild &&
-                            psXMLNode->psChild->eType == CXT_Attribute  &&
-                            psXMLNode->psChild->pszValue &&
-                            strcasecmp(psXMLNode->psChild->pszValue, "matchCase") == 0 &&
-                            psXMLNode->psChild->psChild &&
-                            psXMLNode->psChild->psChild->pszValue &&
-                            strcasecmp( psXMLNode->psChild->psChild->pszValue, "false") == 0)
+                        if (psTmpNode &&
+                            psTmpNode->psChild &&
+                            psTmpNode->psChild->pszValue &&
+                            strlen(psTmpNode->psChild->pszValue) > 0)
-                            (*(int *)psFilterNode->psRightNode->pOther) = 1;
-                    if (psXMLNode->psChild->psChild &&
-                        strlen(psXMLNode->psChild->psChild->pszValue) > 0)
-                        psFilterNode->psLeftNode->eType = FILTER_NODE_TYPE_PROPERTYNAME;
-                        psFilterNode->psLeftNode->pszValue =
-                          strdup(psXMLNode->psChild->psChild->pszValue);
+                            psFilterNode->psRightNode->pszValue =
+                              strdup(psTmpNode->psChild->pszValue);
-                    psFilterNode->psRightNode = FLTCreateFilterEncodingNode();
-                    /* special case where the user puts an empty value */
-                    /* for the Literal so it can end up as an empty  */
-                    /* string query in the expression */
-                    psFilterNode->psRightNode->eType = FILTER_NODE_TYPE_LITERAL;
-                    if (psXMLNode->psChild->psNext->psChild &&
-                        psXMLNode->psChild->psNext->psChild->pszValue &&
-                        strlen(psXMLNode->psChild->psNext->psChild->pszValue) > 0)
-                          strdup(psXMLNode->psChild->psNext->psChild->pszValue);
+                            /*check if the matchCase attribute is set*/
+                            if (psXMLNode->psChild &&
+                                psXMLNode->psChild->eType == CXT_Attribute  &&
+                                psXMLNode->psChild->pszValue &&
+                                strcasecmp(psXMLNode->psChild->pszValue, "matchCase") == 0 &&
+                                psXMLNode->psChild->psChild &&
+                                psXMLNode->psChild->psChild->pszValue &&
+                                strcasecmp( psXMLNode->psChild->psChild->pszValue, "false") == 0)
+                                (*(int *)psFilterNode->psRightNode->pOther) = 1;
+                        /* special case where the user puts an empty value */
+                        /* for the Literal so it can end up as an empty  */
+                        /* string query in the expression */
+                        else
+                          psFilterNode->psRightNode->pszValue = NULL;
-                    else
-                      psFilterNode->psRightNode->pszValue = NULL;
-                else
+                if (psFilterNode->psLeftNode == NULL || psFilterNode->psRightNode == NULL)
                   psFilterNode->eType = FILTER_NODE_TYPE_UNDEFINED;
 /*      PropertyIsBetween filter : extract property name and boudary    */
 /*      values. The boundary  values are stored in the right            */
