[mapserver-commits] r7616 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu May 22 23:12:46 EDT 2008
Author: sdlime
Date: 2008-05-22 23:12:46 -0400 (Thu, 22 May 2008)
New Revision: 7616
trunk/mapserver/mapserv.c
Updated code in mapserv.c to respect mapservObj->sendheaders. (#2594)
Modified: trunk/mapserver/mapserv.c
--- trunk/mapserver/mapserv.c 2008-05-23 01:23:43 UTC (rev 7615)
+++ trunk/mapserver/mapserv.c 2008-05-23 03:12:46 UTC (rev 7616)
@@ -1127,7 +1127,7 @@
printf("%s\n", msGetVersion());
fflush(stdout);
exit(0);
- } else if( iArg < argc-1 && strcmp(argv[iArg], "-nh") == 0) {
+ } else if(strcmp(argv[iArg], "-nh") == 0) {
sendheaders = MS_FALSE;
} else if( iArg < argc-1 && strcmp(argv[iArg], "-tmpbase") == 0) {
msForceTmpFileBase( argv[++iArg] );
@@ -1148,7 +1148,7 @@
} else if( strncmp(argv[iArg], "QUERY_STRING=", 13) == 0) {
/* Debugging hook... pass "QUERY_STRING=..." on the command-line */
putenv( "REQUEST_METHOD=GET" );
- putenv( argv[1] );
+ putenv( argv[iArg] );
} else {
/* we don't produce a usage message as some web servers pass junk arguments */
@@ -1365,7 +1365,7 @@
writeError();
} else {
if(TEMPLATE_TYPE(mapserv->map->web.template) == MS_FILE) { /* if thers's an html template, then use it */
- msIO_printf("Content-type: %s%c%c", mapserv->map->web.browseformat, 10, 10); /* write MIME header */
+ if(mapserv->sendheaders) msIO_printf("Content-type: %s%c%c", mapserv->map->web.browseformat, 10, 10); /* write MIME header */
/* msIO_printf("<!-- %s -->\n", msGetVersion()); */
fflush(stdout);
if(msReturnPage(mapserv, mapserv->map->web.template, BROWSE, NULL) != MS_SUCCESS)
@@ -1420,7 +1420,7 @@
msIO_printf("Cache-Control: max-age=%s%c", msLookupHashTable(&(mapserv->map->web.metadata), "http_max_age"), 10);
- msIO_printf("Content-type: %s%c%c", MS_IMAGE_MIME_TYPE(mapserv->map->outputformat), 10,10);
+ if(mapserv->sendheaders) msIO_printf("Content-type: %s%c%c", MS_IMAGE_MIME_TYPE(mapserv->map->outputformat), 10,10);
if( mapserv->Mode == MAP || mapserv->Mode == TILE )
@@ -1437,7 +1437,7 @@
legendTemplate = generateLegendTemplate(mapserv);
if(legendTemplate) {
- msIO_printf("Content-type: %s%c%c", mapserv->map->web.legendformat, 10, 10);
+ if(mapserv->sendheaders) msIO_printf("Content-type: %s%c%c", mapserv->map->web.legendformat, 10, 10);
msIO_fwrite(legendTemplate, strlen(legendTemplate), 1, stdout);
free(legendTemplate);
@@ -1447,7 +1447,7 @@
img = msDrawLegend(mapserv->map, MS_FALSE);
if(!img) writeError();
status = msSaveImage(NULL, img, NULL);
if(status != MS_SUCCESS) writeError();
@@ -1462,7 +1462,7 @@
/* TODO: do we want to set scale here? */
/* do we have enough information */
- if(!mapserv->icon) {
+ if(!mapserv->icon) {
msSetError(MS_WEBERR, "Mode=LEGENDICON requires an icon parameter.", "mapserv()");
writeError();
@@ -1513,7 +1513,7 @@
if(msDrawLegendIcon(mapserv->map, GET_LAYER(mapserv->map, layerindex), GET_LAYER(mapserv->map, layerindex)->class[classindex], mapserv->map->legend.keysizex, mapserv->map->legend.keysizey, img, 0, 0) != MS_SUCCESS)
writeError();
@@ -1773,7 +1773,7 @@
img = msDrawMap(mapserv->map, MS_TRUE);
- msIO_printf("Content-type: %s%c%c",MS_IMAGE_MIME_TYPE(mapserv->map->outputformat), 10,10);
+ if(mapserv->sendheaders) msIO_printf("Content-type: %s%c%c",MS_IMAGE_MIME_TYPE(mapserv->map->outputformat), 10,10);
status = msSaveImage(mapserv->map, img, NULL);
msFreeImage(img);
More information about the mapserver-commits
