[mapserver-commits] r7554 - trunk/mapserver/rfc
svn at osgeo.org
svn at osgeo.org
Thu May 1 19:56:01 EDT 2008
Author: pramsey
Date: 2008-05-01 19:56:01 -0400 (Thu, 01 May 2008)
New Revision: 7554
trunk/mapserver/rfc/ms-rfc-43.txt
Update to reflect new tilemode behavior (gmap and ve modes)
Modified: trunk/mapserver/rfc/ms-rfc-43.txt
--- trunk/mapserver/rfc/ms-rfc-43.txt 2008-05-01 23:51:43 UTC (rev 7553)
+++ trunk/mapserver/rfc/ms-rfc-43.txt 2008-05-01 23:56:01 UTC (rev 7554)
@@ -1,6 +1,6 @@
-MS RFC 43: Direct tile generation for Google Maps API
+MS RFC 43: Direct tile generation for Google Maps and Virtual Earth API
:Date: 2008/04/08
:Author: Paul Ramsey
@@ -9,10 +9,10 @@
:Status: Adopted on 2008/04/29 - Under development
:Version: MapServer 5.2
-Overview
+Overview
+Providing a simple access API in the mapserv CGI can make using Mapserver with the Google Maps and Virtual Earth user interfaces dramatically easier for new users.
Technical Solution
@@ -25,32 +25,63 @@
For Mapserver, the simple URL pattern will be::
- http://host/cgi-bin/mapserv?map=/the.map&layers=foo,bar&mode=tile&tilemode=spheremerc&tile={X}+{Y}+{Z}
+ http://host/cgi-bin/mapserv?map=/the.map&layers=foo,bar&mode=tile&tilemode=gmap&tile={X}+{Y}+{Z}
The change will add in new handling in the loadForm function for the mode, interface, version, x, y and z parameters. Like the WMS interface, GMaps API will require PROJ to be specified, and the existence of PROJECTION defines for all layers being accessed. Google X/Y/Z coordinates will be converted to "spherical mercator" coordinates and fed into the extent.
The result will make a Google-with-Mapserver map as easy as::
- var myLayer = new GTileLayer(null,null,null,{
- tileUrlTemplate: ' http://host/cgi-bin/mapserv?map=/the.map&layers=foo,bar&mode=tile&tilemode=spheremerc&tile={X}+{Y}+{Z}',
- isPng:true,
- opacity:0.5 });
+ var url = "http://host/cgi-bin/mapserv?";
+ url += "map=/the.map&";
+ url += "layers=parcels&";
+ url += "mode=tile&";
+ url += "tilemode=gmap&";
+ url += "tile={X}+{Y}+{Z}";
+ var myLayer = new GTileLayer(null,null,null,
+ tileUrlTemplate:url,
+ isPng:true,
+ opacity:0.5
var map = new GMap2(document.getElementById("map"));
map.addOverlay(new GTileLayerOverlay(myLayer));
-A tile mode with interface of gmap implies the following:
+A Virtual Earth with Mapserver map would look like::
+ url += "tilemode=ve&";
+ url += "tile=%4";
+ map = new VEMap("map");
+ map.LoadMap();
+ var tileSourceSpec = new VETileSourceSpecification( "myLayer", url );
+ tileSourceSpec.Opacity = 0.3;
+ map.AddTileLayer(tileSourceSpec, true);
+A request with tilemode of "gmap" implies the following:
+* The "tile" parameter will be of the form: x y zoom
* The output CRS will be set to "spherical mercator" (EPSG:900913)
-* The service bounds be global in extent. The top level (0) will have 1 tile.
-* The "levels" will run from 0 upwards
-* The y axis of the tile coordinates will run from top to bottom
+* The service bounds be global in extent. The top "zoom" level (0) will have 1 tile.
+* The "zoom" levels will run from 0 upwards
+* The "y" axis of the tile coordinates will run from top to bottom
+* The "x" axis of the tile coordinates will run from left to right
* The output tiles will be 256x256 in size
* Each zoom level will be related to parent and children by powers of two
+A request with tilemode of "ve" implies the following:
+* The "tile" parameter will use the VE tile numbering scheme, for example "0312". See http://msdn.microsoft.com/en-us/library/bb545006.aspx for more details.
+* The output CRS will be set to "spherical mercator" (EPSG:900913)
+* The service bounds be global in extent. The top level will have 4 tiles (0, 1, 2, 3).
+* The output tiles will be 256x256 in size
+* Each zoom level will be related to parent and children by powers of two
The Mapserver tile mode API will *not* explicitly attempt to address issues of meta-tiling or cross-tile labeling. However, the following steps will be taken to try to minimize these issues:
-* If PARTIALS is not set in labeling directives, it will be turned on automatically.
-* PROCESSING LABEL_NO_CLIP will be turned on automatically.
* Future phases will render into a target slightly larger than the tile and then clip off the extra border pixels.
Mapscript Implications
@@ -65,6 +96,7 @@
mapserv.c
maptile.c <new>
+ maptile.h <new>
* Documentation will be updated to reflect the new feature
@@ -93,6 +125,7 @@
References
+* http://msdn.microsoft.com/en-us/library/bb545006.aspx
* http://code.google.com/apis/maps/documentation/reference.html#GTileLayer
* http://www.worldwindcentral.com/wiki/TileService
More information about the mapserver-commits
