[mapserver-commits] r7765 - trunk/mapserver
    svn at osgeo.org
    svn at osgeo.org
    Mon Jun 30 14:01:39 EDT 2008
Author: tbonfort
Date: 2008-06-30 14:01:38 -0400 (Mon, 30 Jun 2008)
New Revision: 7765
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapresample.c
mapresample.c: fix for bug 2540 when using raster resampling and AGG
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-06-29 14:44:06 UTC (rev 7764)
+++ trunk/mapserver/HISTORY.TXT	2008-06-30 18:01:38 UTC (rev 7765)
@@ -11,6 +11,7 @@
 Current Version (SVN trunk):
+- mapresample.c: fix for bug 2540 when using raster resampling and AGG.
 - mapsde.c: Check at compile time that we have SE_connection_test_server,
   which appears to only be available for ArcSDE 9+ (#2665).
Modified: trunk/mapserver/mapresample.c
--- trunk/mapserver/mapresample.c	2008-06-29 14:44:06 UTC (rev 7764)
+++ trunk/mapserver/mapresample.c	2008-06-30 18:01:38 UTC (rev 7765)
@@ -172,41 +172,6 @@
-#ifdef USE_AGG
-            else if( MS_RENDERER_AGG(psSrcImage->format) )
-                if( !gdImageTrueColor(psSrcImage->img.gd) )
-                    nValue = panCMap[srcImg->pixels[nSrcY][nSrcX]];
-                    if( nValue == -1 )
-                        continue;
-                    nSetPoints++;
-                    dstImg->pixels[nDstY][nDstX] = nValue;
-                else
-                    int nValue = srcImg->tpixels[nSrcY][nSrcX];
-                    int gd_alpha = gdTrueColorGetAlpha(nValue);
-                    if( gd_alpha == 0 )
-                        nSetPoints++;
-                        dstImg->tpixels[nDstY][nDstX] = nValue;
-                    else if( gd_alpha == 127 )
-                        /* overlay is transparent, do nothing */;
-                    else
-                        nSetPoints++;
-                            gdAlphaBlend( dstImg->tpixels[nDstY][nDstX],
-                                          nValue );
-#endif
             else if( MS_RENDERER_RAWDATA(psSrcImage->format) )
                 int band;
@@ -326,31 +291,6 @@
-#ifdef USE_AGG
-            padfPixelSum[0] +=
-                (dfWeight * psSrcImage->img.gd->pixels[iSrcY][iSrcX]);
-            *pdfWeightSum += dfWeight;
-        else
-            int nValue = psSrcImage->img.gd->tpixels[iSrcY][iSrcX];
-            if( gd_alpha != 127 )
-                padfPixelSum[0] += dfWeight * gdTrueColorGetRed(nValue);
-                padfPixelSum[1] += dfWeight * gdTrueColorGetGreen(nValue);
-                padfPixelSum[2] += dfWeight * gdTrueColorGetBlue(nValue);
-#endif
     else
         int band;
@@ -549,45 +489,6 @@
-#ifdef USE_AGG
-                    int nResult = panCMap[(int) padfPixelSum[0]];
-                    if( nResult != -1 )
-                        nSetPoints++;
-                        dstImg->pixels[nDstY][nDstX] = nResult;
-                else
-                    nSetPoints++;
-                    if( dfWeightSum > 0.99 )
-                            gdTrueColor( (int) padfPixelSum[0],
-                                         (int) padfPixelSum[1],
-                                         (int) padfPixelSum[2] );
-                    else
-                        int gd_color;
-                        int gd_alpha = 127 - 127.9 * dfWeightSum;
-                        gd_alpha = MAX(0,MIN(127,gd_alpha));
-                        gd_color = gdTrueColorAlpha(
-                            (int) padfPixelSum[0],
-                            (int) padfPixelSum[2],
-                            gd_alpha );
-                            msAlphaBlend( dstImg->tpixels[nDstY][nDstX],
-                                          gd_color );
-#endif
                 int band;
@@ -814,46 +715,6 @@
-#ifdef USE_AGG
-                        nSetPoints++;
-                else
-                    nSetPoints++;
-                    if( dfAlpha01 > 0.99 )
-                    else
-                        int gd_color;
-                        int gd_alpha = (int) (127 - 127.9 * dfAlpha01);
-                            gd_alpha );
-                                          gd_color );
-#endif
                 int band;
@@ -1646,6 +1507,21 @@
 /*      for the temporary image to include transparentency support.     */
     sDummyMap.outputformat = msCloneOutputFormat( image->format );
+  #ifdef USE_AGG
+    if( MS_RENDERER_AGG(sDummyMap.outputformat))
+Fix for bug 2540 :
+The resampling methods used later assume that the pixel format of the
+dummy image is in gd format (alpha between 127 and 0). If we keep an AGG
+outpuformat, the image is initialised with its alpha=0, which is interpreted
+as fully opaque instead of fully transparent. The fix is to completely forget
+about AGG here, and create a GD imageObj
+        sDummyMap.outputformat->renderer=MS_RENDER_WITH_GD;
+#endif
     sDummyMap.width = nLoadImgXSize;
     sDummyMap.height = nLoadImgYSize;
@@ -1664,16 +1540,6 @@
         sDummyMap.imagecolor.green = 17;
         sDummyMap.imagecolor.blue = 191;
-#ifdef USE_AGG
-    else if( MS_RENDERER_AGG(sDummyMap.outputformat)
-        && !gdImageTrueColor( image->img.gd ) )
-        sDummyMap.outputformat->transparent = MS_TRUE;
-        sDummyMap.imagecolor.red = 117;
-        sDummyMap.imagecolor.green = 17;
-        sDummyMap.imagecolor.blue = 191;
-#endif
 /*      If we are working in RGB mode ensure we produce an RGBA         */
 /*      image so the transparency can be preserved.                     */
@@ -1691,21 +1557,6 @@
         sDummyMap.imagecolor.green = map->imagecolor.green;
         sDummyMap.imagecolor.blue = map->imagecolor.blue;
-#ifdef USE_AGG
-             && gdImageTrueColor( image->img.gd ) )
-        assert( sDummyMap.outputformat->imagemode == MS_IMAGEMODE_RGB
-                || sDummyMap.outputformat->imagemode == MS_IMAGEMODE_RGBA );
-        sDummyMap.outputformat->imagemode = MS_IMAGEMODE_RGBA;
-        sDummyMap.imagecolor.red = map->imagecolor.red;
-        sDummyMap.imagecolor.green = map->imagecolor.green;
-        sDummyMap.imagecolor.blue = map->imagecolor.blue;
-#endif
 /*      Setup a dummy map object we can use to read from the source     */
 /*      raster, with the newly established extents, and resolution.     */
@@ -1761,27 +1612,6 @@
         for( iColor = nColorCount; iColor < 256; iColor++ )
             anCMap[iColor] = -1;
-#ifdef USE_AGG
-    else if( MS_RENDERER_AGG(srcImage->format)
-        && !gdImageTrueColor( srcImage->img.gd ) )
-        int  iColor, nColorCount;
-        anCMap[0] = -1; /* color zero is always transparent */
-        nColorCount = gdImageColorsTotal( srcImage->img.gd );
-        for( iColor = 1; iColor < nColorCount; iColor++ )
-            anCMap[iColor] =
-                msAddColorAGG( map, image->img.gd, 0,
-                              gdImageRed( srcImage->img.gd, iColor ),
-                              gdImageGreen( srcImage->img.gd, iColor ),
-                              gdImageBlue( srcImage->img.gd, iColor ) );
-        for( iColor = nColorCount; iColor < 256; iColor++ )
-            anCMap[iColor] = -1;
-#endif
 /*      Setup transformations between our source image, and the         */
 /*      target map image.                                               */
More information about the mapserver-commits
