[mapserver-commits] r7577 - trunk/mapserver
Mon May 12 12:32:28 EDT 2008
Author: tbonfort
Date: 2008-05-12 12:32:27 -0400 (Mon, 12 May 2008)
New Revision: 7577
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapagg.cpp
   trunk/mapserver/mapdraw.c
   trunk/mapserver/mapgraticule.c
   trunk/mapserver/mapimagemap.c
   trunk/mapserver/maplabel.c
   trunk/mapserver/maplegend.c
   trunk/mapserver/mapscale.c
   trunk/mapserver/mapserver.h
   trunk/mapserver/mapsvg.c
use an agg specific label size calculation function where possible (#2357)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-05-12 15:20:41 UTC (rev 7576)
+++ trunk/mapserver/HISTORY.TXT	2008-05-12 16:32:27 UTC (rev 7577)
@@ -12,6 +12,7 @@
 Current Version (5.1-dev, SVN trunk):
+- AGG: use an agg specific label size calculation function where possible (#2357)
 - mapogcsld.c: fetch TextSymbolizer/Label/ogc:PropertyName correctly (#2611)
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp	2008-05-12 15:20:41 UTC (rev 7576)
+++ trunk/mapserver/mapagg.cpp	2008-05-12 16:32:27 UTC (rev 7577)
@@ -1947,6 +1947,26 @@
+int msGetLabelSizeAGG(imageObj *img, char *string, labelObj *label, rectObj *rect, fontSetObj *fontset, double scalefactor, int adjustBaseline)
+    AGGMapserverRenderer* ren = getAGGRenderer(img);
+    int size;
+    size = MS_NINT(label->size*scalefactor);
+    size = MS_MAX(size, label->minsize);
+    size = MS_MIN(size, label->maxsize);
+    char * font = msLookupHashTable(&(fontset->fonts), label->font);
+    if(!font) {
+        msSetError(MS_TTFERR, "Requested font (%s) not found.", "msGetLabelSizeAGG()", label->font);
+        return MS_FAILURE;
+    if(ren->getLabelSize(string, font, label->size, rect) != MS_SUCCESS)
+    if(adjustBaseline) {
+        label->offsety += MS_NINT(((rect->miny+rect->maxy) + size) / 2);
+        label->offsetx += MS_NINT(rect->minx / 2);
+    return MS_SUCCESS;
 // Draw a label curved along a line
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c	2008-05-12 15:20:41 UTC (rev 7576)
+++ trunk/mapserver/mapdraw.c	2008-05-12 16:32:27 UTC (rev 7577)
@@ -1955,7 +1955,7 @@
     pointObj p;
     rectObj r;
-    if(msGetLabelSize(string, label, &r, fontset, scalefactor, MS_FALSE) == -1) return(-1);
+    if(msGetLabelSize(image,string, label, &r, fontset, scalefactor, MS_FALSE) == -1) return(-1);
     p = get_metrics(&labelPnt, label->position, r, label->offsetx, label->offsety, label->angle, 0, NULL);
     msDrawText(image, p, string, label, fontset, scalefactor); /* actually draw the label */
   } else {
@@ -2086,7 +2086,7 @@
                     if(!cachePtr->text || strlen(cachePtr->text) == 0)
                         continue; /* not an error, just don't want to do anything */
-                    if(msGetLabelSize(cachePtr->text, labelPtr, &r, &(map->fontset), layerPtr->scalefactor, MS_TRUE) == -1)
+                    if(msGetLabelSize(image,cachePtr->text, labelPtr, &r, &(map->fontset), layerPtr->scalefactor, MS_TRUE) == -1)
                         return(-1);
                     if(labelPtr->autominfeaturesize && ((r.maxx-r.minx) > cachePtr->featuresize))
Modified: trunk/mapserver/mapgraticule.c
--- trunk/mapserver/mapgraticule.c	2008-05-12 15:20:41 UTC (rev 7576)
+++ trunk/mapserver/mapgraticule.c	2008-05-12 16:32:27 UTC (rev 7577)
@@ -655,7 +655,7 @@
     if( pLayer->transform )
 		msTransformShapeToPixel( pShape, pLayer->map->extent, pLayer->map->cellsize );
-	if (msGetLabelSize( pShape->text, &pLayer->class[0]->label, &rectLabel, &pLayer->map->fontset, 1.0, MS_FALSE) != 0)
+	if (msGetLabelSizeGD( pShape->text, &pLayer->class[0]->label, &rectLabel, &pLayer->map->fontset, 1.0, MS_FALSE) != 0)
         return MS_FAILURE;  /* msSetError already called */
 	switch( ePosition )
Modified: trunk/mapserver/mapimagemap.c
--- trunk/mapserver/mapimagemap.c	2008-05-12 15:20:41 UTC (rev 7576)
+++ trunk/mapserver/mapimagemap.c	2008-05-12 16:32:27 UTC (rev 7577)
@@ -1850,7 +1850,7 @@
     if(cachePtr->label.type == MS_TRUETYPE)
       cachePtr->label.size = (int)(cachePtr->label.size*layerPtr->scalefactor);
+    if(msGetLabelSize(img,cachePtr->text, labelPtr, &r, &(map->fontset), layerPtr->scalefactor, MS_TRUE) == -1)
       return(-1);
Modified: trunk/mapserver/maplabel.c
--- trunk/mapserver/maplabel.c	2008-05-12 15:20:41 UTC (rev 7576)
+++ trunk/mapserver/maplabel.c	2008-05-12 16:32:27 UTC (rev 7577)
@@ -1,5 +1,5 @@
- * $Id:$
+ * $Id$
  * Project:  MapServer
  * Purpose:  Labeling Implementation.
@@ -396,6 +396,17 @@
 #endif
+int msGetLabelSize(imageObj *img, char *string, labelObj *label, rectObj *rect, fontSetObj *fontset, double scalefactor, int adjustBaseline)
+#ifdef USE_AGG
+    if(MS_RENDERER_AGG(img->format))
+        return msGetLabelSizeAGG(img,string,label,rect,fontset,scalefactor,adjustBaseline);
+    else
+#endif
+        return msGetLabelSizeGD(string,label,rect,fontset,scalefactor,adjustBaseline);
 ** Note: All these routines assume a reference point at the LL corner of the text. GD's
 ** bitmapped fonts use UL and this is compensated for. Note the rect is relative to the
@@ -403,7 +414,7 @@
 /* assumes an angle of 0 regardless of what's in the label object */
-int msGetLabelSize(char *string, labelObj *label, rectObj *rect, fontSetObj *fontset, double scalefactor, int adjustBaseline)
+int msGetLabelSizeGD(char *string, labelObj *label, rectObj *rect, fontSetObj *fontset, double scalefactor, int adjustBaseline)
   int size;
   if(label->type == MS_TRUETYPE) {
@@ -802,7 +813,7 @@
   label.outlinecolor = style->outlinecolor;
   label.antialias = symbol->antialias;
-  if(msGetLabelSize(symbol->character, &label, &label_rect, symbolset->fontset, scalefactor, MS_FALSE) == -1)
+  if(msGetLabelSizeGD(symbol->character, &label, &label_rect, symbolset->fontset, scalefactor, MS_FALSE) == -1)
     return(-1);
   label_width = (int) label_rect.maxx - (int) label_rect.minx;
Modified: trunk/mapserver/maplegend.c
--- trunk/mapserver/maplegend.c	2008-05-12 15:20:41 UTC (rev 7576)
+++ trunk/mapserver/maplegend.c	2008-05-12 16:32:27 UTC (rev 7577)
@@ -200,7 +200,7 @@
               transformedText = strdup(lp->class[j]->name);
             if (   transformedText == NULL
-                || msGetLabelSize(transformedText, &map->legend.label,
+                || msGetLabelSizeGD(transformedText, &map->legend.label,
                                   &rect, &(map->fontset), 1.0, MS_FALSE) != 0)
             { /* something bad happened */
                 if (transformedText)
@@ -309,7 +309,7 @@
             cur->pred=head;
             head=cur;
             if(cur->transformedText==NULL||
-                    msGetLabelSize(cur->transformedText, &map->legend.label, &rect, &(map->fontset), 1.0, MS_FALSE) != 0)
+                    msGetLabelSizeGD(cur->transformedText, &map->legend.label, &rect, &(map->fontset), 1.0, MS_FALSE) != 0)
             { /* something bad happened, free allocated mem */
                 while(cur) {
                     if(cur->transformedText!=cur->theclass->name)
Modified: trunk/mapserver/mapscale.c
--- trunk/mapserver/mapscale.c	2008-05-12 15:20:41 UTC (rev 7576)
+++ trunk/mapserver/mapscale.c	2008-05-12 16:32:27 UTC (rev 7577)
@@ -1,5 +1,5 @@
- * $Id:$
+ * $Id$
  * Purpose:  Scale object rendering.
@@ -310,7 +310,7 @@
       map->scalebar.label.position = MS_CC;
       p.x = ox + j*isx; /* + MS_NINT(fontPtr->w/2); */
       p.y = oy + map->scalebar.height + MS_NINT(VSPACING*fontPtr->h);
-      if(msGetLabelSize(label,&(map->scalebar.label), &r,
+      if(msGetLabelSizeGD(label,&(map->scalebar.label), &r,
               &(map->fontset), 1, MS_FALSE) == -1) return(NULL);
       p2 = get_metrics(&p, MS_CC, r, 0,0, 0, 0, NULL);
       msDrawTextGD(image->img.gd, p2, label, &(map->scalebar.label), &(map->fontset), 1.0);
@@ -323,7 +323,7 @@
     map->scalebar.label.position = MS_CR;
     p.x = ox; /* + MS_NINT(fontPtr->w/2); */
     p2 = get_metrics(&p, MS_CR, r, 0,0, 0, 0, NULL);
@@ -343,7 +343,7 @@
@@ -359,7 +359,7 @@
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2008-05-12 15:20:41 UTC (rev 7576)
+++ trunk/mapserver/mapserver.h	2008-05-12 16:32:27 UTC (rev 7577)
@@ -1680,7 +1680,9 @@
 MS_DLL_EXPORT int msInitFontSet(fontSetObj *fontset);
 MS_DLL_EXPORT int msFreeFontSet(fontSetObj *fontset);
 MS_DLL_EXPORT char *msTransformLabelText(labelObj *label, char *text);
-MS_DLL_EXPORT int msGetLabelSize(char *string, labelObj *label, rectObj *rect, fontSetObj *fontSet, double scalefactor, int adjustBaseline);
+MS_DLL_EXPORT int msGetLabelSize(imageObj *img, char *string, labelObj *label, rectObj *rect, fontSetObj *fontSet, double scalefactor, int adjustBaseline);
+MS_DLL_EXPORT int msGetLabelSizeGD(char *string, labelObj *label, rectObj *rect, fontSetObj *fontSet, double scalefactor, int adjustBaseline);
 MS_DLL_EXPORT int msGetLabelSizeEx(char *string, labelObj *label, rectObj *rect, fontSetObj *fontSet, double scalefactor, int adjustBaseline, double **offsets);
 MS_DLL_EXPORT int msAddLabel(mapObj *map, int layerindex, int classindex, int shapeindex, int tileindex, pointObj *point, labelPathObj *labelpath, char *string, double featuresize, labelObj *label);
 MS_DLL_EXPORT void msTestLabelCacheCollisions(labelCacheObj *labelcache, labelObj *labelPtr, int mapwidth, int mapheight, int buffer, labelCacheMemberObj *cachePtr, int current_priority, int current_label);
@@ -1926,6 +1928,7 @@
 MS_DLL_EXPORT void msDrawLineSymbolAGG(symbolSetObj *symbolset, imageObj *image, shapeObj *p, styleObj *style, double scalefactor);
 MS_DLL_EXPORT void msDrawShadeSymbolAGG(symbolSetObj *symbolset, imageObj *image,shapeObj *p, styleObj *style, double scalefactor);
+MS_DLL_EXPORT int msGetLabelSizeAGG(imageObj *img, char *string, labelObj *label, rectObj *rect, fontSetObj *fontSet, double scalefactor, int adjustBaseline);
 MS_DLL_EXPORT int msDrawTextAGG(imageObj *imgage, pointObj labelPnt, char *string, labelObj *label, fontSetObj *fontset, double scalefactor);
 MS_DLL_EXPORT int msDrawTextLineAGG(imageObj *image, char *string, labelObj *label, labelPathObj *labelpath, fontSetObj *fontset, double scalefactor);
Modified: trunk/mapserver/mapsvg.c
--- trunk/mapserver/mapsvg.c	2008-05-12 15:20:41 UTC (rev 7576)
+++ trunk/mapserver/mapsvg.c	2008-05-12 16:32:27 UTC (rev 7577)
@@ -1152,7 +1152,7 @@
+    if(msGetLabelSizeGD(cachePtr->text, labelPtr, &r, &(map->fontset), layerPtr->scalefactor, MS_TRUE) == -1)
       return(-1);
