[mapserver-commits] r7726 - trunk/docs/howto
Mon Jun 23 10:57:27 EDT 2008
Author: tomkralidis
Date: 2008-06-23 10:57:26 -0400 (Mon, 23 Jun 2008)
New Revision: 7726
   trunk/docs/howto/sos_server.txt
make sos_srs required (#2558)
Modified: trunk/docs/howto/sos_server.txt
--- trunk/docs/howto/sos_server.txt	2008-06-21 15:56:58 UTC (rev 7725)
+++ trunk/docs/howto/sos_server.txt	2008-06-23 14:57:26 UTC (rev 7726)
@@ -103,7 +103,7 @@
 Each instance of SOS server that you setup needs to have its own mapfile. It is just a regular MapServer mapfile in which some parameters and some metadata entries are mandatory. Most of the metadata is required in order to produce a valid GetCapabilites output.
-Here is the list of parameters and metadata items that usually optional with MapServer, but are **required (or strongly recommended) for a WMS configuration:**
+Here is the list of parameters and metadata items that usually optional with MapServer, but are **required (or strongly recommended) for a SOS configuration:**
 **MAP level:**
@@ -113,7 +113,7 @@
   - sos_title
   - sos_onlineresource
-  - sos_srs (unless PROJECTION object is defined using "init=epsg:...")
+  - sos_srs
   - see the `Reference Section`_ of this document for a full list of metadata and
     descriptions
@@ -127,7 +127,6 @@
   - sos_observedproperty_id
   - sos_describesensor_url
-  - sos_srs (optional since the layers inherit the map's SRS value)
     descriptions
@@ -186,7 +185,7 @@
          METADATA
            "sos_onlineresource" "http://127.0.0.1/cgi-bin/mapserv.exe?map=D:/ms4w/apps/sos/sos_test.map" ## REQUIRED
            "sos_title"          "My SOS Demo Server" ## Recommended
-           "sos_srs"            "epsg:4326" ## Recommended
+           "sos_srs"            "EPSG:4326" ## REQUIRED
          END
         END
@@ -433,7 +432,7 @@
 **sos_srs**
-- *Description:* (Recommended) Contains a list of EPSG projection codes that should be advertized as being available for all layers in this server. The value can contain one or more EPSG:<code> pairs separated by spaces (e.g. "EPSG:4269 EPSG:4326") This value should be upper case (EPSG:42304.....not epsg:42304) to avoid problems with case sensitive platforms.
+- *Description:* (Required) Contains a list of EPSG projection codes that should be advertized as being available for all layers in this server. The value can contain one or more EPSG:<code> pairs separated by spaces (e.g. "EPSG:4269 EPSG:4326") This value should be upper case (EPSG:42304.....not epsg:42304) to avoid problems with case sensitive platforms.
 **sos_title**
