[mapserver-commits] r7475 - trunk/docs/howto
svn at osgeo.org
svn at osgeo.org
Thu Mar 20 17:28:31 EDT 2008
Author: jmckenna
Date: 2008-03-20 17:28:30 -0400 (Thu, 20 Mar 2008)
New Revision: 7475
trunk/docs/howto/mapcontext.txt
add dimension metadata (ticket 1581)
Modified: trunk/docs/howto/mapcontext.txt
--- trunk/docs/howto/mapcontext.txt 2008-03-20 19:36:53 UTC (rev 7474)
+++ trunk/docs/howto/mapcontext.txt 2008-03-20 21:28:30 UTC (rev 7475)
@@ -2,7 +2,7 @@
:Author: Jeff McKenna
:Contact: jmckenna(at)dmsolutions.ca
-:Last Updated: 2006/02/14
+:Last Updated: 2008/03/20
@@ -28,8 +28,9 @@
Support for OGC Web Map Context was added to MapServer in version 3.7/4.0. This
allows client applications to load and save a map configuration in a standard XML format.
-MapServer can read context documents of versions 0.1.2, 0.1.4, 0.1.7, & 1.0.0 and
-can export contents in versions 0.1.4, 0.1.7, & 1.0.0.
+MapServer can read context documents of versions 0.1.2, 0.1.4, 0.1.7, 1.0.0, 1.1.0 and
+can export contents in versions 0.1.4, 0.1.7, 1.0.0, 1.1.0. Web Map Context 1.1.0
+support was added to MapServer 4.10
This document assumes that you are already familiar with certain aspects of MapServer:
@@ -153,7 +154,29 @@
- *wms_dataurl_format* : Format of the online resource where data corresponding
to the layer can be found.
+- *wms_dimension* : Current dimension used. (added in MapServer 4.10)
+- *wms_dimensionlist* : List of available dimensions. (added in MapServer 4.10)
+- *wms_dimension_%s_default* : Default dimension value. (added in MapServer 4.10) MapServer will check for wms_time and wms_timedefault metadata when this is not specified.
+ %s = the name of the dimension.
+- *wms_dimension_%s_multiplevalues* : Multiple dimension values. (added in MapServer 4.10)
+- *wms_dimension_%s_nearestvalue* : Nearest dimension value. The default value is 0. (added in MapServer 4.10)
+- *wms_dimension_%s_units* : Units for the dimension values. The default value is ISO8601. (added in MapServer 4.10)
+- *wms_dimension_%s_unitsymbol* : Symbol for dimension units. The default value is t. (added in MapServer 4.10)
+- *wms_dimension_%s_uservalue* : User dimension value. (added in MapServer 4.10) MapServer will check for wms_time and wms_timedefault metadata when this is not specified.
- *wms_format* : Current format used.
- *wms_formatlist* : List of available formats for this layer.
@@ -234,6 +257,14 @@
"wms_srs" "EPSG:42304"
"wms_title" "Canadian boundaries" #### REQUIRED
"wms_onlineresource" "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?" #### REQUIRED
+ "wms_dimensionlist" "time,width"
+ "wms_dimension" "time"
+ "wms_dimension_time_unitsymbol" "t"
+ "wms_dimension_time_units" "ISO8601"
+ "wms_dimension_time_uservalue" "1310"
+ "wms_dimension_time_default" "1310"
+ "wms_dimension_time_multiplevalues" "1310,1410"
+ "wms_dimension_time_nearestvalue" "0"
END
END
@@ -265,7 +296,7 @@
<?php
- dl("php_mapscript_48.dll");
+ dl("php_mapscript.dll");
$oMap = ms_newMapObj("gmap_wms_context.map");
$oMap->saveMapContext("gmap_wms_context_output.xml");
@@ -285,64 +316,47 @@
- <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
- <ViewContext version="1.0.0" id="DEMO" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://www.opengis.net/context" xsi:schemaLocation="http://www.opengis.net/context http://schemas.opengis.net/context/1.0.0/context.xsd">
- <General>
- <Window width="400" height="300"/>
- <!-- Bounding box corners and spatial reference system -->
- <BoundingBox SRS="EPSG:42304" minx="-2610230.000000" miny="-905635.000000" maxx="2636310.000000" maxy="3031130.000000"/>
- <!-- Title of Context -->
- <Title>my test</Title>
- </General>
- <!-- LayerList of Layer elements
- - implied order: bottom To Top
- first Layer element is bottom most layer in map view
- last Layer elements is op most layer in map view
- <LayerList>
- <Layer queryable="0" hidden="0">
- <Server service="WMS" version="1.1.1" title="Oceans/Seas">
- <OnlineResource xlink:type="simple" xlink:href="http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?"/>
- </Server>
- <Name>OCEANSEA_BND_1M:Foundation</Name>
- <Title>Oceans/Seas</Title>
- <Abstract>VRF Narrative Table for 'Oceans/Seas':\n\n<P>In coastal area, points of change from ocean/sea areas (BA040) to inland water\nareas (BH000) were taken from Digital Chart of the World, edition 1, July 1992\nexcept when it was determined that the point of change was implemented too far\ninland. In these cases, cartographic judgement was used to establish the point\nof change.\n</Abstract>
- <SRS>EPSG:4326 AUTO:42001 AUTO:42002 AUTO:42003 AUTO:42004EPSG:32750 EPSG:32751 EPSG:32752 EPSG:32753 EPSG:32754 EPSG:32755 EPSG:32756 EPSG:32757 EPSG:32758 EPSG:32759 EPSG:32760 EPSG:41001 EPSG:42101 EPSG:42102 EPSG:42103 EPSG:42104 EPSG:42105 EPSG:42106 EPSG:42301 EPSG:42302 EPSG:42303 EPSG:42304 EPSG:42305 EPSG:42306 EPSG:42307 EPSG:42308 EPSG:42309 EPSG:42310 EPSG:100001.................</SRS>
- <FormatList>
- <Format>image/png image/tiff image/gif image/jpeg image/ppm application/x-cubestor-wkb application/x-cubestor-gml.1 application/x</Format>
- </FormatList>
- <StyleList>
- <Style current="1">
- <Name>0xb8d8f6</Name>
- <Title>0xb8d8f6</Title>
- <LegendURL width="16" height="16" format="image/gif">
- <OnlineResource xlink:type="simple" xlink:href="http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?VERSION=1.1.1&REQUEST=GetLegendGraphic&LAYER=OCEANSEA_BND_1M%3AFoundation&SPATIAL_TYPE=POLYGON&STYLE=0xb8d8f6&FORMAT=image%2Fgif&SIMPLE=TRUE"/>
- </LegendURL>
- </Style>
- </StyleList>
- </Layer>
- <Server service="WMS" version="1.1.1" title="Political Boundaries">
- </Server>
- <Name>POLBNDL_BND_1M:Foundation</Name>
- <Title>Political Boundaries</Title>
- <SRS>EPSG:4326 AUTO:42001 AUTO:42002 AUTO:42003 AUTO:EPSG:42102 EPSG:42103 EPSG:42104 EPSG:42105 EPSG:42106 EPSG:42301 EPSG:42302 EPSG:42303 EPSG:42304 EPSG:42305 EPSG:42306 EPSG:42307 EPSG:42308 EPSG:42309 EPSG:42310 EPSG:100001...........</SRS>
- <FormatList>
- </FormatList>
- <StyleList>
- <Name>black</Name>
- <Title>black</Title>
- <OnlineResource xlink:type="simple" xlink:href="http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?VERSION=1.1.1&REQUEST=GetLegendGraphic&LAYER=POLBNDL_BND_1M%3AFoundation&SPATIAL_TYPE=LINE&STYLE=black&FORMAT=image%2Fgif&SIMPLE=TRUE"/>
- </LegendURL>
- </Style>
- </StyleList>
- </Layer>
- </LayerList>
- </ViewContext>
+ <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
+ <ViewContext version="1.1.0" id="WMS_CONTEXT" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ogc="http://www.opengis.net/ogc" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://www.opengis.net/context" xmlns:sld="http://www.opengis.net/sld" xsi:schemaLocation="http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd">
+ <General>
+ <Window width="400" height="300"/>
+ <!-- Bounding box corners and spatial reference system -->
+ <BoundingBox SRS="EPSG:42304" minx="-2200000.000000" miny="-712631.000000" maxx="3072800.000000" maxy="3840000.000000"/>
+ <!-- Title of Context -->
+ <Title>Map Context demo</Title>
+ <Abstract>Demo for map context document. Blah blah...</Abstract>
+ <ContactInformation>
+ </ContactInformation>
+ </General>
+ <LayerList>
+ <Layer queryable="0" hidden="0">
+ <Server service="OGC:WMS" version="1.1.1" title="Canadian boundaries">
+ <OnlineResource xlink:type="simple" xlink:href="http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?"/>
+ </Server>
+ <Name>prov_bound</Name>
+ <Title>Canadian boundaries</Title>
+ <SRS>EPSG:42304</SRS>
+ <FormatList>
+ <Format current="1">image/gif</Format>
+ </FormatList>
+ <DimensionList>
+ <Dimension name="time" units="ISO8601" unitSymbol="t" userValue="1310" default="1310" multipleValues="1310,1410" nearestValue="0" current="1"/>
+ </DimensionList>
+ </Layer>
+ <Server service="OGC:WMS" version="1.1.1" title="Canadian Cities">
+ </Server>
+ <Name>popplace</Name>
+ <Title>Canadian Cities</Title>
+ <FormatList>
+ <Format current="1">image/png</Format>
+ </FormatList>
+ </DimensionList>
+ </Layer>
+ </LayerList>
+ </ViewContext>
Map Context Support Through CGI
More information about the mapserver-commits
