[mapserver-commits] r7588 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue May 13 09:23:08 EDT 2008
Author: sdlime
Date: 2008-05-13 09:23:08 -0400 (Tue, 13 May 2008)
New Revision: 7588
trunk/mapserver/maptile.c
Missed some changes to mapservObj member names in maptile.c.
Modified: trunk/mapserver/maptile.c
--- trunk/mapserver/maptile.c 2008-05-13 13:21:18 UTC (rev 7587)
+++ trunk/mapserver/maptile.c 2008-05-13 13:23:08 UTC (rev 7588)
@@ -44,7 +44,7 @@
** Ensure all the LAYERs have a projection.
- if( msTileSetProjections(msObj->Map) != 0 ) {
+ if( msTileSetProjections(msObj->map) != 0 ) {
return(MS_FAILURE);
@@ -56,7 +56,7 @@
} else {
return(MS_FAILURE); /* Huh? No mode? */
- if( msLoadProjectionString(&(msObj->Map->projection), outProjStr) != 0 ) {
+ if( msLoadProjectionString(&(msObj->map->projection), outProjStr) != 0 ) {
msSetError(MS_CGIERR, "Unable to load projection string.", "msTileSetup()");
return(MS_FAILURE);
@@ -129,7 +129,7 @@
int msTileSetExtent(mapservObj* msObj) {
#ifdef USE_TILE_API
- mapObj *map = msObj->Map;
+ mapObj *map = msObj->map;
double dx, dy;
if( msObj->TileMode == TILE_GMAP ) {
More information about the mapserver-commits
