[mapserver-commits] r7606 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed May 21 01:00:07 EDT 2008
Author: sdlime
Date: 2008-05-21 01:00:07 -0400 (Wed, 21 May 2008)
New Revision: 7606
trunk/mapserver/mapgraticule.c
Cleaned up excessive tabs in mapgraticule.c that made it difficult to debug.
Modified: trunk/mapserver/mapgraticule.c
--- trunk/mapserver/mapgraticule.c 2008-05-21 03:43:49 UTC (rev 7605)
+++ trunk/mapserver/mapgraticule.c 2008-05-21 05:00:07 UTC (rev 7606)
@@ -37,18 +37,18 @@
typedef enum
- posBottom = 1,
- posTop,
- posLeft,
- posRight
+ posBottom = 1,
+ posTop,
+ posLeft,
+ posRight
} msGraticulePosition;
typedef enum
- lpDefault = 0,
- lpDDMMSS = 1,
- lpDDMM,
- lpDD
+ lpDefault = 0,
+ lpDDMMSS = 1,
+ lpDDMM,
+ lpDD
} msLabelProcessingType;
void DefineAxis( int iTickCountTarget, double *Min, double *Max, double *Inc );
@@ -57,11 +57,11 @@
int msGraticuleLayerInitItemInfo(layerObj *layer);
-#define MAPGRATICULE_ARC_SUBDIVISION_DEFAULT (256)
-#define MAPGRATICULE_ARC_MINIMUM (16)
-#define MAPGRATICULE_FORMAT_STRING_DEFAULT "%5.2g"
-#define MAPGRATICULE_FORMAT_STRING_DDMMSS "%3d %02d %02d"
-#define MAPGRATICULE_FORMAT_STRING_DDMM "%3d %02d"
+#define MAPGRATICULE_ARC_SUBDIVISION_DEFAULT (256)
+#define MAPGRATICULE_ARC_MINIMUM (16)
+#define MAPGRATICULE_FORMAT_STRING_DEFAULT "%5.2g"
+#define MAPGRATICULE_FORMAT_STRING_DDMMSS "%3d %02d %02d"
+#define MAPGRATICULE_FORMAT_STRING_DDMM "%3d %02d"
#define MAPGRATICULE_FORMAT_STRING_DD "%3d"
@@ -93,7 +93,7 @@
pInfo->labelformat = (char *) malloc( strlen( MAPGRATICULE_FORMAT_STRING_DDMMSS ) + 1 );
pInfo->ilabeltype = (int) lpDDMMSS;
strcpy( pInfo->labelformat, MAPGRATICULE_FORMAT_STRING_DDMMSS );
- } else if( strcmp( pInfo->labelformat, "DDMM" ) == 0 ) {
+ } else if( strcmp( pInfo->labelformat, "DDMM" ) == 0 ) {
pInfo->labelformat = (char *) malloc( strlen( MAPGRATICULE_FORMAT_STRING_DDMM ) + 1 );
pInfo->ilabeltype = (int) lpDDMM;
strcpy( pInfo->labelformat, MAPGRATICULE_FORMAT_STRING_DDMM );
@@ -111,9 +111,9 @@
int msGraticuleLayerIsOpen(layerObj *layer)
- if (layer->layerinfo)
+ if(layer->layerinfo)
return MS_TRUE;
return MS_FALSE;
@@ -129,7 +129,7 @@
free( pInfo->labelformat );
pInfo->labelformat = NULL;
if( pInfo->pboundingpoints ) {
free( pInfo->pboundingpoints );
pInfo->pboundingpoints = NULL;
@@ -148,135 +148,124 @@
int msGraticuleLayerWhichShapes(layerObj *layer, rectObj rect)
- graticuleObj *pInfo = (graticuleObj *) layer->layerinfo;
- int iAxisTickCount = 0;
- rectObj rectMapCoordinates;
+ graticuleObj *pInfo = (graticuleObj *) layer->layerinfo;
+ int iAxisTickCount = 0;
+ rectObj rectMapCoordinates;
- if ( msCheckParentPointer(layer->map,"map")==MS_FAILURE )
- return MS_FAILURE;
+ if(msCheckParentPointer(layer->map,"map") == MS_FAILURE)
+ return MS_FAILURE;
- pInfo->dstartlatitude = rect.miny;
- pInfo->dstartlongitude = rect.minx;
- pInfo->dendlatitude = rect.maxy;
- pInfo->dendlongitude = rect.maxx;
- pInfo->bvertical = 1;
- pInfo->extent = rect;
- if( pInfo->minincrement > 0.0 )
- pInfo->dincrementlongitude = pInfo->minincrement;
- pInfo->dincrementlatitude = pInfo->minincrement;
- else if( pInfo->maxincrement > 0.0 )
- pInfo->dincrementlongitude = pInfo->maxincrement;
- pInfo->dincrementlatitude = pInfo->maxincrement;
- else
- pInfo->dincrementlongitude = 0;
- pInfo->dincrementlatitude = 0;
- if( pInfo->maxarcs > 0 )
- iAxisTickCount = (int) pInfo->maxarcs;
- else if( pInfo->minarcs > 0 )
- iAxisTickCount = (int) pInfo->minarcs;
- DefineAxis( iAxisTickCount, &pInfo->dstartlongitude, &pInfo->dendlongitude, &pInfo->dincrementlongitude );
- DefineAxis( iAxisTickCount, &pInfo->dstartlatitude, &pInfo->dendlatitude, &pInfo->dincrementlatitude );
+ pInfo->dstartlatitude = rect.miny;
+ pInfo->dstartlongitude = rect.minx;
+ pInfo->dendlatitude = rect.maxy;
+ pInfo->dendlongitude = rect.maxx;
+ pInfo->bvertical = 1;
+ pInfo->extent = rect;
- pInfo->dwhichlatitude = pInfo->dstartlatitude;
- pInfo->dwhichlongitude = pInfo->dstartlongitude;
+ if( pInfo->minincrement > 0.0 ) {
+ pInfo->dincrementlongitude = pInfo->minincrement;
+ pInfo->dincrementlatitude = pInfo->minincrement;
+ } else if( pInfo->maxincrement > 0.0 ) {
+ pInfo->dincrementlongitude = pInfo->maxincrement;
+ pInfo->dincrementlatitude = pInfo->maxincrement;
+ } else {
+ pInfo->dincrementlongitude = 0;
+ pInfo->dincrementlatitude = 0;
+ if( pInfo->maxarcs > 0 )
+ iAxisTickCount = (int) pInfo->maxarcs;
+ else if( pInfo->minarcs > 0 )
+ iAxisTickCount = (int) pInfo->minarcs;
- && pInfo->maxincrement > 0.0
- && pInfo->minincrement == pInfo->maxincrement )
- else if( pInfo->minincrement > 0.0 )
- * If using PROJ, project rect back into map system, and generate rect corner points in native system.
- * These lines will be used when generating labels to get correct placement at arc/rect edge intersections.
- rectMapCoordinates = layer->map->extent;
- pInfo->pboundinglines = (lineObj *) malloc( sizeof( lineObj ) * 4 );
- pInfo->pboundingpoints = (pointObj *) malloc( sizeof( pointObj ) * 8 );
- * top
- pInfo->pboundinglines[0].numpoints = 2;
- pInfo->pboundinglines[0].point = &pInfo->pboundingpoints[0];
- pInfo->pboundinglines[0].point[0].x = rectMapCoordinates.minx;
- pInfo->pboundinglines[0].point[0].y = rectMapCoordinates.maxy;
- pInfo->pboundinglines[0].point[1].x = rectMapCoordinates.maxx;
- pInfo->pboundinglines[0].point[1].y = rectMapCoordinates.maxy;
+ DefineAxis( iAxisTickCount, &pInfo->dstartlongitude, &pInfo->dendlongitude, &pInfo->dincrementlongitude);
+ DefineAxis( iAxisTickCount, &pInfo->dstartlatitude, &pInfo->dendlatitude, &pInfo->dincrementlatitude);
+ pInfo->dwhichlatitude = pInfo->dstartlatitude;
+ pInfo->dwhichlongitude = pInfo->dstartlongitude;
+ if( pInfo->minincrement > 0.0 && pInfo->maxincrement > 0.0 && pInfo->minincrement == pInfo->maxincrement ) {
+ } else if( pInfo->minincrement > 0.0 ) {
+ * If using PROJ, project rect back into map system, and generate rect corner points in native system.
+ * These lines will be used when generating labels to get correct placement at arc/rect edge intersections.
+ rectMapCoordinates = layer->map->extent;
+ pInfo->pboundinglines = (lineObj *) malloc( sizeof( lineObj ) * 4 );
+ pInfo->pboundingpoints = (pointObj *) malloc( sizeof( pointObj ) * 8 );
+ * top
+ pInfo->pboundinglines[0].numpoints = 2;
+ pInfo->pboundinglines[0].point = &pInfo->pboundingpoints[0];
+ pInfo->pboundinglines[0].point[0].x = rectMapCoordinates.minx;
+ pInfo->pboundinglines[0].point[0].y = rectMapCoordinates.maxy;
+ pInfo->pboundinglines[0].point[1].x = rectMapCoordinates.maxx;
+ pInfo->pboundinglines[0].point[1].y = rectMapCoordinates.maxy;
#ifdef USE_PROJ
- if( layer->map->projection.numargs > 0
- && layer->projection.numargs > 0 )
- msProjectLine( &layer->map->projection, &layer->projection, &pInfo->pboundinglines[0] );
+ if( layer->map->projection.numargs > 0 && layer->projection.numargs > 0 )
+ msProjectLine( &layer->map->projection, &layer->projection, &pInfo->pboundinglines[0] );
#endif
- * bottom
- pInfo->pboundinglines[1].numpoints = 2;
- pInfo->pboundinglines[1].point = &pInfo->pboundingpoints[2];
- pInfo->pboundinglines[1].point[0].x = rectMapCoordinates.minx;
- pInfo->pboundinglines[1].point[0].y = rectMapCoordinates.miny;
- pInfo->pboundinglines[1].point[1].x = rectMapCoordinates.maxx;
- pInfo->pboundinglines[1].point[1].y = rectMapCoordinates.miny;
+ * bottom
+ pInfo->pboundinglines[1].numpoints = 2;
+ pInfo->pboundinglines[1].point = &pInfo->pboundingpoints[2];
+ pInfo->pboundinglines[1].point[0].x = rectMapCoordinates.minx;
+ pInfo->pboundinglines[1].point[0].y = rectMapCoordinates.miny;
+ pInfo->pboundinglines[1].point[1].x = rectMapCoordinates.maxx;
+ pInfo->pboundinglines[1].point[1].y = rectMapCoordinates.miny;
#ifdef USE_PROJ
- msProjectLine( &layer->map->projection, &layer->projection, &pInfo->pboundinglines[1] );
+ msProjectLine( &layer->map->projection, &layer->projection, &pInfo->pboundinglines[1] );
#endif
- * left
- pInfo->pboundinglines[2].numpoints = 2;
- pInfo->pboundinglines[2].point = &pInfo->pboundingpoints[4];
- pInfo->pboundinglines[2].point[0].x = rectMapCoordinates.minx;
- pInfo->pboundinglines[2].point[0].y = rectMapCoordinates.miny;
- pInfo->pboundinglines[2].point[1].x = rectMapCoordinates.minx;
- pInfo->pboundinglines[2].point[1].y = rectMapCoordinates.maxy;
+ * left
+ pInfo->pboundinglines[2].numpoints = 2;
+ pInfo->pboundinglines[2].point = &pInfo->pboundingpoints[4];
+ pInfo->pboundinglines[2].point[0].x = rectMapCoordinates.minx;
+ pInfo->pboundinglines[2].point[0].y = rectMapCoordinates.miny;
+ pInfo->pboundinglines[2].point[1].x = rectMapCoordinates.minx;
+ pInfo->pboundinglines[2].point[1].y = rectMapCoordinates.maxy;
#ifdef USE_PROJ
- msProjectLine( &layer->map->projection, &layer->projection, &pInfo->pboundinglines[2] );
+ msProjectLine( &layer->map->projection, &layer->projection, &pInfo->pboundinglines[2] );
#endif
- * right
- pInfo->pboundinglines[3].numpoints = 2;
- pInfo->pboundinglines[3].point = &pInfo->pboundingpoints[6];
- pInfo->pboundinglines[3].point[0].x = rectMapCoordinates.maxx;
- pInfo->pboundinglines[3].point[0].y = rectMapCoordinates.miny;
- pInfo->pboundinglines[3].point[1].x = rectMapCoordinates.maxx;
- pInfo->pboundinglines[3].point[1].y = rectMapCoordinates.maxy;
+ * right
+ pInfo->pboundinglines[3].numpoints = 2;
+ pInfo->pboundinglines[3].point = &pInfo->pboundingpoints[6];
+ pInfo->pboundinglines[3].point[0].x = rectMapCoordinates.maxx;
+ pInfo->pboundinglines[3].point[0].y = rectMapCoordinates.miny;
+ pInfo->pboundinglines[3].point[1].x = rectMapCoordinates.maxx;
+ pInfo->pboundinglines[3].point[1].y = rectMapCoordinates.maxy;
#ifdef USE_PROJ
- msProjectLine( &layer->map->projection, &layer->projection, &pInfo->pboundinglines[3] );
+ msProjectLine( &layer->map->projection, &layer->projection, &pInfo->pboundinglines[3] );
#endif
- return MS_SUCCESS;
+ return MS_SUCCESS;
@@ -284,210 +273,193 @@
int msGraticuleLayerNextShape(layerObj *layer, shapeObj *shape)
- if( pInfo->minsubdivides <= 0.0
- || pInfo->maxsubdivides <= 0.0 )
- pInfo->minsubdivides =
- pInfo->maxsubdivides = MAPGRATICULE_ARC_SUBDIVISION_DEFAULT;
+ if( pInfo->minsubdivides <= 0.0 || pInfo->maxsubdivides <= 0.0 )
+ pInfo->minsubdivides = pInfo->maxsubdivides = MAPGRATICULE_ARC_SUBDIVISION_DEFAULT;
- shape->numlines = 1;
- shape->type = MS_SHAPE_LINE;
- shape->line = (lineObj *) malloc( sizeof( lineObj ) );
+ shape->numlines = 1;
+ shape->type = MS_SHAPE_LINE;
+ shape->line = (lineObj *) malloc(sizeof( lineObj ));
+ shape->line->numpoints = (int) pInfo->maxsubdivides;
- shape->line->numpoints = (int) pInfo->maxsubdivides;
- * Subdivide and draw current arc, rendering the arc labels first
- if( pInfo->bvertical )
- int iPointIndex;
- double dArcDelta = (pInfo->dendlatitude - pInfo->dstartlatitude) / (double) shape->line->numpoints;
- double dArcPosition = pInfo->dstartlatitude + dArcDelta;
- double dStartY, dDeltaX;
- switch( pInfo->ilabelstate )
- case 0:
- if( ! pInfo->blabelaxes ) /* Bottom */
- pInfo->ilabelstate++;
- shape->numlines = 0;
+ * Subdivide and draw current arc, rendering the arc labels first
+ if( pInfo->bvertical ) {
+ int iPointIndex;
+ double dArcDelta = (pInfo->dendlatitude - pInfo->dstartlatitude) / (double) shape->line->numpoints;
+ double dArcPosition = pInfo->dstartlatitude + dArcDelta;
+ double dStartY, dDeltaX;
+ switch( pInfo->ilabelstate ) {
+ case 0:
+ if(!pInfo->blabelaxes) { /* Bottom */
+ pInfo->ilabelstate++;
+ shape->numlines = 0;
- dDeltaX = (pInfo->dwhichlongitude - pInfo->pboundinglines[1].point[0].x) / (pInfo->pboundinglines[1].point[1].x - pInfo->pboundinglines[1].point[0].x );
- dStartY = (pInfo->pboundinglines[1].point[1].y - pInfo->pboundinglines[1].point[0].y) * dDeltaX + pInfo->pboundinglines[1].point[0].y;
- shape->line->numpoints = (int) 2;
- shape->line->point = (pointObj *) malloc( sizeof( pointObj ) * 2 );
- shape->line->point[0].x = pInfo->dwhichlongitude;
- shape->line->point[0].y = dStartY;
- shape->line->point[1].x = pInfo->dwhichlongitude;
- shape->line->point[1].y = dStartY + dArcDelta;
+ dDeltaX = (pInfo->dwhichlongitude - pInfo->pboundinglines[1].point[0].x) / (pInfo->pboundinglines[1].point[1].x - pInfo->pboundinglines[1].point[0].x);
+ dStartY = (pInfo->pboundinglines[1].point[1].y - pInfo->pboundinglines[1].point[0].y) * dDeltaX + pInfo->pboundinglines[1].point[0].y;
+ shape->line->numpoints = (int) 2;
+ shape->line->point = (pointObj *) malloc( sizeof( pointObj ) * 2 );
+ shape->line->point[0].x = pInfo->dwhichlongitude;
+ shape->line->point[0].y = dStartY;
+ shape->line->point[1].x = pInfo->dwhichlongitude;
+ shape->line->point[1].y = dStartY + dArcDelta;
- _FormatLabel( layer, shape, shape->line->point[0].x );
- if (_AdjustLabelPosition( layer, shape, posBottom ) != MS_SUCCESS)
+ _FormatLabel( layer, shape, shape->line->point[0].x );
+ if(_AdjustLabelPosition( layer, shape, posBottom ) != MS_SUCCESS)
- case 1:
- if( ! pInfo->blabelaxes ) /* Top */
+ case 1:
+ if(!pInfo->blabelaxes) { /* Top */
- dDeltaX = (pInfo->dwhichlongitude - pInfo->pboundinglines[0].point[0].x) / (pInfo->pboundinglines[0].point[1].x - pInfo->pboundinglines[0].point[0].x );
- dStartY = (pInfo->pboundinglines[0].point[1].y - pInfo->pboundinglines[0].point[0].y) * dDeltaX + pInfo->pboundinglines[0].point[1].y;
+ dDeltaX = (pInfo->dwhichlongitude - pInfo->pboundinglines[0].point[0].x) / (pInfo->pboundinglines[0].point[1].x - pInfo->pboundinglines[0].point[0].x );
+ dStartY = (pInfo->pboundinglines[0].point[1].y - pInfo->pboundinglines[0].point[0].y) * dDeltaX + pInfo->pboundinglines[0].point[1].y;
- shape->line->point[0].y = dStartY - dArcDelta;
- shape->line->point[1].y = dStartY;
+ shape->line->point[0].y = dStartY - dArcDelta;
+ shape->line->point[1].y = dStartY;
- if (_AdjustLabelPosition( layer, shape, posTop ) != MS_SUCCESS)
+ if(_AdjustLabelPosition( layer, shape, posTop ) != MS_SUCCESS)
- case 2:
- shape->line->numpoints = (int) shape->line->numpoints + 1;
- shape->line->point = (pointObj *) malloc( sizeof( pointObj ) * shape->line->numpoints );
+ case 2:
+ shape->line->numpoints = (int) shape->line->numpoints + 1;
+ shape->line->point = (pointObj *) malloc( sizeof( pointObj ) * shape->line->numpoints );
- shape->line->point[0].y = pInfo->dstartlatitude;
+ shape->line->point[0].y = pInfo->dstartlatitude;
- for( iPointIndex = 1; iPointIndex < shape->line->numpoints; iPointIndex++ )
- shape->line->point[iPointIndex].x = pInfo->dwhichlongitude;
- shape->line->point[iPointIndex].y = dArcPosition;
- dArcPosition += dArcDelta;
- pInfo->ilabelstate = 0;
- break;
+ for( iPointIndex = 1; iPointIndex < shape->line->numpoints; iPointIndex++ ) {
+ shape->line->point[iPointIndex].x = pInfo->dwhichlongitude;
+ shape->line->point[iPointIndex].y = dArcPosition;
+ dArcPosition += dArcDelta;
+ pInfo->ilabelstate = 0;
+ break;
- default:
- break;
- else
- int iPointIndex;
- double dArcDelta = (pInfo->dendlongitude - pInfo->dstartlongitude) / (double) shape->line->numpoints;
- double dArcPosition = pInfo->dstartlongitude + dArcDelta;
- double dStartX, dDeltaY;
+ default:
+ break;
+ } else {
+ int iPointIndex;
+ double dArcDelta = (pInfo->dendlongitude - pInfo->dstartlongitude) / (double) shape->line->numpoints;
+ double dArcPosition = pInfo->dstartlongitude + dArcDelta;
+ double dStartX, dDeltaY;
- case 0:
- if( ! pInfo->blabelaxes ) /* Left side */
+ case 0:
+ if(!pInfo->blabelaxes) { /* Left side */
- dDeltaY = (pInfo->dwhichlatitude - pInfo->pboundinglines[2].point[0].y) / (pInfo->pboundinglines[2].point[1].y - pInfo->pboundinglines[2].point[0].y );
- dStartX = (pInfo->pboundinglines[2].point[1].x - pInfo->pboundinglines[2].point[0].x) * dDeltaY + pInfo->pboundinglines[2].point[0].x;
- shape->line->point[0].x = dStartX;
- shape->line->point[0].y = pInfo->dwhichlatitude;
- shape->line->point[1].x = dStartX + dArcDelta;
- shape->line->point[1].y = pInfo->dwhichlatitude;
+ dDeltaY = (pInfo->dwhichlatitude - pInfo->pboundinglines[2].point[0].y) / (pInfo->pboundinglines[2].point[1].y - pInfo->pboundinglines[2].point[0].y );
+ dStartX = (pInfo->pboundinglines[2].point[1].x - pInfo->pboundinglines[2].point[0].x) * dDeltaY + pInfo->pboundinglines[2].point[0].x;
+ shape->line->point[0].x = dStartX;
+ shape->line->point[0].y = pInfo->dwhichlatitude;
+ shape->line->point[1].x = dStartX + dArcDelta;
+ shape->line->point[1].y = pInfo->dwhichlatitude;
- _FormatLabel( layer, shape, shape->line->point[0].y );
- if (_AdjustLabelPosition( layer, shape, posLeft ) != MS_SUCCESS)
+ _FormatLabel( layer, shape, shape->line->point[0].y );
+ if(_AdjustLabelPosition( layer, shape, posLeft ) != MS_SUCCESS)
- case 1:
- if( ! pInfo->blabelaxes ) /* Right side */
+ case 1:
+ if(!pInfo->blabelaxes) { /* Right side */
- dDeltaY = (pInfo->dwhichlatitude - pInfo->pboundinglines[3].point[0].y) / (pInfo->pboundinglines[3].point[1].y - pInfo->pboundinglines[3].point[0].y );
- dStartX = (pInfo->pboundinglines[3].point[1].x - pInfo->pboundinglines[3].point[0].x) * dDeltaY + pInfo->pboundinglines[3].point[0].x;
+ dDeltaY = (pInfo->dwhichlatitude - pInfo->pboundinglines[3].point[0].y) / (pInfo->pboundinglines[3].point[1].y - pInfo->pboundinglines[3].point[0].y );
+ dStartX = (pInfo->pboundinglines[3].point[1].x - pInfo->pboundinglines[3].point[0].x) * dDeltaY + pInfo->pboundinglines[3].point[0].x;
- shape->line->point[0].x = dStartX - dArcDelta;
- shape->line->point[1].x = dStartX;
+ shape->line->point[0].x = dStartX - dArcDelta;
+ shape->line->point[1].x = dStartX;
- if (_AdjustLabelPosition( layer, shape, posRight ) != MS_SUCCESS)
+ if(_AdjustLabelPosition( layer, shape, posRight ) != MS_SUCCESS)
- case 2:
+ case 2:
- shape->line->point[0].x = pInfo->dstartlongitude;
+ shape->line->point[0].x = pInfo->dstartlongitude;
- shape->line->point[iPointIndex].x = dArcPosition;
- shape->line->point[iPointIndex].y = pInfo->dwhichlatitude;
- break;
+ for(iPointIndex = 1; iPointIndex < shape->line->numpoints; iPointIndex++) {
+ shape->line->point[iPointIndex].x = dArcPosition;
+ shape->line->point[iPointIndex].y = pInfo->dwhichlatitude;
+ break;
- default:
- break;
- * Increment and move to next arc
- pInfo->dwhichlatitude += pInfo->dincrementlatitude;
+ default:
+ break;
- if( pInfo->dwhichlatitude > pInfo->dendlatitude )
- pInfo->dwhichlongitude += pInfo->dincrementlongitude;
+ * Increment and move to next arc
+ pInfo->dwhichlatitude += pInfo->dincrementlatitude;
- if( pInfo->dwhichlongitude > pInfo->dendlongitude
- && pInfo->bvertical == 0 )
- return MS_DONE;
- else if( pInfo->dwhichlongitude > pInfo->dendlongitude )
- pInfo->bvertical = 0;
+ if(pInfo->dwhichlatitude > pInfo->dendlatitude) {
+ pInfo->dwhichlongitude += pInfo->dincrementlongitude;
+ if( pInfo->dwhichlongitude > pInfo->dendlongitude && pInfo->bvertical == 0 )
+ return MS_DONE;
+ else if( pInfo->dwhichlongitude > pInfo->dendlongitude ) {
+ pInfo->bvertical = 0;
@@ -495,8 +467,8 @@
int msGraticuleLayerGetItems(layerObj *layer)
- msGraticuleLayerInitItemInfo(layer);
+ msGraticuleLayerInitItemInfo(layer);
@@ -504,15 +476,15 @@
- char **ppItemName = (char **) malloc( sizeof( char * ) );
+ char **ppItemName = (char **) malloc( sizeof( char * ) );
- *ppItemName = (char *) malloc( 64 );
- strcpy( *ppItemName, "Graticule" );
- layer->numitems = 1;
- layer->items = ppItemName;
+ *ppItemName = (char *) malloc( 64 );
+ strcpy( *ppItemName, "Graticule" );
+ layer->numitems = 1;
+ layer->items = ppItemName;
@@ -520,12 +492,11 @@
void msGraticuleLayerFreeItemInfo(layerObj *layer)
- if( layer->items )
- free( *((char **) layer->items) );
- free( ((char **) layer->items) );
- return;
+ if(layer->items) {
+ free( *((char **) layer->items) );
+ free( ((char **) layer->items) );
+ return;
@@ -533,7 +504,7 @@
int msGraticuleLayerGetShape(layerObj *layer, shapeObj *shape, int tile, long record)
- return 0;
+ return 0;
@@ -541,16 +512,14 @@
int msGraticuleLayerGetExtent(layerObj *layer, rectObj *extent)
- if( pInfo )
- *extent = pInfo->extent;
+ if(pInfo) {
+ *extent = pInfo->extent;
@@ -558,38 +527,37 @@
int msGraticuleLayerGetAutoStyle(mapObj *map, layerObj *layer, classObj *c, int tile, long record)
-int
-msGraticuleLayerInitializeVirtualTable(layerObj *layer)
+int msGraticuleLayerInitializeVirtualTable(layerObj *layer)
- assert(layer != NULL);
- assert(layer->vtable != NULL);
+ assert(layer != NULL);
+ assert(layer->vtable != NULL);
- layer->vtable->LayerInitItemInfo = msGraticuleLayerInitItemInfo;
- layer->vtable->LayerFreeItemInfo = msGraticuleLayerFreeItemInfo;
- layer->vtable->LayerOpen = msGraticuleLayerOpen;
- layer->vtable->LayerIsOpen = msGraticuleLayerIsOpen;
- layer->vtable->LayerWhichShapes = msGraticuleLayerWhichShapes;
- layer->vtable->LayerNextShape = msGraticuleLayerNextShape;
- layer->vtable->LayerGetShape = msGraticuleLayerGetShape;
+ layer->vtable->LayerInitItemInfo = msGraticuleLayerInitItemInfo;
+ layer->vtable->LayerFreeItemInfo = msGraticuleLayerFreeItemInfo;
+ layer->vtable->LayerOpen = msGraticuleLayerOpen;
+ layer->vtable->LayerIsOpen = msGraticuleLayerIsOpen;
+ layer->vtable->LayerWhichShapes = msGraticuleLayerWhichShapes;
+ layer->vtable->LayerNextShape = msGraticuleLayerNextShape;
+ layer->vtable->LayerGetShape = msGraticuleLayerGetShape;
- layer->vtable->LayerClose = msGraticuleLayerClose;
- layer->vtable->LayerGetItems = msGraticuleLayerGetItems;
- layer->vtable->LayerGetExtent = msGraticuleLayerGetExtent;
- layer->vtable->LayerGetAutoStyle = msGraticuleLayerGetAutoStyle;
+ layer->vtable->LayerClose = msGraticuleLayerClose;
+ layer->vtable->LayerGetItems = msGraticuleLayerGetItems;
+ layer->vtable->LayerGetExtent = msGraticuleLayerGetExtent;
+ layer->vtable->LayerGetAutoStyle = msGraticuleLayerGetAutoStyle;
- /* layer->vtable->LayerCloseConnection, use default */;
- layer->vtable->LayerSetTimeFilter = msLayerMakePlainTimeFilter;
- /* layer->vtable->LayerApplyFilterToLayer, use default */
- /* layer->vtable->LayerCreateItems, use default */
- /* layer->vtable->LayerGetNumFeatures, use default */
+ /* layer->vtable->LayerCloseConnection, use default */;
+ layer->vtable->LayerSetTimeFilter = msLayerMakePlainTimeFilter;
+ /* layer->vtable->LayerApplyFilterToLayer, use default */
+ /* layer->vtable->LayerCreateItems, use default */
+ /* layer->vtable->LayerGetNumFeatures, use default */
@@ -600,7 +568,7 @@
graticuleObj *pInfo = (graticuleObj *) pLayer->layerinfo;
char cBuffer[32];
int iDegrees, iMinutes;
switch( pInfo->ilabeltype ) {
case lpDDMMSS:
iDegrees = (int) dDataToFormat;
@@ -622,7 +590,7 @@
default:
sprintf( cBuffer, pInfo->labelformat, dDataToFormat );
pShape->text = strdup( cBuffer );
@@ -632,80 +600,72 @@
static int _AdjustLabelPosition( layerObj *pLayer, shapeObj *pShape, msGraticulePosition ePosition )
- graticuleObj *pInfo = (graticuleObj *) pLayer->layerinfo;
- rectObj rectLabel;
- pointObj ptPoint;
+ graticuleObj *pInfo = (graticuleObj *) pLayer->layerinfo;
+ rectObj rectLabel;
+ pointObj ptPoint;
- if( pInfo == NULL || pShape == NULL )
- msSetError(MS_MISCERR, "Assertion failed: Null shape or layerinfo!, ", "_AdjustLabelPosition()");
- if ( msCheckParentPointer(pLayer->map,"map")==MS_FAILURE )
- ptPoint = pShape->line->point[0];
+ if( pInfo == NULL || pShape == NULL ) {
+ msSetError(MS_MISCERR, "Assertion failed: Null shape or layerinfo!, ", "_AdjustLabelPosition()");
+ if(msCheckParentPointer(pLayer->map,"map")==MS_FAILURE)
+ ptPoint = pShape->line->point[0];
#ifdef USE_PROJ
- if( pLayer->project
- && msProjectionsDiffer( &pLayer->projection, &pLayer->map->projection ) )
- msProjectShape( &pLayer->projection, &pLayer->map->projection, pShape );
+ if(pLayer->project && msProjectionsDiffer( &pLayer->projection, &pLayer->map->projection ))
+ msProjectShape( &pLayer->projection, &pLayer->map->projection, pShape );
#endif
- if( pLayer->transform )
- msTransformShapeToPixel( pShape, pLayer->map->extent, pLayer->map->cellsize );
+ if(pLayer->transform)
+ msTransformShapeToPixel(pShape, pLayer->map->extent, pLayer->map->cellsize);
- if (msGetLabelSizeGD( pShape->text, &pLayer->class[0]->label, &rectLabel, &pLayer->map->fontset, 1.0, MS_FALSE) != 0)
- return MS_FAILURE; /* msSetError already called */
+ if(msGetLabelSizeGD( pShape->text, &pLayer->class[0]->label, &rectLabel, &pLayer->map->fontset, 1.0, MS_FALSE) != 0)
+ return MS_FAILURE; /* msSetError already called */
- switch( ePosition )
- case posBottom:
- pShape->line->point[1].y = pLayer->map->height;
- pShape->line->point[0].y = pLayer->map->height - (fabs(rectLabel.maxy - rectLabel.miny) * 2 + 5);
- break;
+ switch( ePosition ) {
+ case posBottom:
+ pShape->line->point[1].y = pLayer->map->height;
+ pShape->line->point[0].y = pLayer->map->height - (fabs(rectLabel.maxy - rectLabel.miny) * 2 + 5);
+ break;
+ case posTop:
+ pShape->line->point[1].y = 0;
+ pShape->line->point[0].y = fabs(rectLabel.maxy - rectLabel.miny) * 2 + 5;
+ break;
+ case posLeft:
+ pShape->line->point[1].x = 0;
+ pShape->line->point[0].x = fabs(rectLabel.maxx - rectLabel.minx) * 2 + 5;
+ break;
+ case posRight:
+ pShape->line->point[1].x = pLayer->map->width;
+ pShape->line->point[0].x = pLayer->map->width - (fabs(rectLabel.maxx - rectLabel.minx) * 2 + 5);
+ break;
- case posTop:
- pShape->line->point[1].y = 0;
- pShape->line->point[0].y = fabs(rectLabel.maxy - rectLabel.miny) * 2 + 5;
- break;
- case posLeft:
- pShape->line->point[1].x = 0;
- pShape->line->point[0].x = fabs(rectLabel.maxx - rectLabel.minx) * 2 + 5;
- break;
- case posRight:
- pShape->line->point[1].x = pLayer->map->width;
- pShape->line->point[0].x = pLayer->map->width - (fabs(rectLabel.maxx - rectLabel.minx) * 2 + 5);
- break;
- msTransformPixelToShape( pShape, pLayer->map->extent, pLayer->map->cellsize );
+ msTransformPixelToShape( pShape, pLayer->map->extent, pLayer->map->cellsize );
#ifdef USE_PROJ
- && msProjectionsDiffer( &pLayer->map->projection, &pLayer->projection ) )
- msProjectShape( &pLayer->map->projection, &pLayer->projection, pShape );
+ if(pLayer->project && msProjectionsDiffer( &pLayer->map->projection, &pLayer->projection ))
+ msProjectShape( &pLayer->map->projection, &pLayer->projection, pShape );
#endif
- case posBottom:
- case posTop:
- pShape->line->point[1].x = ptPoint.x;
- pShape->line->point[0].x = ptPoint.x;
- break;
+ case posBottom:
+ case posTop:
+ pShape->line->point[1].x = ptPoint.x;
+ pShape->line->point[0].x = ptPoint.x;
+ break;
+ case posLeft:
+ case posRight:
+ pShape->line->point[1].y = ptPoint.y;
+ pShape->line->point[0].y = ptPoint.y;
+ break;
- case posLeft:
- case posRight:
- pShape->line->point[1].y = ptPoint.y;
- pShape->line->point[0].y = ptPoint.y;
- break;
@@ -719,90 +679,81 @@
- /* define local variables... */
+ /* define local variables... */
- double Test_inc, /* candidate increment value */
- Test_min, /* minimum scale value */
- Test_max, /* maximum scale value */
- Range = *Max - *Min ; /* range of data */
+ double Test_inc, /* candidate increment value */
+ Test_min, /* minimum scale value */
+ Test_max, /* maximum scale value */
+ Range = *Max - *Min ; /* range of data */
- int i = 0 ; /* counter */
+ int i = 0 ; /* counter */
- /* don't create problems -- solve them */
+ /* don't create problems -- solve them */
- if( Range < 0 )
- *Inc = 0 ;
- return ;
+ if( Range < 0 ) {
+ *Inc = 0 ;
+ return ;
- /* handle special case of repeated values */
+ /* handle special case of repeated values */
- else if( Range == 0)
- *Min = ceil(*Max) - 1 ;
- *Max = *Min + 1 ;
- *Inc = 1 ;
- return ;
+ else if( Range == 0) {
+ *Min = ceil(*Max) - 1 ;
+ *Max = *Min + 1 ;
+ *Inc = 1 ;
+ return ;
- /* compute candidate for increment */
+ /* compute candidate for increment */
+ Test_inc = pow( 10.0, ceil( log10( Range/10 ) ) ) ;
+ if(*Inc > 0 && ( Test_inc < *Inc || Test_inc > *Inc ))
+ Test_inc = *Inc;
- Test_inc = pow( 10.0, ceil( log10( Range/10 ) ) ) ;
- if( *Inc > 0 && ( Test_inc < *Inc || Test_inc > *Inc ) )
- Test_inc=*Inc;
+ /* establish maximum scale value... */
+ Test_max = ( (long)(*Max / Test_inc)) * Test_inc ;
- /* establish maximum scale value... */
+ if( Test_max < *Max )
+ Test_max += Test_inc ;
- Test_max = ( (long)(*Max / Test_inc)) * Test_inc ;
+ /* establish minimum scale value... */
+ Test_min = Test_max ;
+ do {
+ ++i ;
+ Test_min -= Test_inc ;
+ } while( Test_min > *Min ) ;
- if( Test_max < *Max )
- Test_max += Test_inc ;
- /* establish minimum scale value... */
+ /* subtracting small values can screw up the scale limits, */
+ /* eg: if DefineAxis is called with (min,max)=(0.01, 0.1), */
+ /* then the calculated scale is 1.0408E17 TO 0.05 BY 0.01. */
+ /* the following if statment corrects for this... */
- Test_min = Test_max ;
+ /* if(fabs(Test_min) < 1E-10) */
+ /* Test_min = 0 ; */
- do
- ++i ;
- Test_min -= Test_inc ;
- while( Test_min > *Min ) ;
+ /* adjust for too few tick marks */
- /* subtracting small values can screw up the scale limits, */
- /* eg: if DefineAxis is called with (min,max)=(0.01, 0.1), */
- /* then the calculated scale is 1.0408E17 TO 0.05 BY 0.01. */
- /* the following if statment corrects for this... */
+ if(iTickCountTarget <= 0)
+ iTickCountTarget = MAPGRATICULE_ARC_MINIMUM;
- /* if( fabs(Test_min) < 1E-10 ) */
- /* Test_min = 0 ; */
+ while(i < iTickCountTarget) {
+ Test_inc /= 2 ;
+ i *= 2 ;
- /* adjust for too few tick marks */
+ if(i < 6 && 0) {
+ Test_inc /= 2 ;
+ if((Test_min + Test_inc) <= *Min)
+ Test_min += Test_inc ;
+ if((Test_max - Test_inc) >= *Max)
+ Test_max -= Test_inc ;
- if( iTickCountTarget <= 0 )
- iTickCountTarget = MAPGRATICULE_ARC_MINIMUM;
+ /* pass back axis definition to caller */
- while( i < iTickCountTarget )
- Test_inc /= 2 ;
- i *= 2 ;
- if( i < 6 && 0 )
- Test_inc /= 2 ;
- if( (Test_min + Test_inc) <= *Min )
- Test_min += Test_inc ;
- if( (Test_max - Test_inc) >= *Max )
- Test_max -= Test_inc ;
- /* pass back axis definition to caller */
- *Min = Test_min ;
- *Max = Test_max ;
- *Inc = Test_inc ;
+ *Min = Test_min;
+ *Max = Test_max;
+ *Inc = Test_inc;
More information about the mapserver-commits
