[mapserver-commits] r7763 - trunk/mapserver
Sat Jun 28 12:31:05 EDT 2008
Author: pramsey
Date: 2008-06-28 12:31:04 -0400 (Sat, 28 Jun 2008)
New Revision: 7763
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapshape.c
restore old behavior of tiled shapes relative to shapepath with new behavior for when shapepath is undefined (#2369)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-06-28 15:39:24 UTC (rev 7762)
+++ trunk/mapserver/HISTORY.TXT	2008-06-28 16:31:04 UTC (rev 7763)
@@ -12,6 +12,9 @@
 Current Version (SVN trunk):
+- mapshape.c: restore old behavior of tiled shapes relative to shapepath
+  with new behavior for when shapepath is undefined (#2369)
 - maputil.c: fix a bug for offset lines with agg, when the first segment
   was horizontal (#2659)
Modified: trunk/mapserver/mapshape.c
--- trunk/mapserver/mapshape.c	2008-06-28 15:39:24 UTC (rev 7762)
+++ trunk/mapserver/mapshape.c	2008-06-28 16:31:04 UTC (rev 7763)
@@ -1875,18 +1875,23 @@
     if(strlen(filename) == 0) continue; /* check again */
-    msBuildPath3(szPath, tiFileAbsDir, layer->map->shapepath, filename);
-    /* open the shapefile */
-    if(msShapefileOpen(tSHP->shpfile, "rb", szPath) == -1) {
+    if(msShapefileOpen(tSHP->shpfile, "rb", msBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, filename)) == -1) {
+      if(msShapefileOpen(tSHP->shpfile, "rb", msBuildPath3(szPath, tiFileAbsDir, layer->map->shapepath, filename)) == -1) {
+        if(msShapefileOpen(tSHP->shpfile, "rb", msBuildPath(szPath, layer->map->mappath, filename)) == -1) {
 #ifndef IGNORE_MISSING_DATA
-      if( layer->debug || layer->map->debug ) msDebug( "Unable to open shapefile %s for layer %s ... fatal error.\n", szPath, layer->name );
-      return(MS_FAILURE);
+          if( layer->debug || layer->map->debug ) {
+            msDebug( "Unable to open file %s for layer %s ... fatal error.\n", filename, layer->name );
+          return(MS_FAILURE);
 #else
-      if( layer->debug || layer->map->debug ) msDebug( "Unable to open shapefile %s for layer %s ... ignoring this missing data.\n", szPath, layer->name );
-      continue; /* check again */
+            msDebug( "Unable to open shapefile %s for layer %s ... ignoring this missing data.\n", szPath, layer->name );
+          continue; /* check again */
 #endif
     return(MS_SUCCESS); /* found a template, ok to proceed */
@@ -1937,17 +1942,22 @@
 #else
 #endif
       status = msShapefileWhichShapes(tSHP->shpfile, rect, layer->debug);
@@ -1985,18 +1995,23 @@
 #else
 #endif
@@ -2072,17 +2087,22 @@
 #else
 #endif
           status = msShapefileWhichShapes(tSHP->shpfile, tSHP->tileshpfile->statusbounds, layer->debug);
@@ -2120,17 +2140,22 @@
 #else
 #endif
@@ -2214,14 +2239,14 @@
     /* open the shapefile, since a specific tile was request an error should be generated if that tile does not exist */
     if(strlen(filename) == 0) return(MS_FAILURE);
-    msTileIndexAbsoluteDir(tiFileAbsDir, layer);
   if((record < 0) || (record >= tSHP->shpfile->numshapes)) return(MS_FAILURE);
