[mapserver-commits] r7454 - trunk/msautotest/wxs/data
Fri Mar 14 08:20:23 EDT 2008
Author: tomkralidis
Date: 2008-03-14 08:20:23 -0400 (Fri, 14 Mar 2008)
New Revision: 7454
Added:
   trunk/msautotest/wxs/data/sos-2147.xml
   trunk/msautotest/wxs/data/sos-35.xml
   trunk/msautotest/wxs/data/sos-604.xml
Removed:
   trunk/msautotest/wxs/data/p2147.xml
   trunk/msautotest/wxs/data/p35.xml
   trunk/msautotest/wxs/data/p604.xml
rename files to match def in sos.map
Deleted: trunk/msautotest/wxs/data/p2147.xml
--- trunk/msautotest/wxs/data/p2147.xml	2008-03-14 12:16:54 UTC (rev 7453)
+++ trunk/msautotest/wxs/data/p2147.xml	2008-03-14 12:20:23 UTC (rev 7454)
@@ -1,72 +0,0 @@
-<?xml version="1.0" encoding="ISO-8859-1"?>
-<sml:SensorML xmlns:sml="http://www.opengis.net/sensorML/1.0" xmlns:swe="http://www.opengis.net/swe/1.0" xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="http://www.w3.org/1999/xlink" xsi:schemaLocation="http://www.opengis.net/sensorML/1.0 http://schemas.opengis.net/sensorML/1.0.0/sensorML.xsd" version="1.0">
-<sml:member>
-<sml:ProcessModel gml:id="p2147">
-   <!-- METADATA -->
-   <gml:description>
-      Water Quality Measurement:  procedure 2147
-   </gml:description>
-            <sml:identification>
-                <sml:IdentifierList>
-                    <sml:identifier>
-                        <sml:Term definition="urn:x-ogc:def:identifier:OGC:longName">
-                            <sml:value>Water quality measurement p2147</sml:value>
-                        </sml:Term>
-                    </sml:identifier>
-                    <sml:identifier>
-                        <sml:Term definition="urn:x-ogc:def:identifier:OGC:shortName">
-                            <sml:value>p2147</sml:value>
-                        </sml:Term>
-                    </sml:identifier>
-                    <sml:identifier>
-                        <sml:Term definition="http://www.w3.org/1999/02/22-rdf-syntax-ns#ID">
-                            <sml:value>urn:ogc:def:procedure:p2147</sml:value>
-                        </sml:Term>
-                    </sml:identifier>
-                    <sml:identifier>
-                        <sml:Term definition="urn:x-ogc:def:identifier:OGC:operatorShortName">
-                            <sml:value>MS</sml:value>
-                        </sml:Term>
-                    </sml:identifier>
-                    <sml:identifier>
-                        <sml:Term definition="urn:x-ogc:def:identifier:OGC:dataProviderShortName">
-                        </sml:Term>
-                    </sml:identifier>
-                    <sml:identifier>
-                        <sml:Term definition="urn:x-ogc:def:identifier:OGC:regionalAssociationShortName">
-                        </sml:Term>
-                    </sml:identifier>
-                </sml:IdentifierList>
-            </sml:identification>
-   <!-- INPUTS -->
-   <sml:inputs>
-      <sml:InputList>
-         <sml:input name="input1">
-            <swe:Quantity definition="urn:ogc:def:phenomenon:p1"/>
-         </sml:input>
-         <sml:input name="input2">
-            <swe:Count definition="urn:ogc:def:phenomenon:p2"/>
-         </sml:input>
-         <sml:input name="input3">
-            <swe:Quantity definition="urn:ogc:def:phenomenon:p3"/>
-         </sml:input>
-      </sml:InputList>
-   </sml:inputs>
-   <!-- OUTPUTS -->
-   <sml:outputs>
-      <sml:OutputList>
-         <sml:output name="output1">
-            <swe:Quantity definition="urn:ogc:def:phenomenon:p4"/>
-         </sml:output>
-      </sml:OutputList>
-   </sml:outputs>
-   <!-- METHOD -->
-   <sml:method xlink:href="urn:ogc:def:process:method2:1.0"/>
-</sml:ProcessModel>
-</sml:member>
-</sml:SensorML>
Deleted: trunk/msautotest/wxs/data/p35.xml
--- trunk/msautotest/wxs/data/p35.xml	2008-03-14 12:16:54 UTC (rev 7453)
+++ trunk/msautotest/wxs/data/p35.xml	2008-03-14 12:20:23 UTC (rev 7454)
@@ -1,32 +0,0 @@
-<sml:member>
-<sml:ProcessModel gml:id="p35">
-   <!-- METADATA -->
-   <gml:description>
-      Water Quality Measurement:  procedure 35
-   <!-- INPUTS -->
-   <sml:inputs>
-      <sml:InputList>
-         </sml:input>
-         </sml:input>
-      </sml:InputList>
-   </sml:inputs>
-   <!-- OUTPUTS -->
-   <sml:outputs>
-      <sml:OutputList>
-         </sml:output>
-      </sml:OutputList>
-   </sml:outputs>
-   <!-- METHOD -->
-   <sml:method xlink:href="urn:ogc:def:process:method1:1.0"/>
-</sml:member>
-</sml:SensorML>
Deleted: trunk/msautotest/wxs/data/p604.xml
--- trunk/msautotest/wxs/data/p604.xml	2008-03-14 12:16:54 UTC (rev 7453)
+++ trunk/msautotest/wxs/data/p604.xml	2008-03-14 12:20:23 UTC (rev 7454)
@@ -1,40 +0,0 @@
-<sml:member>
-<sml:ProcessModel gml:id="p604">
-   <!-- METADATA -->
-   <gml:description>
-      Water Quality Measurement:  procedure 604
-    <!-- INPUTS -->
-   <sml:inputs>
-      <sml:InputList>
-           </sml:input>
-          </sml:input>
-          </sml:input>
-         <sml:input name="input4">
-          </sml:input>
-      </sml:InputList>
-   </sml:inputs>
-   <!-- OUTPUTS -->
-   <sml:outputs>
-      <sml:OutputList>
-            <swe:Quantity definition="urn:ogc:def:phenomenon:p5"/>
-          </sml:output>
-      </sml:OutputList>
-   </sml:outputs>
-   <!-- METHOD -->
-   <sml:method xlink:href="urn:ogc:def:process:method3:1.0"/>
-</sml:member>
-</sml:SensorML>
Copied: trunk/msautotest/wxs/data/sos-2147.xml (from rev 7453, trunk/msautotest/wxs/data/p2147.xml)
--- trunk/msautotest/wxs/data/sos-2147.xml	                        (rev 0)
+++ trunk/msautotest/wxs/data/sos-2147.xml	2008-03-14 12:20:23 UTC (rev 7454)
@@ -0,0 +1,72 @@
+<?xml version="1.0" encoding="ISO-8859-1"?>
+<sml:SensorML xmlns:sml="http://www.opengis.net/sensorML/1.0" xmlns:swe="http://www.opengis.net/swe/1.0" xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="http://www.w3.org/1999/xlink" xsi:schemaLocation="http://www.opengis.net/sensorML/1.0 http://schemas.opengis.net/sensorML/1.0.0/sensorML.xsd" version="1.0">
+<sml:member>
+<sml:ProcessModel gml:id="p2147">
+   <!-- METADATA -->
+   <gml:description>
+      Water Quality Measurement:  procedure 2147
+   </gml:description>
+            <sml:identification>
+                <sml:IdentifierList>
+                    <sml:identifier>
+                        <sml:Term definition="urn:x-ogc:def:identifier:OGC:longName">
+                            <sml:value>Water quality measurement p2147</sml:value>
+                        </sml:Term>
+                    </sml:identifier>
+                    <sml:identifier>
+                        <sml:Term definition="urn:x-ogc:def:identifier:OGC:shortName">
+                            <sml:value>p2147</sml:value>
+                        </sml:Term>
+                    </sml:identifier>
+                    <sml:identifier>
+                        <sml:Term definition="http://www.w3.org/1999/02/22-rdf-syntax-ns#ID">
+                            <sml:value>urn:ogc:def:procedure:p2147</sml:value>
+                        </sml:Term>
+                    </sml:identifier>
+                    <sml:identifier>
+                        <sml:Term definition="urn:x-ogc:def:identifier:OGC:operatorShortName">
+                            <sml:value>MS</sml:value>
+                        </sml:Term>
+                    </sml:identifier>
+                    <sml:identifier>
+                        <sml:Term definition="urn:x-ogc:def:identifier:OGC:dataProviderShortName">
+                        </sml:Term>
+                    </sml:identifier>
+                    <sml:identifier>
+                        <sml:Term definition="urn:x-ogc:def:identifier:OGC:regionalAssociationShortName">
+                        </sml:Term>
+                    </sml:identifier>
+                </sml:IdentifierList>
+            </sml:identification>
+   <!-- INPUTS -->
+   <sml:inputs>
+      <sml:InputList>
+         <sml:input name="input1">
+            <swe:Quantity definition="urn:ogc:def:phenomenon:p1"/>
+         </sml:input>
+         <sml:input name="input2">
+            <swe:Count definition="urn:ogc:def:phenomenon:p2"/>
+         </sml:input>
+         <sml:input name="input3">
+            <swe:Quantity definition="urn:ogc:def:phenomenon:p3"/>
+         </sml:input>
+      </sml:InputList>
+   </sml:inputs>
+   <!-- OUTPUTS -->
+   <sml:outputs>
+      <sml:OutputList>
+         <sml:output name="output1">
+            <swe:Quantity definition="urn:ogc:def:phenomenon:p4"/>
+         </sml:output>
+      </sml:OutputList>
+   </sml:outputs>
+   <!-- METHOD -->
+   <sml:method xlink:href="urn:ogc:def:process:method2:1.0"/>
+</sml:ProcessModel>
+</sml:member>
+</sml:SensorML>
Copied: trunk/msautotest/wxs/data/sos-35.xml (from rev 7453, trunk/msautotest/wxs/data/p35.xml)
--- trunk/msautotest/wxs/data/sos-35.xml	                        (rev 0)
+++ trunk/msautotest/wxs/data/sos-35.xml	2008-03-14 12:20:23 UTC (rev 7454)
@@ -0,0 +1,32 @@
+<sml:member>
+<sml:ProcessModel gml:id="p35">
+   <!-- METADATA -->
+   <gml:description>
+      Water Quality Measurement:  procedure 35
+   <!-- INPUTS -->
+   <sml:inputs>
+      <sml:InputList>
+         </sml:input>
+         </sml:input>
+      </sml:InputList>
+   </sml:inputs>
+   <!-- OUTPUTS -->
+   <sml:outputs>
+      <sml:OutputList>
+         </sml:output>
+      </sml:OutputList>
+   </sml:outputs>
+   <!-- METHOD -->
+   <sml:method xlink:href="urn:ogc:def:process:method1:1.0"/>
+</sml:member>
+</sml:SensorML>
Copied: trunk/msautotest/wxs/data/sos-604.xml (from rev 7453, trunk/msautotest/wxs/data/p604.xml)
--- trunk/msautotest/wxs/data/sos-604.xml	                        (rev 0)
+++ trunk/msautotest/wxs/data/sos-604.xml	2008-03-14 12:20:23 UTC (rev 7454)
@@ -0,0 +1,40 @@
+<sml:member>
+<sml:ProcessModel gml:id="p604">
+   <!-- METADATA -->
+   <gml:description>
+      Water Quality Measurement:  procedure 604
+    <!-- INPUTS -->
+   <sml:inputs>
+      <sml:InputList>
+           </sml:input>
+          </sml:input>
+          </sml:input>
+         <sml:input name="input4">
+          </sml:input>
+      </sml:InputList>
+   </sml:inputs>
+   <!-- OUTPUTS -->
+   <sml:outputs>
+      <sml:OutputList>
+            <swe:Quantity definition="urn:ogc:def:phenomenon:p5"/>
+          </sml:output>
+      </sml:OutputList>
+   </sml:outputs>
+   <!-- METHOD -->
+   <sml:method xlink:href="urn:ogc:def:process:method3:1.0"/>
+</sml:member>
+</sml:SensorML>
