[mapserver-commits] r7574 - trunk/mapserver/mapscript/php3
Mon May 12 09:59:02 EDT 2008
Author: Assefa
Date: 2008-05-12 09:59:02 -0400 (Mon, 12 May 2008)
New Revision: 7574
   trunk/mapserver/mapscript/php3/README
   trunk/mapserver/mapscript/php3/mapscript_i.c
   trunk/mapserver/mapscript/php3/php_mapscript.c
   trunk/mapserver/mapscript/php3/php_mapscript.h
Add insertLayer function (#762)
Modified: trunk/mapserver/mapscript/php3/README
--- trunk/mapserver/mapscript/php3/README	2008-05-09 13:33:55 UTC (rev 7573)
+++ trunk/mapserver/mapscript/php3/README	2008-05-12 13:59:02 UTC (rev 7574)
@@ -576,6 +576,10 @@
     using the msIO services (ie. ms_ioinstallstdouttobuffer() and
     ms_iogetstdoutbufferstring())
+  int insertLayer( layerObj layer [, int nIndex=-1 ] )
+    Insert a copy of *layer* into the Map at index *nIndex*.  The default
+    value of *nIndex* is -1, which means the last possible index.  Returns
+    the index of the new Layer, or -1 in the case of a failure.
  LayerObj Class:
@@ -885,6 +889,7 @@
        Returns MS_TRUE/MS_FALSE depending on whether the layer is
        currently visible in the map (i.e. turned on, in scale, etc.).
  ClassObj Class:
Modified: trunk/mapserver/mapscript/php3/mapscript_i.c
--- trunk/mapserver/mapscript/php3/mapscript_i.c	2008-05-09 13:33:55 UTC (rev 7573)
+++ trunk/mapserver/mapscript/php3/mapscript_i.c	2008-05-12 13:59:02 UTC (rev 7574)
@@ -335,6 +335,14 @@
     return msOWSDispatch( self, req, TRUE);
+int mapObj_insertLayer(mapObj *self, layerObj *layer, int index)
+    if (self && layer)
+      return msInsertLayer(self, layer, index);
+    return -1;
  * class extensions for layerObj, always within the context of a map
Modified: trunk/mapserver/mapscript/php3/php_mapscript.c
--- trunk/mapserver/mapscript/php3/php_mapscript.c	2008-05-09 13:33:55 UTC (rev 7573)
+++ trunk/mapserver/mapscript/php3/php_mapscript.c	2008-05-12 13:59:02 UTC (rev 7574)
@@ -168,6 +168,8 @@
 DLEXPORT void php3_ms_map_loadOWSParameters(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_map_OWSDispatch(INTERNAL_FUNCTION_PARAMETERS);
+DLEXPORT void php3_ms_map_insertLayer(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_img_saveImage(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_img_saveWebImage(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_img_pasteImage(INTERNAL_FUNCTION_PARAMETERS);
@@ -696,6 +698,7 @@
     {"applyconfigoptions", php3_ms_map_applyConfigOptions,      NULL},
     {"loadowsparameters",  php3_ms_map_loadOWSParameters,       NULL},
     {"owsdispatch",     php3_ms_map_OWSDispatch,        NULL},
+    {"insertlayer",     php3_ms_map_insertLayer,        NULL},
     {NULL, NULL, NULL}
@@ -5986,10 +5989,75 @@
+ *                        map->insertLayer(layerobj)
+/* {{{ proto int map.insertLayer(layerObj layer, index)
+   Returns the index where the layer had been inserted*/
+  pval  *pLyrIndex, *pLyr, *pThis;
+  mapObj *self=NULL;
+  layerObj *poLayer=NULL;
+  int nLyrIndex = -1, iReturn=-1;
+  int nArgs;
+#ifdef PHP4
+    HashTable   *list=NULL;
+#endif
+    nArgs = ARG_COUNT(ht);
+#ifdef PHP4
+    pThis = getThis();
+#else
+    getThis(&pThis);
+#endif
+    if (pThis == NULL ||
+        (nArgs != 1 && nArgs != 2) ||
+        getParameters(ht, nArgs, &pLyr, &pLyrIndex) == FAILURE)
+        WRONG_PARAM_COUNT;
+    if (nArgs == 2)
+        convert_to_long(pLyrIndex);
+        nLyrIndex = pLyrIndex->value.lval;
+    self = (mapObj *)_phpms_fetch_handle(pThis, PHPMS_GLOBAL(le_msmap),
+                                         list TSRMLS_CC);
+    poLayer = (layerObj *)_phpms_fetch_handle(pLyr,
+                                              PHPMS_GLOBAL(le_mslayer),
+                                              list TSRMLS_CC);
+    if (self == NULL || poLayer == NULL ||
+        (iReturn =  mapObj_insertLayer(self, poLayer, nLyrIndex) ) < 0)
+        _phpms_report_mapserver_error(E_ERROR);
+    /* Update mapObj members */
+    _phpms_set_property_long(pThis, "numlayers",
+                             self->numlayers, E_ERROR TSRMLS_CC);
+    /* Return layer object */
+    RETURN_LONG(iReturn);
  *                 PHP function wrappers - image class
Modified: trunk/mapserver/mapscript/php3/php_mapscript.h
--- trunk/mapserver/mapscript/php3/php_mapscript.h	2008-05-09 13:33:55 UTC (rev 7573)
+++ trunk/mapserver/mapscript/php3/php_mapscript.h	2008-05-12 13:59:02 UTC (rev 7574)
@@ -126,6 +126,7 @@
 int             mapObj_loadOWSParameters(mapObj *self, cgiRequestObj *request,
                                           char *wmtver_string);
 int             mapObj_OWSDispatch(mapObj *self, cgiRequestObj *req );
+int             mapObj_insertLayer(mapObj *self, layerObj *layer, int index);
 layerObj       *layerObj_new(mapObj *map);
 void            layerObj_destroy(layerObj* self);
