[mapserver-commits] r7572 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu May 8 10:14:39 EDT 2008
Author: sdlime
Date: 2008-05-08 10:14:39 -0400 (Thu, 08 May 2008)
New Revision: 7572
trunk/mapserver/maptemplate.c
Slowly towards RFC 36...
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c 2008-05-08 14:10:14 UTC (rev 7571)
+++ trunk/mapserver/maptemplate.c 2008-05-08 14:14:39 UTC (rev 7572)
@@ -191,53 +191,58 @@
return MS_FAILURE;
- /* does the format reference an outputFormatObj */
if((outputFormat = msSelectOutputFormat( mapserv->Map, queryFormat)) != NULL) {
- printf("got an output format!\n");
+ if( !MS_RENDERER_TEMPLATE(outputFormat) ) { /* got an image format, return the query results that way */
- } else {
- if(mapserv->Map->querymap.status) {
- checkWebScale(mapserv);
- img = msDrawMap(mapserv->Map, MS_TRUE);
- if(!img) return MS_FAILURE;
+ ** At this point we know we have a template of some sort, either the new style that references a or the old
+ ** style made up of external files slammed together. Either way we may have to compute a query map.
+ if(mapserv->Map->querymap.status) {
+ checkWebScale(mapserv);
- snprintf(buffer, 1024, "%s%s%s.%s", mapserv->Map->web.imagepath, mapserv->Map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->Map->outputformat));
+ img = msDrawMap(mapserv->Map, MS_TRUE);
+ if(!img) return MS_FAILURE;
+ snprintf(buffer, 1024, "%s%s%s.%s", mapserv->Map->web.imagepath, mapserv->Map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->Map->outputformat));
+ status = msSaveImage(mapserv->Map, img, buffer);
+ if(status != MS_SUCCESS) return status;
+ msFreeImage(img);
+ if((mapserv->Map->legend.status == MS_ON || mapserv->UseShapes) && mapserv->Map->legend.template == NULL) {
+ img = msDrawLegend(mapserv->Map, MS_FALSE);
+ snprintf(buffer, 1024, "%s%sleg%s.%s", mapserv->Map->web.imagepath, mapserv->Map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->Map->outputformat));
msFreeImage(img);
- if((mapserv->Map->legend.status == MS_ON || mapserv->UseShapes) && mapserv->Map->legend.template == NULL) {
- img = msDrawLegend(mapserv->Map, MS_FALSE);
- snprintf(buffer, 1024, "%s%sleg%s.%s", mapserv->Map->web.imagepath, mapserv->Map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->Map->outputformat));
- status = msSaveImage(mapserv->Map, img, buffer);
- if(status != MS_SUCCESS) return status;
- msFreeImage(img);
- if(mapserv->Map->scalebar.status == MS_ON) {
- img = msDrawScalebar(mapserv->Map);
- snprintf(buffer, 1024, "%s%ssb%s.%s", mapserv->Map->web.imagepath, mapserv->Map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->Map->outputformat));
- status = msSaveImage( mapserv->Map, img, buffer);
- msFreeImage(img);
+ if(mapserv->Map->scalebar.status == MS_ON) {
+ img = msDrawScalebar(mapserv->Map);
+ snprintf(buffer, 1024, "%s%ssb%s.%s", mapserv->Map->web.imagepath, mapserv->Map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->Map->outputformat));
+ status = msSaveImage( mapserv->Map, img, buffer);
+ msFreeImage(img);
- if(mapserv->Map->reference.status == MS_ON) {
- img = msDrawReferenceMap(mapserv->Map);
- snprintf(buffer, 1024, "%s%sref%s.%s", mapserv->Map->web.imagepath, mapserv->Map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->Map->outputformat));
- msFreeImage(img);
+ if(mapserv->Map->reference.status == MS_ON) {
+ img = msDrawReferenceMap(mapserv->Map);
+ snprintf(buffer, 1024, "%s%sref%s.%s", mapserv->Map->web.imagepath, mapserv->Map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->Map->outputformat));
+ msFreeImage(img);
+ if(outputFormat) {
+ printf("got an output format!\n");
+ } else {
if((status = msReturnQuery(mapserv, queryFormat, papszBuffer)) != MS_SUCCESS)
return status;
@@ -795,10 +800,10 @@
-** Function to process a [features ...] tag. This tag can *only* be found within
+** Function to process a [feature ...] tag. This tag can *only* be found within
** a [resultset ...][/resultset] block.
-static int processFeaturesTag(mapservObj *mapserv, char **line, layerObj *layer)
+static int processFeatureTag(mapservObj *mapserv, char **line, layerObj *layer)
char *preTag, *postTag; /* text before and after the tag */
@@ -808,31 +813,31 @@
int i, j, status;
if(!*line) {
- msSetError(MS_WEBERR, "Invalid line pointer.", "processFeaturesTag()");
+ msSetError(MS_WEBERR, "Invalid line pointer.", "processFeatureTag()");
return(MS_FAILURE);
- tagStart = findTag(*line, "features");
+ tagStart = findTag(*line, "feature");
if(!tagStart) return(MS_SUCCESS); /* OK, just return; */
/* check for any tag arguments */
- if(getTagArgs("features", tagStart, &tagArgs) != MS_SUCCESS) return(MS_FAILURE);
+ if(getTagArgs("feature", tagStart, &tagArgs) != MS_SUCCESS) return(MS_FAILURE);
if(tagArgs) {
/* todo */
- if(strstr(*line, "[/features]") == NULL) { /* we know the closing tag must be here, if not throw an error */
- msSetError(MS_WEBERR, "[features] tag found without closing [/features].", "processFeaturesTag()");
+ if(strstr(*line, "[/feature]") == NULL) { /* we know the closing tag must be here, if not throw an error */
+ msSetError(MS_WEBERR, "[feature] tag found without closing [/feature].", "processFeatureTag()");
return(MS_FAILURE);
- if(getInlineTag("features", *line, &tag) != MS_SUCCESS) {
- msSetError(MS_WEBERR, "Malformed features tag.", "processFeaturesTag()");
+ if(getInlineTag("feature", *line, &tag) != MS_SUCCESS) {
+ msSetError(MS_WEBERR, "Malformed feature tag.", "processFeatureTag()");
return MS_FAILURE;
- preTag = getPreTagText(*line, "[features");
- postTag = getPostTagText(*line, "[/featres]");
+ preTag = getPreTagText(*line, "[feature");
+ postTag = getPostTagText(*line, "[/feature]");
/* start rebuilding **line */
free(*line); *line = preTag;
More information about the mapserver-commits
