[mapserver-commits] r7625 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed May 28 00:25:23 EDT 2008
Author: sdlime
Date: 2008-05-28 00:25:23 -0400 (Wed, 28 May 2008)
New Revision: 7625
trunk/mapserver/maptemplate.c
Added general tag to support extent/bounds formating in a template. Can be applied to mapext, rawext, refext, mapext_latlon and shpext tags. (#2376)
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c 2008-05-27 18:03:19 UTC (rev 7624)
+++ trunk/mapserver/maptemplate.c 2008-05-28 04:25:23 UTC (rev 7625)
@@ -257,7 +257,7 @@
return MS_FAILURE;
- msIO_printf("Content-type: %s%c%c\n", outputFormat->mimetype, 10, 10);
+ if(mapserv->sendheaders) msIO_printf("Content-type: %s%c%c\n", outputFormat->mimetype, 10, 10);
if((status = msReturnPage(mapserv, (char *) file, BROWSE, papszBuffer)) != MS_SUCCESS)
return status;
} else {
@@ -1031,6 +1031,86 @@
+** Function process a [include src="..."] tag.
+** TODO's:
+** - allow URLs
+static int processIncludeTag(mapservObj *mapserv, char **line, FILE *stream, int mode)
+ char *tag, *tagStart, *tagEnd;
+ hashTableObj *tagArgs=NULL;
+ int tagOffset, tagLength;
+ char *content=NULL, *processedContent=NULL, *src=NULL;
+ FILE *includeStream;
+ char buffer[MS_BUFFER_LENGTH], path[MS_MAXPATHLEN];
+ if(!*line) {
+ msSetError(MS_WEBERR, "Invalid line pointer.", "processIncludeTag()");
+ return(MS_FAILURE);
+ tagStart = findTag(*line, "include");
+ /* It is OK to have no include tags, just return. */
+ if( !tagStart ) return MS_SUCCESS;
+ while( tagStart ) {
+ tagOffset = tagStart - *line;
+ /* check for any tag arguments */
+ if(getTagArgs("include", tagStart, &tagArgs) != MS_SUCCESS) return(MS_FAILURE);
+ if(tagArgs) {
+ src = msLookupHashTable(tagArgs, "src");
+ if(!src) return(MS_SUCCESS); /* don't process the tag, could be something else so return MS_SUCCESS */
+ if((includeStream = fopen(msBuildPath(path, mapserv->map->mappath, src), "r")) == NULL) {
+ msSetError(MS_IOERR, src, "processIncludeTag()");
+ return MS_FAILURE;
+ while(fgets(buffer, MS_BUFFER_LENGTH, includeStream) != NULL)
+ content = msStringConcatenate(content, buffer);
+ /* done with included file handle */
+ fclose(includeStream);
+ /* find the end of the tag */
+ tagEnd = strchr(tagStart, ']');
+ tagEnd++;
+ /* build the complete tag so we can do substitution */
+ tagLength = tagEnd - tagStart;
+ tag = (char *) malloc(tagLength + 1);
+ strncpy(tag, tagStart, tagLength);
+ tag[tagLength] = '\0';
+ /* process any other tags in the content */
+ processedContent = processLine(mapserv, content, stream, mode);
+ /* do the replacement */
+ *line = msReplaceSubstring(*line, tag, processedContent);
+ /* clean up */
+ free(tag); tag = NULL;
+ msFreeHashTable(tagArgs); tagArgs=NULL;
+ free(content);
+ free(processedContent);
+ if((*line)[tagOffset] != '\0')
+ tagStart = findTag(*line+tagOffset+1, "include");
+ else
+ tagStart = NULL;
+ return(MS_SUCCESS);
** Function to process an [item ...] tag: line contains the tag, shape holds the attributes.
enum ITEM_ESCAPING {ESCAPE_HTML, ESCAPE_URL, ESCAPE_NONE};
@@ -1199,54 +1279,80 @@
-** Function process a [include src="..."] tag.
+** Function process any number of MapServer extent tags (e.g. shpext, mapext, etc...).
-** TODO's:
-** - allow URLs
+** TODO: Add projection support (see shpxy tag).
+** Allow percentage expansion (e.g. 10%).
-static int processIncludeTag(mapservObj *mapserv, char **line, FILE *stream, int mode)
+static int processExtentTag(mapservObj *mapserv, char **line, char *name, rectObj *extent)
+ char *argValue;
- char *content=NULL, *processedContent=NULL, *src=NULL;
+ char *encodedTagValue=NULL, *tagValue=NULL;
- FILE *includeStream;
- char buffer[MS_BUFFER_LENGTH], path[MS_MAXPATHLEN];
+ rectObj tempExtent;
+ double expand=0;
+ char number[64]; /* holds a single number in the extent */
+ char numberFormat[16]="%f";
+ char *format="$minx $miny $maxx $maxy";
+ int precision=-1;
+ int escape=ESCAPE_HTML;
if(!*line) {
- msSetError(MS_WEBERR, "Invalid line pointer.", "processIncludeTag()");
+ msSetError(MS_WEBERR, "Invalid line pointer.", "processExtentTag()");
return(MS_FAILURE);
- tagStart = findTag(*line, "include");
+ tagStart = findTag(*line, name); /* this supports any extent */
- if( !tagStart ) return MS_SUCCESS;
+ if(!tagStart) return MS_SUCCESS;
- while( tagStart ) {
+ while(tagStart) {
- if(getTagArgs("include", tagStart, &tagArgs) != MS_SUCCESS) return(MS_FAILURE);
+ if(getTagArgs(name, tagStart, &tagArgs) != MS_SUCCESS) return(MS_FAILURE);
if(tagArgs) {
- src = msLookupHashTable(tagArgs, "src");
+ argValue = msLookupHashTable(tagArgs, "expand");
+ if(argValue) expand = atof(argValue);
+ argValue = msLookupHashTable(tagArgs, "escape");
+ if(argValue && strcasecmp(argValue, "url") == 0) escape = ESCAPE_URL;
+ else if(argValue && strcasecmp(argValue, "none") == 0) escape = ESCAPE_NONE;
+ argValue = msLookupHashTable(tagArgs, "format");
+ if(argValue) format = argValue;
+ argValue = msLookupHashTable(tagArgs, "precision");
+ if(argValue) precision = atoi(argValue);
- if(!src) return(MS_SUCCESS); /* don't process the tag, could be something else so return MS_SUCCESS */
+ tempExtent.minx = extent->minx - expand;
+ tempExtent.miny = extent->miny - expand;
+ tempExtent.maxx = extent->maxx + expand;
+ tempExtent.maxy = extent->maxy + expand;
- if((includeStream = fopen(msBuildPath(path, mapserv->map->mappath, src), "r")) == NULL) {
- msSetError(MS_IOERR, src, "processIncludeTag()");
- return MS_FAILURE;
- while(fgets(buffer, MS_BUFFER_LENGTH, includeStream) != NULL)
- content = msStringConcatenate(content, buffer);
+ tagValue = strdup(format);
- /* done with included file handle */
- fclose(includeStream);
+ if(precision != -1)
+ snprintf(numberFormat, 16, "%%.%dlf", precision);
+ snprintf(number, 64, numberFormat, tempExtent.minx);
+ tagValue = msReplaceSubstring(tagValue, "$minx", number);
+ snprintf(number, 64, numberFormat, tempExtent.miny);
+ tagValue = msReplaceSubstring(tagValue, "$miny", number);
+ snprintf(number, 64, numberFormat, tempExtent.maxx);
+ tagValue = msReplaceSubstring(tagValue, "$maxx", number);
+ tagValue = msReplaceSubstring(tagValue, "$maxy", number);
tagEnd++;
@@ -1257,17 +1363,28 @@
- /* process any other tags in the content */
- processedContent = processLine(mapserv, content, stream, mode);
- *line = msReplaceSubstring(*line, tag, processedContent);
+ switch(escape) {
+ case ESCAPE_HTML:
+ encodedTagValue = msEncodeHTMLEntities(tagValue);
+ *line = msReplaceSubstring(*line, tag, encodedTagValue);
+ break;
+ case ESCAPE_URL:
+ encodedTagValue = msEncodeUrl(tagValue);
+ break;
+ case ESCAPE_NONE:
+ *line = msReplaceSubstring(*line, tag, tagValue);
+ break;
+ default:
+ break;
/* clean up */
- free(content);
- free(processedContent);
+ msFree(tagValue); tagValue=NULL;
+ msFree(encodedTagValue); encodedTagValue=NULL;
@@ -1322,7 +1439,6 @@
if( msCheckParentPointer(layer->map,"map")==MS_FAILURE )
return MS_FAILURE;
tagStart = findTag(*line, "shpxy");
/* It is OK to have no shpxy tags, just return. */
@@ -2968,7 +3084,7 @@
sprintf(repstr, "%f", mapserv->mappnt.y);
outstr = msReplaceSubstring(outstr, "[mapy]", repstr);
- sprintf(repstr, "%f", mapserv->map->extent.minx); /* Individual mapextent elements for spatial query building */
+ sprintf(repstr, "%f", mapserv->map->extent.minx); /* Individual mapextent elements for spatial query building, depricated. */
outstr = msReplaceSubstring(outstr, "[minx]", repstr);
sprintf(repstr, "%f", mapserv->map->extent.maxx);
outstr = msReplaceSubstring(outstr, "[maxx]", repstr);
@@ -2976,11 +3092,12 @@
outstr = msReplaceSubstring(outstr, "[miny]", repstr);
sprintf(repstr, "%f", mapserv->map->extent.maxy);
outstr = msReplaceSubstring(outstr, "[maxy]", repstr);
- sprintf(repstr, "%f %f %f %f", mapserv->map->extent.minx, mapserv->map->extent.miny, mapserv->map->extent.maxx, mapserv->map->extent.maxy);
- outstr = msReplaceSubstring(outstr, "[mapext]", repstr);
+ if(processExtentTag(mapserv, &outstr, "mapext", &(mapserv->map->extent)) != MS_SUCCESS)
+ return(NULL);
encodedstr = msEncodeUrl(repstr);
- outstr = msReplaceSubstring(outstr, "[mapext_esc]", encodedstr);
+ outstr = msReplaceSubstring(outstr, "[mapext_esc]", encodedstr); /* depricated */
free(encodedstr);
sprintf(repstr, "%f", (mapserv->map->extent.maxx-mapserv->map->extent.minx)); /* useful for creating cachable extents (i.e. 0 0 dx dy) with legends and scalebars */
@@ -2988,7 +3105,7 @@
sprintf(repstr, "%f", (mapserv->map->extent.maxy-mapserv->map->extent.miny));
outstr = msReplaceSubstring(outstr, "[dy]", repstr);
- sprintf(repstr, "%f", mapserv->RawExt.minx); /* Individual raw extent elements for spatial query building */
+ sprintf(repstr, "%f", mapserv->RawExt.minx); /* Individual raw extent elements for spatial query building, depricated. */
outstr = msReplaceSubstring(outstr, "[rawminx]", repstr);
sprintf(repstr, "%f", mapserv->RawExt.maxx);
outstr = msReplaceSubstring(outstr, "[rawmaxx]", repstr);
@@ -2996,11 +3113,12 @@
outstr = msReplaceSubstring(outstr, "[rawminy]", repstr);
sprintf(repstr, "%f", mapserv->RawExt.maxy);
outstr = msReplaceSubstring(outstr, "[rawmaxy]", repstr);
- sprintf(repstr, "%f %f %f %f", mapserv->RawExt.minx, mapserv->RawExt.miny, mapserv->RawExt.maxx, mapserv->RawExt.maxy);
- outstr = msReplaceSubstring(outstr, "[rawext]", repstr);
+ if(processExtentTag(mapserv, &outstr, "rawext", &(mapserv->RawExt)) != MS_SUCCESS)
+ return(NULL);
- outstr = msReplaceSubstring(outstr, "[rawext_esc]", encodedstr);
+ outstr = msReplaceSubstring(outstr, "[rawext_esc]", encodedstr); /* depricated */
free(encodedstr);
#ifdef USE_PROJ
@@ -3025,11 +3143,12 @@
outstr = msReplaceSubstring(outstr, "[minlat]", repstr);
sprintf(repstr, "%f", llextent.maxy);
outstr = msReplaceSubstring(outstr, "[maxlat]", repstr);
- sprintf(repstr, "%f %f %f %f", llextent.minx, llextent.miny, llextent.maxx, llextent.maxy);
- outstr = msReplaceSubstring(outstr, "[mapext_latlon]", repstr);
+ if(processExtentTag(mapserv, &outstr, "mapext_latlon", &(llextent)) != MS_SUCCESS)
+ return(NULL);
- outstr = msReplaceSubstring(outstr, "[mapext_latlon_esc]", encodedstr);
+ outstr = msReplaceSubstring(outstr, "[mapext_latlon_esc]", encodedstr); /* depricated */
free(encodedstr);
#endif
@@ -3044,11 +3163,12 @@
outstr = msReplaceSubstring(outstr, "[refminy]", repstr);
sprintf(repstr, "%f", mapserv->map->reference.extent.maxy);
outstr = msReplaceSubstring(outstr, "[refmaxy]", repstr);
- sprintf(repstr, "%f %f %f %f", mapserv->map->reference.extent.minx, mapserv->map->reference.extent.miny, mapserv->map->reference.extent.maxx, mapserv->map->reference.extent.maxy);
- outstr = msReplaceSubstring(outstr, "[refext]", repstr);
+ if(processExtentTag(mapserv, &outstr, "refext", &(mapserv->map->reference.extent)) != MS_SUCCESS)
+ return(NULL);
- outstr = msReplaceSubstring(outstr, "[refext_esc]", encodedstr);
+ outstr = msReplaceSubstring(outstr, "[refext_esc]", encodedstr); /* depricated */
free(encodedstr);
@@ -3131,9 +3251,9 @@
sprintf(repstr, "%f", (mapserv->resultshape.bounds.maxy + mapserv->resultshape.bounds.miny)/2);
outstr = msReplaceSubstring(outstr, "[shpmidy]", repstr);
- sprintf(repstr, "%f %f %f %f", mapserv->resultshape.bounds.minx, mapserv->resultshape.bounds.miny, mapserv->resultshape.bounds.maxx, mapserv->resultshape.bounds.maxy);
- outstr = msReplaceSubstring(outstr, "[shpext]", repstr);
+ if(processExtentTag(mapserv, &outstr, "shpext", &(mapserv->resultshape.bounds)) != MS_SUCCESS)
+ return(NULL);
outstr = msReplaceSubstring(outstr, "[shpext_esc]", encodedstr);
free(encodedstr);
More information about the mapserver-commits
