[mapserver-commits] r8026 - branches/branch-5-2/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Nov 21 10:40:21 EST 2008
Author: Assefa
Date: 2008-11-21 10:40:21 -0500 (Fri, 21 Nov 2008)
New Revision: 8026
branches/branch-5-2/mapserver/nmake.opt
add a libxml2 section. Add notes for the OGC sections that need libxml2 #2657
Modified: branches/branch-5-2/mapserver/nmake.opt
--- branches/branch-5-2/mapserver/nmake.opt 2008-11-21 14:12:35 UTC (rev 8025)
+++ branches/branch-5-2/mapserver/nmake.opt 2008-11-21 15:40:21 UTC (rev 8026)
@@ -71,7 +71,8 @@
# Set the following to point to the directory adjacent to the dependent libs.
!IFNDEF MS_BASE
-MS_BASE = c:\projects\mapserver
+#MS_BASE = c:\projects\mapserver
+MS_BASE = f:\projects\mapserver-buildkit-ms520\mapserver-5.2.x
!ENDIF
# Set the following to point to the current (mapserver) directory.
@@ -166,8 +167,9 @@
# GD is a required support library for MapServer 4.x.
!IFNDEF GD_DIR
-GD_DIR=$(MS_BASE)\..\gd-2.0.33
-GD_LIB=$(GD_DIR)/bgd_i.lib
+GD_DIR=$(MS_BASE)\..\gd-2.0.35
+GD_LIB=$(GD_DIR)/gd.lib
+#GD_LIB=$(GD_DIR)/bgd_i.lib
!ENDIF
@@ -280,8 +282,8 @@
# The AGG (Ant-Grain Geometry) libraray http://www.antigrain.com/
#is used in Mapserver to putput high class rendering
-#AGG=-DUSE_AGG
-#AGG_DIR=$(MS_BASE)\..\agg-2.4
+AGG=-DUSE_AGG
+AGG_DIR=$(MS_BASE)\..\agg-2.4
# PDF (Acrobat PDF support)
@@ -341,7 +343,7 @@
# GDAL_DIR to the directory where GDAL was built.
#GDAL=-DUSE_GDAL
-#GDAL_DIR=$(MS_BASE)\..\gdal
+#GDAL_DIR=$(MS_BASE)\..\gdal_1_5_2
@@ -359,7 +361,7 @@
# needs only be defined once.
#OGR=-DUSE_OGR
@@ -384,18 +386,19 @@
# See http://www.postgresql.org for support library.
#POSTGIS =-DUSE_POSTGIS
-#POSTGIS_DIR =$(MS_BASE)\..\postgresql-8.1.2
+#POSTGIS_DIR =$(MS_BASE)\..\postgresql-8.3.3
# Direct connectivity to Oracle Spatial.
# Point this to where your ORACLE_HOME directory lives.
-#ORACLE_DIR = c:\Oracle\Ora81
+#ORACLE_DIR = $(MS_BASE)\..\oracle-10.2.0.1.0
#ORACLE=-DUSE_ORACLESPATIAL
#ORACLE=-DUSE_ORACLE_PLUGIN
# Direct connectivity to ESRI ArcSDE.
@@ -457,6 +460,14 @@
# Section IV: Mapserver OGC Configuration
+# LIBXML: utility library to write xml.
+# http://xmlsoft.org/index.html
+# WFS, WCS and SOS all need this flag to be activated
+# NOTE: ICONV is required when libxml2 is activated
+#XML2_ENABLED=-DUSE_LIBXML2
+#LIBXML_DIR=$(MS_BASE)\..\libxml2-2.6.23.win32
# WMS Server
@@ -481,6 +492,8 @@
#WINSOCK_LIB = "C:\Program Files\Microsoft Visual Studio\VC98\Lib\WSOCK32.LIB"
#WINSOCK_LIB ="C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\PlatformSDK\Lib\WS2_32.Lib"
# WFS Client
@@ -491,13 +504,14 @@
# WFS Server
# Use -DUSE_WFS_SVR to compile with WFS server
-# support, requires OGR and PROJ4
+# support, requires OGR and PROJ4, and libxml2
#WFS=-DUSE_WFS_SVR
# WCS Server
# Use -DUSE_WCS_SVR to compile with WCS server support, requires GDAL.
+# It Also requires libxml2
#WCS=-DUSE_WCS_SVR
@@ -506,12 +520,8 @@
# Use -DUSE_OGC_SOS to compile with SOS, needs USE_WMS_SVR or
#USE_WFS_SVR enabled so the the gml functions to be enabled
-#It also needs ICONV support since the libxml windows binaries
-#are built with it
-#http://xmlsoft.org/index.html
+#It also needs ICONV support and libxml2 support
#SOS=-DUSE_SOS_SVR
-#XML2_ENABLED=-DUSE_LIBXML2
-#LIBXML_DIR=$(MS_BASE)\..\libxml2-2.6.13.win32
@@ -578,7 +588,7 @@
# also required for all OGC services (WMS, WFS, and WCS).
#PROJ=-DUSE_PROJ -DUSE_PROJ_API_H
-#PROJ_DIR=$(MS_BASE)\..\proj-4.4.9
+#PROJ_DIR=$(MS_BASE)\..\proj
@@ -627,7 +637,7 @@
!ENDIF
# LIBXML include and library
-!IFDEF SOS
+!IFDEF XML2_ENABLED
LIBXML_INC = -I$(LIBXML_DIR)/include
LIBXML_LIB = $(LIBXML_DIR)/lib/libxml2.lib
!ENDIF
@@ -681,7 +691,7 @@
# Setup OGR includes and libraries
!IFDEF OGR
-OGR_INC = -I$(GDAL_DIR)/ogr/ogrsf_frmts -I$(GDAL_DIR)/ogr -I$(GDAL_DIR)/port
+OGR_INC = -I$(GDAL_DIR)/ogr/ogrsf_frmts -I$(GDAL_DIR)/ogr -I$(GDAL_DIR)/port -I$(GDAL_DIR)/gcore
OGR_LIB = $(GDAL_DIR)/gdal_i.lib
!ENDIF
More information about the mapserver-commits
