[mapserver-commits] r8008 - trunk/mapserver/rfc
svn at osgeo.org
svn at osgeo.org
Wed Nov 5 13:01:12 EST 2008
Author: tbonfort
Date: 2008-11-05 13:01:12 -0500 (Wed, 05 Nov 2008)
New Revision: 8008
Added:
trunk/mapserver/rfc/ms-rfc-48.txt
initial checkin of rfc48: TYPE keyword for styleObj
Added: trunk/mapserver/rfc/ms-rfc-48.txt
--- trunk/mapserver/rfc/ms-rfc-48.txt (rev 0)
+++ trunk/mapserver/rfc/ms-rfc-48.txt 2008-11-05 18:01:12 UTC (rev 8008)
@@ -0,0 +1,81 @@
+:Date: 2008/11/01
+:Authors: Stephen Lime, Thomas Bonfort
+:Contact: Steve.Lime at DNR.State.MN.US, thomas.bonfort at camptocamp.com
+:Status: Draft
+:Version: MapServer 5.4
+:Funding: Camptocamp
+1. Summary
+The purpose of this RFC is to add the ability to Mapserver to interpret the
+geometries based on a user-defined TYPE keyword, and to render the interpreted
+geometry with the selected styling
+The directive to activate this behavior is the TYPE keyword, that belongs to
+the STYLE object.
+Usages of this parameter include drawing bounding boxes of underlying
+geometries, or adding arrowheads/tails to lines.
+2. Detailed functionality
+The TYPE keyword initially accepts these parameters :
+- *BBOX* : render a shapeObj representing the bounding box of the
+ underlying geometry
+- *BUFFER* : render a shapeObj representing the buffered geometry.
+ TODO: specify buffer distance. Not initially implemented.
+- *CENTROID* : render a pointObj at the location of the centroid of the
+ geometry
+- *CONVEXHULL* : not initially implemented
+- *START / END* : render a point symbol at the first/last vertex of the
+ underlying geometry. By default, the symbol is oriented to match the
+ orientation of the corresponding geometry segment. This would be used
+ to add arrowheads/tails to linestrings.
+- *VERTICES* : render a point symbol at each vertex of the geometry. The
+ default orientation matches the half angle of the corresponding segments.
+ TODO: specify if the start and end points are included or not.
+3. Implementation Details
+Apart from the parsing and internal storage of which type should be used,
+the modifications of this RFC only affect the high-level rendering functions
+in mapdraw.c .
+There are two main modifications:
+- inside msDrawVectorLayer, a copy of the shape before being clipped by the
+ current extent must be kept, as the whole shape must be used for all but
+ the VERTICES type. Then, when looping through the different styles that
+ can be applied, we switch off to the type-specific function if a TYPE
+ keyword is set.
+- inside mapdraw.c, the type-specific drawing function is added. Depending
+ on the current style type, it either computes a new shape from the
+ original shape (types bbox, convexhull or buffer) and passes it to the
+ msDrawShadeSymbol, or calls msDrawMarkerSymbol for points of the original
+ shape (types start, end, vertices, centroid) after having adjusted the
+ orientation accordingly.
+4. Affected Files
+- mapdraw.c
+- maplexer.c/.l
+- mapfile.c
+- mapserver.h
+5. Backwards Incompatibility Issues
+none expected.
+6. Bug ID
+http://trac.osgeo.org/mapserver/ticket/xxxx
Property changes on: trunk/mapserver/rfc/ms-rfc-48.txt
___________________________________________________________________
+ text/x-rst
More information about the mapserver-commits
