[mapserver-commits] r8015 - in trunk/mapserver: . mapscript/php3 mapscript/swiginc
Tue Nov 11 13:14:14 EST 2008
Author: pramsey
Date: 2008-11-11 13:14:14 -0500 (Tue, 11 Nov 2008)
New Revision: 8015
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapobject.c
   trunk/mapserver/mapraster.c
   trunk/mapserver/maprasterquery.c
   trunk/mapserver/mapscript/php3/mapscript_i.c
   trunk/mapserver/mapscript/swiginc/shapefile.i
   trunk/mapserver/mapserver.h
   trunk/mapserver/mapshape.c
   trunk/mapserver/mapshape.h
   trunk/mapserver/shptree.c
IGNORE_MISSING_DATA largely replaced by run-time CONFIG property, ON_MISSING_DATA, which supports three modes: FAIL, LOG, and IGNORE.  (#2785) ms-rfc-47.txt
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-11-08 15:22:31 UTC (rev 8014)
+++ trunk/mapserver/HISTORY.TXT	2008-11-11 18:14:14 UTC (rev 8015)
@@ -12,6 +12,10 @@
 Current Version (5.3-dev, SVN trunk):
+- IGNORE_MISSING_DATA: largely replaced by run-time CONFIG property,
+  ON_MISSING_DATA, which supports three modes: FAIL, LOG, and IGNORE.
+  (#2785) ms-rfc-47.txt
 - mapstring.c: msStringTrim(*char str), front-and-back whitespace trimmer
 - mappostgis.c: re-write to remove binary cursors and break up
Modified: trunk/mapserver/mapobject.c
--- trunk/mapserver/mapobject.c	2008-11-08 15:22:31 UTC (rev 8014)
+++ trunk/mapserver/mapobject.c	2008-11-11 18:14:14 UTC (rev 8015)
@@ -227,6 +227,33 @@
+/*                         msMapIgnoreMissingData()                               */
+int msMapIgnoreMissingData( mapObj *map )
+    const char *result = msGetConfigOption( map, "ON_MISSING_DATA" );
+    const int default_result =
+#ifndef IGNORE_MISSING_DATA
+        MS_MISSING_DATA_FAIL;
+#else
+        MS_MISSING_DATA_LOG;
+#endif
+    if( result == NULL )
+        return default_result;
+    if( strcasecmp(result,"FAIL") == 0 )
+        return MS_MISSING_DATA_FAIL;
+    else if( strcasecmp(result,"LOG") == 0 )
+        return MS_MISSING_DATA_LOG;
+    else if( strcasecmp(result,"IGNORE") == 0 )
+        return MS_MISSING_DATA_IGNORE;
 /*                           msMapSetExtent()                           */
Modified: trunk/mapserver/mapraster.c
--- trunk/mapserver/mapraster.c	2008-11-08 15:22:31 UTC (rev 8014)
+++ trunk/mapserver/mapraster.c	2008-11-11 18:14:14 UTC (rev 8015)
@@ -1588,20 +1588,27 @@
     ** Generate an error.
     if( !f ) {
-      msSetError(MS_IOERR, "%s using full path %s", "msDrawRaster()", filename, szPath);
+      int ignore_missing = msMapIgnoreMissingData( map );
+      if( ignore_missing != MS_MISSING_DATA_IGNORE ) {
+        msSetError(MS_IOERR, "%s using full path %s", "msDrawRaster()", filename, szPath);
-#ifndef IGNORE_MISSING_DATA
-      if( layer->debug || map->debug )
+      if( ignore_missing == MS_MISSING_DATA_FAIL ) {
+        if( layer->debug || map->debug )
           msDebug( "Unable to open file %s for layer %s ... fatal error.\n", filename, layer->name );
+        final_status = MS_FAILURE;
+        break;
-      final_status = MS_FAILURE;
-      break;
-#else
+      if( ignore_missing == MS_MISSING_DATA_LOG ) {
           msDebug( "Unable to open file %s for layer %s ... ignoring this missing data.\n", filename, layer->name );
+        continue;
-      continue; /* skip it, next tile */
-#endif
+      if( ignore_missing == MS_MISSING_DATA_IGNORE ) {
+        continue; /* skip it, next tile */
     /* put others which may require checks here */
Modified: trunk/mapserver/maprasterquery.c
--- trunk/mapserver/maprasterquery.c	2008-11-08 15:22:31 UTC (rev 8014)
+++ trunk/mapserver/maprasterquery.c	2008-11-11 18:14:14 UTC (rev 8015)
@@ -721,8 +721,8 @@
     if(layer->tileindex) { /* we have in index file */
         if(msShapefileOpen(&tilefile, "rb",
                          msBuildPath3(szPath, map->mappath, map->shapepath,
-                                      layer->tileindex)) == -1)
-            if(msShapefileOpen(&tilefile, "rb", msBuildPath(szPath, map->mappath, layer->tileindex)) == -1)
+                                      layer->tileindex), MS_TRUE) == -1)
+            if(msShapefileOpen(&tilefile, "rb", msBuildPath(szPath, map->mappath, layer->tileindex), MS_TRUE) == -1)
                 return(MS_FAILURE);
         tileitemindex = msDBFGetItemIndex(tilefile.hDBF, layer->tileitem);
@@ -790,22 +790,22 @@
         if( hDS == NULL )
             msReleaseLock( TLOCK_GDAL );
+            if ( ignore_missing == MS_MISSING_DATA_FAIL ) {
                 msSetError( MS_IMGERR,
                             "Unable to open file %s for layer %s ... fatal error.\n%s",
                             szPath, layer->name, CPLGetLastErrorMsg(),
                             "msRasterQueryByRect()" );
-            return(MS_FAILURE);
-#else
+              return(MS_FAILURE);
                 msDebug( "Unable to open file %s for layer %s ... ignoring this missing data.\n%s",
                          filename, layer->name, CPLGetLastErrorMsg() );
-#endif
             continue;
Modified: trunk/mapserver/mapscript/php3/mapscript_i.c
--- trunk/mapserver/mapscript/php3/mapscript_i.c	2008-11-08 15:22:31 UTC (rev 8014)
+++ trunk/mapserver/mapscript/php3/mapscript_i.c	2008-11-11 18:14:14 UTC (rev 8015)
@@ -1069,9 +1069,9 @@
       return NULL;
     if(type == -1)
-      status = msShapefileOpen(shapefile, "rb", filename);
+      status = msShapefileOpen(shapefile, "rb", filename, MS_TRUE);
     else if (type == -2)
-      status = msShapefileOpen(shapefile, "rb+", filename);
+      status = msShapefileOpen(shapefile, "rb+", filename, MS_TRUE);
     else
       status = msShapefileCreate(shapefile, filename, type);
Modified: trunk/mapserver/mapscript/swiginc/shapefile.i
--- trunk/mapserver/mapscript/swiginc/shapefile.i	2008-11-08 15:22:31 UTC (rev 8014)
+++ trunk/mapserver/mapscript/swiginc/shapefile.i	2008-11-11 18:14:14 UTC (rev 8015)
@@ -42,9 +42,9 @@
             return NULL;
         if (type == -1)
         else
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2008-11-08 15:22:31 UTC (rev 8014)
+++ trunk/mapserver/mapserver.h	2008-11-11 18:14:14 UTC (rev 8015)
@@ -175,6 +175,10 @@
 #define MS_MAXCOLORS 256
+#define MS_MISSING_DATA_IGNORE 0
+#define MS_MISSING_DATA_FAIL 1
+#define MS_MISSING_DATA_LOG 2
 #define MS_BUFFER_LENGTH 2048 /* maximum input line length */
 #define MS_URL_LENGTH 1024
 #define MS_MAXPATHLEN 1024
@@ -1520,6 +1524,7 @@
 MS_DLL_EXPORT int msMapRestoreRealExtent( mapObj *map );
 MS_DLL_EXPORT int msMapLoadOWSParameters( mapObj *map, cgiRequestObj *request,
                                           const char *wmtver_string );
+MS_DLL_EXPORT int msMapIgnoreMissingData( mapObj *map );
 /* mapfile.c */
Modified: trunk/mapserver/mapshape.c
--- trunk/mapserver/mapshape.c	2008-11-08 15:22:31 UTC (rev 8014)
+++ trunk/mapserver/mapshape.c	2008-11-11 18:14:14 UTC (rev 8015)
@@ -1626,13 +1626,14 @@
   return MS_SUCCESS;
-int msShapefileOpen(shapefileObj *shpfile, char *mode, char *filename)
+int msShapefileOpen(shapefileObj *shpfile, char *mode, char *filename, int log_failures)
   int i;
   char *dbfFilename;
   if(!filename) {
-    msSetError(MS_IOERR, "No (NULL) filename provided.", "msShapefileOpen()");
+    if( log_failures )
+      msSetError(MS_IOERR, "No (NULL) filename provided.", "msShapefileOpen()");
     return(-1);
@@ -1648,7 +1649,8 @@
     shpfile->hSHP = msSHPOpen( filename, mode);
   if(!shpfile->hSHP) {
-    msSetError(MS_IOERR, "(%s)", "msShapefileOpen()", filename);
+      msSetError(MS_IOERR, "(%s)", "msShapefileOpen()", filename);
     return(-1);
@@ -1674,7 +1676,8 @@
   shpfile->hDBF = msDBFOpen(dbfFilename, "rb");
   if(!shpfile->hDBF) {
-    msSetError(MS_IOERR, "(%s)", "msShapefileOpen()", dbfFilename);
+      msSetError(MS_IOERR, "(%s)", "msShapefileOpen()", dbfFilename);
     free(dbfFilename);
     return(-1);
@@ -1810,6 +1813,52 @@
   free(tiFileAbsDirTmp);
+** Build possible paths we might find the tile file at:
+**   map dir + shape path + filename?
+**   tile dir + shape path + filename?
+**   map dir + filename?
+** Returns
+** MS_SUCCESS - found a file
+** MS_FAILURE - no file, and map is configured to fail on missing
+** MS_DONE - no file, and map is configured to continue on missing
+int msTiledSHPTryOpen(shapefileObj *shpfile, layerObj *layer, char *tiFileAbsDir, char *filename) {
+    char szPath[MS_MAXPATHLEN];
+    int ignore_missing = msMapIgnoreMissingData(layer->map);
+    int log_failures = MS_TRUE;
+      log_failures = MS_FALSE;
+    if(msShapefileOpen(shpfile, "rb", msBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, filename), log_failures) == -1) {
+      if(msShapefileOpen(shpfile, "rb", msBuildPath3(szPath, tiFileAbsDir, layer->map->shapepath, filename), log_failures) == -1) {
+        if(msShapefileOpen(shpfile, "rb", msBuildPath(szPath, layer->map->mappath, filename), log_failures) == -1) {
+          if(ignore_missing == MS_MISSING_DATA_FAIL) {
+            msSetError(MS_IOERR, "Unable to open shapefile '%s' for layer '%s' ... fatal error.", "msTiledSHPTryOpen()", filename, layer->name);
+          else if( ignore_missing == MS_MISSING_DATA_LOG ) {
+            if( layer->debug || layer->map->debug ) {
+              msDebug( "Unable to open shapefile '%s' for layer '%s' ... ignoring this missing data.\n", szPath, layer->name );
+            return(MS_DONE);
+          else if( ignore_missing == MS_MISSING_DATA_IGNORE ) {
+            return(MS_DONE);
+          else {
+            /* never get here */
+            msSetError(MS_IOERR, "msIgnoreMissingData returned unexpected value.", "msTiledSHPTryOpen()");
+    return(MS_SUCCESS);
 int msTiledSHPOpenFile(layerObj *layer)
   int i;
@@ -1857,8 +1906,8 @@
     /* we need tSHP->tileshpfile if we're not working with a layer */
     tSHP->tileshpfile = (shapefileObj *) malloc(sizeof(shapefileObj));
-    if(msShapefileOpen(tSHP->tileshpfile, "rb", msBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, layer->tileindex)) == -1)
-      if(msShapefileOpen(tSHP->tileshpfile, "rb", msBuildPath(szPath, layer->map->mappath, layer->tileindex)) == -1)
+    if(msShapefileOpen(tSHP->tileshpfile, "rb", msBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, layer->tileindex), MS_TRUE) == -1)
+      if(msShapefileOpen(tSHP->tileshpfile, "rb", msBuildPath(szPath, layer->map->mappath, layer->tileindex), MS_TRUE) == -1)
         return(MS_FAILURE);
@@ -1868,7 +1917,8 @@
   /* position the source at the FIRST tile to use as a template, this is so the functions that fill the iteminfo array have something to work from */
   for(i=0; i<tSHP->tileshpfile->numshapes; i++) {
+    int try_open;
     if(!layer->data) /* assume whole filename is in attribute field */
       filename = (char*) msDBFReadStringAttribute(tSHP->tileshpfile->hDBF, i, layer->tileitemindex);
     else {
@@ -1877,24 +1927,12 @@
     if(strlen(filename) == 0) continue; /* check again */
-    if(msShapefileOpen(tSHP->shpfile, "rb", msBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, filename)) == -1) {
-      if(msShapefileOpen(tSHP->shpfile, "rb", msBuildPath3(szPath, tiFileAbsDir, layer->map->shapepath, filename)) == -1) {
-        if(msShapefileOpen(tSHP->shpfile, "rb", msBuildPath(szPath, layer->map->mappath, filename)) == -1) {
-          if( layer->debug || layer->map->debug ) {
-            msDebug( "Unable to open file %s for layer %s ... fatal error.\n", filename, layer->name );
-#else
-            msDebug( "Unable to open shapefile %s for layer %s ... ignoring this missing data.\n", szPath, layer->name );
-          continue; /* check again */
-#endif
+    try_open = msTiledSHPTryOpen(tSHP->shpfile, layer, tiFileAbsDir, filename);
+    if( try_open == MS_DONE )
+      continue;
+    else if (try_open == MS_FAILURE )
     return(MS_SUCCESS); /* found a template, ok to proceed */
@@ -1903,10 +1941,11 @@
   return(MS_FAILURE);
 int msTiledSHPWhichShapes(layerObj *layer, rectObj rect)
   int i, status;
-  char *filename, tilename[MS_MAXPATHLEN], szPath[MS_MAXPATHLEN];
+  char *filename, tilename[MS_MAXPATHLEN];
   char tiFileAbsDir[MS_MAXPATHLEN];
   msTiledSHPLayerInfo *tSHP=NULL;
@@ -1934,7 +1973,8 @@
     msInitShape(&tshape);
     while((status = msLayerNextShape(tlp, &tshape)) == MS_SUCCESS) {
+      int try_open;
       /* TODO: seems stupid to read the tileitem seperately from the shape, need to fix msTiledSHPOpenFile */
 	    filename = (char *) msDBFReadStringAttribute(tSHP->tileshpfile->hDBF, tshape.index, layer->tileitemindex);
@@ -1945,23 +1985,11 @@
-#else
-#endif
+        continue;
       status = msShapefileWhichShapes(tSHP->shpfile, rect, layer->debug);
       if(status == MS_DONE) {
@@ -1981,7 +2009,8 @@
     return(status); /* if we reach here we either 1) ran out of tiles or 2) had an error reading a tile */
   } else { /* or reference a shapefile directly */
+    int try_open;
     status = msShapefileWhichShapes(tSHP->tileshpfile, rect, layer->debug);
     if(status != MS_SUCCESS) return(status); /* could be MS_DONE or MS_FAILURE */
@@ -1999,23 +2028,11 @@
-#else
-#endif
+          continue;
@@ -2045,7 +2062,7 @@
 int msTiledSHPNextShape(layerObj *layer, shapeObj *shape)
   int i, status, filter_passed = MS_FALSE;
   char **values=NULL;
@@ -2074,7 +2091,8 @@
       if(tSHP->tilelayerindex != -1) { /* does the tileindex reference another layer */
         layerObj *tlp;
         shapeObj tshape;
+        int try_open;
         tlp = (GET_LAYER(layer->map, tSHP->tilelayerindex));
@@ -2090,23 +2108,11 @@
-#else
-#endif
+            continue;
           status = msShapefileWhichShapes(tSHP->shpfile, tSHP->tileshpfile->statusbounds, layer->debug);
@@ -2134,32 +2140,22 @@
         for(i=(tSHP->tileshpfile->lastshape + 1); i<tSHP->tileshpfile->numshapes; i++) {
           if(msGetBit(tSHP->tileshpfile->status,i)) {
+            int try_open;
               filename = (char*)msDBFReadStringAttribute(tSHP->tileshpfile->hDBF, i, layer->tileitemindex);
             else {
               sprintf(tilename,"%s/%s", msDBFReadStringAttribute(tSHP->tileshpfile->hDBF, i, layer->tileitemindex) , layer->data);
               filename = tilename;
-#else
-#endif
+              continue;
@@ -2242,9 +2238,9 @@
     /* open the shapefile, since a specific tile was request an error should be generated if that tile does not exist */
     if(strlen(filename) == 0) return(MS_FAILURE);
+    if(msShapefileOpen(tSHP->shpfile, "rb", msBuildPath3(szPath, tiFileAbsDir, layer->map->shapepath, filename), MS_TRUE) == -1) {
+      if(msShapefileOpen(tSHP->shpfile, "rb", msBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, filename), MS_TRUE) == -1) {
+        if(msShapefileOpen(tSHP->shpfile, "rb", msBuildPath(szPath, layer->map->mappath, filename), MS_TRUE) == -1) {
           return(MS_FAILURE);
@@ -2443,8 +2439,8 @@
   layer->layerinfo = shpfile;
-  if(msShapefileOpen(shpfile, "rb", msBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, layer->data)) == -1) {
-    if(msShapefileOpen(shpfile, "rb", msBuildPath(szPath, layer->map->mappath, layer->data)) == -1) {
+  if(msShapefileOpen(shpfile, "rb", msBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, layer->data), MS_TRUE) == -1) {
+    if(msShapefileOpen(shpfile, "rb", msBuildPath(szPath, layer->map->mappath, layer->data), MS_TRUE) == -1) {
       layer->layerinfo = NULL;
       free(shpfile);
       return MS_FAILURE;
Modified: trunk/mapserver/mapshape.h
--- trunk/mapserver/mapshape.h	2008-11-08 15:22:31 UTC (rev 8014)
+++ trunk/mapserver/mapshape.h	2008-11-11 18:14:14 UTC (rev 8015)
@@ -183,7 +183,7 @@
 } msTiledSHPLayerInfo;
 /* shapefileObj function prototypes  */
-MS_DLL_EXPORT int msShapefileOpen(shapefileObj *shpfile, char *mode, char *filename);
+MS_DLL_EXPORT int msShapefileOpen(shapefileObj *shpfile, char *mode, char *filename, int log_failures);
 MS_DLL_EXPORT int msShapefileCreate(shapefileObj *shpfile, char *filename, int type);
 MS_DLL_EXPORT void msShapefileClose(shapefileObj *shpfile);
 MS_DLL_EXPORT int msShapefileWhichShapes(shapefileObj *shpfile, rectObj rect, int debug);
Modified: trunk/mapserver/shptree.c
--- trunk/mapserver/shptree.c	2008-11-08 15:22:31 UTC (rev 8014)
+++ trunk/mapserver/shptree.c	2008-11-11 18:14:14 UTC (rev 8015)
@@ -1,5 +1,5 @@
- * $Id:$
+ * $Id$
  * Project:  MapServer
  * Purpose:  Commandline utility to generate .qix shapefile spatial indexes.
@@ -124,7 +124,7 @@
       byte_order = MS_NEW_MSB_ORDER;
-  if(msShapefileOpen(&shapefile, "rb", argv[1]) == -1) {
+  if(msShapefileOpen(&shapefile, "rb", argv[1], MS_TRUE) == -1) {
     fprintf(stdout, "Error opening shapefile %s.\n", argv[1]);
     exit(0);
