[mapserver-commits] r8028 - in trunk/docs: . howto references/cgi references/fontset references/mapfile references/mapscript references/phpmapscript-class references/symbology references/systemmanage references/templatereference references/utilityreference references/vector_data
Fri Nov 21 11:06:57 EST 2008
Author: hobu
Date: 2008-11-21 11:06:57 -0500 (Fri, 21 Nov 2008)
New Revision: 8028
Added:
   trunk/docs/index.txt
Removed:
   trunk/docs/howto/buildkit.txt
   trunk/docs/howto/Configure Oracle and UMN.txt
   trunk/docs/howto/Debian Lenny install guide.txt
   trunk/docs/howto/FreeBSD-install.txt
   trunk/docs/howto/PHPMapscriptAndMscross.txt
   trunk/docs/howto/RedHat9andMapServer40.txt
   trunk/docs/howto/Ubuntu Compilation.txt
   trunk/docs/howto/WCSServerFormatHowTo.txt
   trunk/docs/howto/agg-rendering-specifics.txt
   trunk/docs/howto/antialias.txt
   trunk/docs/howto/bug_submission.txt
   trunk/docs/howto/building-mapserver-its-main-dependencies-from-scratches-under-linux.txt
   trunk/docs/howto/cartosymbols.txt
   trunk/docs/howto/cgi-wrapper-script.txt
   trunk/docs/howto/coldfusion.txt
   trunk/docs/howto/compiling_on_unix.txt
   trunk/docs/howto/debian-install.txt
   trunk/docs/howto/debian-odbc-mysql.txt
   trunk/docs/howto/dynamic-charting.txt
   trunk/docs/howto/fastcgi.txt
   trunk/docs/howto/filterencoding.txt
   trunk/docs/howto/flash_output.txt
   trunk/docs/howto/freebsd62mapserver410.txt
   trunk/docs/howto/html_legend.txt
   trunk/docs/howto/imagemaps.txt
   trunk/docs/howto/java_mapscript_Tomcat_55.txt
   trunk/docs/howto/javamapscript.txt
   trunk/docs/howto/jbox.txt
   trunk/docs/howto/mapcontext.txt
   trunk/docs/howto/mapfiletuning.txt
   trunk/docs/howto/mapscript_imagery.txt
   trunk/docs/howto/mapscript_map_config.txt
   trunk/docs/howto/mapscript_python.txt
   trunk/docs/howto/mapscript_querying.txt
   trunk/docs/howto/mapscriptcscompile.txt
   trunk/docs/howto/mapserver openbsd 3.7 jan 2005.txt
   trunk/docs/howto/mapserver_compilation_on_suse_10.txt
   trunk/docs/howto/mapserverubuntu.txt
   trunk/docs/howto/msexpressions.txt
   trunk/docs/howto/ogr_howto.txt
   trunk/docs/howto/ogrmysql.txt
   trunk/docs/howto/optimizeraster.txt
   trunk/docs/howto/optimizevector.txt
   trunk/docs/howto/oracle_spatial_howto.txt
   trunk/docs/howto/pdf-output.txt
   trunk/docs/howto/perl_examples.txt
   trunk/docs/howto/phpmapscript-byexample.txt
   trunk/docs/howto/phpmapscript-install.txt
   trunk/docs/howto/raster_data.txt
   trunk/docs/howto/runsub.txt
   trunk/docs/howto/setupiis.txt
   trunk/docs/howto/sldhowto.txt
   trunk/docs/howto/sos_server.txt
   trunk/docs/howto/suse-linux.txt
   trunk/docs/howto/svg-howto.txt
   trunk/docs/howto/symbologyexchange.txt
   trunk/docs/howto/symbologyexchange_pixmap.txt
   trunk/docs/howto/symbologyexchange_ttf.txt
   trunk/docs/howto/symbologyexchange_vector.txt
   trunk/docs/howto/tile_mode.txt
   trunk/docs/howto/tileindex.txt
   trunk/docs/howto/verboselinuxinstall.txt
   trunk/docs/howto/vim-syntax-howto.txt
   trunk/docs/howto/vimfolding.txt
   trunk/docs/howto/wcs_server.txt
   trunk/docs/howto/wfs_client.txt
   trunk/docs/howto/wfs_server.txt
   trunk/docs/howto/win32_compiling.txt
   trunk/docs/howto/wms_client.txt
   trunk/docs/howto/wms_server.txt
   trunk/docs/howto/wms_time_support.txt
   trunk/docs/howto/wxs_mapscript.txt
   trunk/docs/references/cgi/about.txt
   trunk/docs/references/cgi/controls.txt
   trunk/docs/references/cgi/introduction.txt
   trunk/docs/references/cgi/mapcontext.txt
   trunk/docs/references/cgi/mapserv.txt
   trunk/docs/references/fontset/fontset.txt
   trunk/docs/references/mapfile/Include.txt
   trunk/docs/references/mapfile/articleinfo.txt
   trunk/docs/references/mapfile/class.txt
   trunk/docs/references/mapfile/feature.txt
   trunk/docs/references/mapfile/grid.txt
   trunk/docs/references/mapfile/introduction.txt
   trunk/docs/references/mapfile/join.txt
   trunk/docs/references/mapfile/label.txt
   trunk/docs/references/mapfile/layer.txt
   trunk/docs/references/mapfile/legend.txt
   trunk/docs/references/mapfile/mapObj.txt
   trunk/docs/references/mapfile/outputformat.txt
   trunk/docs/references/mapfile/projection.txt
   trunk/docs/references/mapfile/querymap.txt
   trunk/docs/references/mapfile/reference.txt
   trunk/docs/references/mapfile/scalebar.txt
   trunk/docs/references/mapfile/style.txt
   trunk/docs/references/mapfile/variable_sub.txt
   trunk/docs/references/mapfile/web.txt
   trunk/docs/references/mapscript/index_html.txt
   trunk/docs/references/mapscript/introduction.txt
   trunk/docs/references/mapscript/variables.txt
   trunk/docs/references/phpmapscript-class/class-constants.txt
   trunk/docs/references/phpmapscript-class/class-functions.txt
   trunk/docs/references/phpmapscript-class/class-intro.txt
   trunk/docs/references/phpmapscript-class/javamapscript.txt
   trunk/docs/references/symbology/examples.txt
   trunk/docs/references/symbology/notes.txt
   trunk/docs/references/symbology/syntax.txt
   trunk/docs/references/systemmanage/systemmanage.txt
   trunk/docs/references/templatereference/templatereference.txt
   trunk/docs/references/utilityreference/available-packages.txt
   trunk/docs/references/utilityreference/batch_utilities.txt
   trunk/docs/references/utilityreference/legend.txt
   trunk/docs/references/utilityreference/msencrypt.txt
   trunk/docs/references/utilityreference/scalebar.txt
   trunk/docs/references/utilityreference/shp2img.txt
   trunk/docs/references/utilityreference/shptree.txt
   trunk/docs/references/utilityreference/shptreevis.txt
   trunk/docs/references/utilityreference/sortshp.txt
   trunk/docs/references/utilityreference/sym2img.txt
   trunk/docs/references/utilityreference/tile4ms.txt
   trunk/docs/references/utilityreference/utilityreference.txt
   trunk/docs/references/vector_data/ArcInfo.txt
   trunk/docs/references/vector_data/S57.txt
   trunk/docs/references/vector_data/VirtualSpatialData.txt
   trunk/docs/references/vector_data/arcsde.txt
   trunk/docs/references/vector_data/articleinfo.txt
   trunk/docs/references/vector_data/dgn.txt
   trunk/docs/references/vector_data/format_types.txt
   trunk/docs/references/vector_data/formats_intro.txt
   trunk/docs/references/vector_data/gml.txt
   trunk/docs/references/vector_data/inline.txt
   trunk/docs/references/vector_data/introduction.txt
   trunk/docs/references/vector_data/kml.txt
   trunk/docs/references/vector_data/mapinfo.txt
   trunk/docs/references/vector_data/mygis.txt
   trunk/docs/references/vector_data/ntf.txt
   trunk/docs/references/vector_data/oracle_spatial.txt
   trunk/docs/references/vector_data/pgeo.txt
   trunk/docs/references/vector_data/postgis.txt
   trunk/docs/references/vector_data/sdts.txt
   trunk/docs/references/vector_data/shapefiles.txt
   trunk/docs/references/vector_data/tiger.txt
   trunk/docs/references/vector_data/wfs.txt
propsets
Property changes on: trunk/docs/howto/Configure Oracle and UMN.txt
___________________________________________________________________
   + Id Author Rev Date
Property changes on: trunk/docs/howto/Debian Lenny install guide.txt
Property changes on: trunk/docs/howto/FreeBSD-install.txt
Property changes on: trunk/docs/howto/PHPMapscriptAndMscross.txt
Property changes on: trunk/docs/howto/RedHat9andMapServer40.txt
Property changes on: trunk/docs/howto/Ubuntu Compilation.txt
Property changes on: trunk/docs/howto/WCSServerFormatHowTo.txt
Property changes on: trunk/docs/howto/agg-rendering-specifics.txt
Property changes on: trunk/docs/howto/antialias.txt
Property changes on: trunk/docs/howto/bug_submission.txt
Property changes on: trunk/docs/howto/building-mapserver-its-main-dependencies-from-scratches-under-linux.txt
Deleted: trunk/docs/howto/buildkit.txt
--- trunk/docs/howto/buildkit.txt	2008-11-21 15:41:53 UTC (rev 8027)
+++ trunk/docs/howto/buildkit.txt	2008-11-21 16:06:57 UTC (rev 8028)
@@ -1 +0,0 @@
-This doc will describe the windows buildkit
\ No newline at end of file
Property changes on: trunk/docs/howto/cartosymbols.txt
Property changes on: trunk/docs/howto/cgi-wrapper-script.txt
Property changes on: trunk/docs/howto/coldfusion.txt
Modified: trunk/docs/howto/compiling_on_unix.txt
--- trunk/docs/howto/compiling_on_unix.txt	2008-11-21 15:41:53 UTC (rev 8027)
+++ trunk/docs/howto/compiling_on_unix.txt	2008-11-21 16:06:57 UTC (rev 8028)
@@ -1,4 +1,4 @@
-..  $Id: compiling_on_unix,v 1.0.0 2004/09/14 00:57:25 hobu Exp $
+..  $Id$
     RULE #1: No tabs in this document!
@@ -27,8 +27,8 @@
 :Release: 4.8.4
-:Revision: $Revision: 1.2 $
-:Date: $Date: 2006/8/25 00:57:25 $
+:Revision: $Revision$
+:Date: $Date$
 :Author: J.F. Doyon
 :Contact: jdoyon at nrcan.gc.ca
 :Author: Howard Butler
Property changes on: trunk/docs/howto/compiling_on_unix.txt
Property changes on: trunk/docs/howto/debian-install.txt
Property changes on: trunk/docs/howto/debian-odbc-mysql.txt
Property changes on: trunk/docs/howto/dynamic-charting.txt
Modified: trunk/docs/howto/fastcgi.txt
--- trunk/docs/howto/fastcgi.txt	2008-11-21 15:41:53 UTC (rev 8027)
+++ trunk/docs/howto/fastcgi.txt	2008-11-21 16:06:57 UTC (rev 8028)
@@ -1,4 +1,4 @@
+..  $Id$
@@ -27,7 +27,7 @@
 :Release: 4.4.2
-:Last Updated: $Date: 2008/08/08 $
+:Last Updated: $Date$
 :Author: Frank Warmerdam and Howard Butler
 :Contact: hobu at iastate.edu
Property changes on: trunk/docs/howto/fastcgi.txt
Property changes on: trunk/docs/howto/filterencoding.txt
Property changes on: trunk/docs/howto/flash_output.txt
Property changes on: trunk/docs/howto/freebsd62mapserver410.txt
Property changes on: trunk/docs/howto/html_legend.txt
Property changes on: trunk/docs/howto/imagemaps.txt
Property changes on: trunk/docs/howto/java_mapscript_Tomcat_55.txt
Property changes on: trunk/docs/howto/javamapscript.txt
Property changes on: trunk/docs/howto/jbox.txt
Property changes on: trunk/docs/howto/mapcontext.txt
Property changes on: trunk/docs/howto/mapfiletuning.txt
Modified: trunk/docs/howto/mapscript_imagery.txt
--- trunk/docs/howto/mapscript_imagery.txt	2008-11-21 15:41:53 UTC (rev 8027)
+++ trunk/docs/howto/mapscript_imagery.txt	2008-11-21 16:06:57 UTC (rev 8028)
@@ -1,4 +1,4 @@
-.. $Id: imagery-HOWTO.txt,v 1.3 2004/11/26 14:51:56 sean Exp $
+.. $Id$
    Copyright (c) 2004 Sean Gillies.
@@ -25,8 +25,8 @@
 :Author: Sean Gillies
 :Contact: sgillies(at)frii.com
-:Revision: $Revision: 1.3 $
-:Date: $Date: 2004/11/26 14:51:56 $
+:Date: $Date$
Property changes on: trunk/docs/howto/mapscript_imagery.txt
Modified: trunk/docs/howto/mapscript_map_config.txt
--- trunk/docs/howto/mapscript_map_config.txt	2008-11-21 15:41:53 UTC (rev 8027)
+++ trunk/docs/howto/mapscript_map_config.txt	2008-11-21 16:06:57 UTC (rev 8028)
@@ -3,8 +3,8 @@
-:Revision: $Revision: 1.1 $
+:Date: $Date$
Property changes on: trunk/docs/howto/mapscript_map_config.txt
Property changes on: trunk/docs/howto/mapscript_python.txt
Modified: trunk/docs/howto/mapscript_querying.txt
--- trunk/docs/howto/mapscript_querying.txt	2008-11-21 15:41:53 UTC (rev 8027)
+++ trunk/docs/howto/mapscript_querying.txt	2008-11-21 16:06:57 UTC (rev 8028)
@@ -1,4 +1,4 @@
-..  $Id: querying-HOWTO.txt,v 1.2 2004/09/25 18:44:04 sean Exp $
+..  $Id$
     This is the mapscript querying HOWTO for mapserver 4.4.
@@ -30,8 +30,8 @@
 :Contact: sgillies at frii.com
-:Date: $Date: 2004/09/25 18:44:04 $
+:Date: $Date$
Property changes on: trunk/docs/howto/mapscript_querying.txt
Property changes on: trunk/docs/howto/mapscriptcscompile.txt
Property changes on: trunk/docs/howto/mapserver openbsd 3.7 jan 2005.txt
Property changes on: trunk/docs/howto/mapserver_compilation_on_suse_10.txt
Property changes on: trunk/docs/howto/mapserverubuntu.txt
Property changes on: trunk/docs/howto/msexpressions.txt
Property changes on: trunk/docs/howto/ogr_howto.txt
Property changes on: trunk/docs/howto/ogrmysql.txt
Property changes on: trunk/docs/howto/optimizeraster.txt
Property changes on: trunk/docs/howto/optimizevector.txt
Property changes on: trunk/docs/howto/oracle_spatial_howto.txt
Property changes on: trunk/docs/howto/pdf-output.txt
Property changes on: trunk/docs/howto/perl_examples.txt
Property changes on: trunk/docs/howto/phpmapscript-byexample.txt
Property changes on: trunk/docs/howto/phpmapscript-install.txt
Property changes on: trunk/docs/howto/raster_data.txt
Property changes on: trunk/docs/howto/runsub.txt
Property changes on: trunk/docs/howto/setupiis.txt
Property changes on: trunk/docs/howto/sldhowto.txt
Property changes on: trunk/docs/howto/sos_server.txt
Property changes on: trunk/docs/howto/suse-linux.txt
Property changes on: trunk/docs/howto/svg-howto.txt
Property changes on: trunk/docs/howto/symbologyexchange.txt
Property changes on: trunk/docs/howto/symbologyexchange_pixmap.txt
Property changes on: trunk/docs/howto/symbologyexchange_ttf.txt
Property changes on: trunk/docs/howto/symbologyexchange_vector.txt
Property changes on: trunk/docs/howto/tile_mode.txt
Property changes on: trunk/docs/howto/tileindex.txt
Property changes on: trunk/docs/howto/verboselinuxinstall.txt
Property changes on: trunk/docs/howto/vim-syntax-howto.txt
Property changes on: trunk/docs/howto/vimfolding.txt
Property changes on: trunk/docs/howto/wcs_server.txt
Property changes on: trunk/docs/howto/wfs_client.txt
Property changes on: trunk/docs/howto/wfs_server.txt
Property changes on: trunk/docs/howto/win32_compiling.txt
Property changes on: trunk/docs/howto/wms_client.txt
Property changes on: trunk/docs/howto/wms_server.txt
Property changes on: trunk/docs/howto/wms_time_support.txt
Modified: trunk/docs/howto/wxs_mapscript.txt
--- trunk/docs/howto/wxs_mapscript.txt	2008-11-21 15:41:53 UTC (rev 8027)
+++ trunk/docs/howto/wxs_mapscript.txt	2008-11-21 16:06:57 UTC (rev 8028)
@@ -1,13 +1,12 @@
-..  $Id: mapscript.txt,v 1.107 2006/07/13 20:22:36 frank Exp $
-    This is a HOWTO on using mapscript wrappers for WxS services.
  MapScript Wrappers for WxS Services
+:Author: Frank Warmerdam
+:Contact: warmerdam at pobox.com
+:Date: $Date$
 .. sectnum::
 .. contents::
Property changes on: trunk/docs/howto/wxs_mapscript.txt
Added: trunk/docs/index.txt
--- trunk/docs/index.txt	                        (rev 0)
+++ trunk/docs/index.txt	2008-11-21 16:06:57 UTC (rev 8028)
@@ -0,0 +1,19 @@
+.. MapServer documentation master file, created by sphinx-quickstart on Fri Nov 21 09:49:43 2008.
+   You can adapt this file completely to your liking, but it should at least
+   contain the root `toctree` directive.
+Welcome to MapServer's documentation!
+Contents:
+.. toctree::
+   :maxdepth: 2
+Indices and tables
+* :ref:`genindex`
+* :ref:`modindex`
+* :ref:`search`
Property changes on: trunk/docs/index.txt
Property changes on: trunk/docs/references/cgi/about.txt
Property changes on: trunk/docs/references/cgi/controls.txt
Property changes on: trunk/docs/references/cgi/introduction.txt
Property changes on: trunk/docs/references/cgi/mapcontext.txt
Property changes on: trunk/docs/references/cgi/mapserv.txt
Property changes on: trunk/docs/references/fontset/fontset.txt
Property changes on: trunk/docs/references/mapfile/Include.txt
Property changes on: trunk/docs/references/mapfile/articleinfo.txt
Property changes on: trunk/docs/references/mapfile/class.txt
Property changes on: trunk/docs/references/mapfile/feature.txt
Property changes on: trunk/docs/references/mapfile/grid.txt
Property changes on: trunk/docs/references/mapfile/introduction.txt
Property changes on: trunk/docs/references/mapfile/join.txt
Property changes on: trunk/docs/references/mapfile/label.txt
Property changes on: trunk/docs/references/mapfile/layer.txt
Property changes on: trunk/docs/references/mapfile/legend.txt
Property changes on: trunk/docs/references/mapfile/mapObj.txt
Property changes on: trunk/docs/references/mapfile/outputformat.txt
Property changes on: trunk/docs/references/mapfile/projection.txt
Property changes on: trunk/docs/references/mapfile/querymap.txt
Property changes on: trunk/docs/references/mapfile/reference.txt
Property changes on: trunk/docs/references/mapfile/scalebar.txt
Property changes on: trunk/docs/references/mapfile/style.txt
Property changes on: trunk/docs/references/mapfile/variable_sub.txt
Property changes on: trunk/docs/references/mapfile/web.txt
Modified: trunk/docs/references/mapscript/index_html.txt
--- trunk/docs/references/mapscript/index_html.txt	2008-11-21 15:41:53 UTC (rev 8027)
+++ trunk/docs/references/mapscript/index_html.txt	2008-11-21 16:06:57 UTC (rev 8028)
@@ -1,4 +1,4 @@
-..  $Id: mapscript.txt,v 1.119 2006/09/05 21:27:47 tamas Exp $
+..  $Id$
     This is the new unified mapscript documentation prepared using
     reStructured Text.
@@ -35,8 +35,8 @@
-:Revision: $Revision: 1.119 $
-:Date: $Date: 2008/07/16 21:27:47 $
+:Date: $Date$
 ..  The next heading encountered becomes our H2
Property changes on: trunk/docs/references/mapscript/index_html.txt
Property changes on: trunk/docs/references/mapscript/introduction.txt
Property changes on: trunk/docs/references/mapscript/variables.txt
Property changes on: trunk/docs/references/phpmapscript-class/class-constants.txt
Property changes on: trunk/docs/references/phpmapscript-class/class-functions.txt
Property changes on: trunk/docs/references/phpmapscript-class/class-intro.txt
Property changes on: trunk/docs/references/phpmapscript-class/javamapscript.txt
Property changes on: trunk/docs/references/symbology/examples.txt
Property changes on: trunk/docs/references/symbology/notes.txt
Property changes on: trunk/docs/references/symbology/syntax.txt
Property changes on: trunk/docs/references/systemmanage/systemmanage.txt
Property changes on: trunk/docs/references/templatereference/templatereference.txt
Property changes on: trunk/docs/references/utilityreference/available-packages.txt
Property changes on: trunk/docs/references/utilityreference/batch_utilities.txt
Property changes on: trunk/docs/references/utilityreference/legend.txt
Property changes on: trunk/docs/references/utilityreference/msencrypt.txt
Property changes on: trunk/docs/references/utilityreference/scalebar.txt
Property changes on: trunk/docs/references/utilityreference/shp2img.txt
Property changes on: trunk/docs/references/utilityreference/shptree.txt
Property changes on: trunk/docs/references/utilityreference/shptreevis.txt
Property changes on: trunk/docs/references/utilityreference/sortshp.txt
Property changes on: trunk/docs/references/utilityreference/sym2img.txt
Property changes on: trunk/docs/references/utilityreference/tile4ms.txt
Property changes on: trunk/docs/references/utilityreference/utilityreference.txt
Property changes on: trunk/docs/references/vector_data/ArcInfo.txt
Property changes on: trunk/docs/references/vector_data/S57.txt
Property changes on: trunk/docs/references/vector_data/VirtualSpatialData.txt
Property changes on: trunk/docs/references/vector_data/arcsde.txt
Property changes on: trunk/docs/references/vector_data/articleinfo.txt
Property changes on: trunk/docs/references/vector_data/dgn.txt
Property changes on: trunk/docs/references/vector_data/format_types.txt
Property changes on: trunk/docs/references/vector_data/formats_intro.txt
Property changes on: trunk/docs/references/vector_data/gml.txt
Property changes on: trunk/docs/references/vector_data/inline.txt
Property changes on: trunk/docs/references/vector_data/introduction.txt
Property changes on: trunk/docs/references/vector_data/kml.txt
Property changes on: trunk/docs/references/vector_data/mapinfo.txt
Property changes on: trunk/docs/references/vector_data/mygis.txt
Property changes on: trunk/docs/references/vector_data/ntf.txt
Property changes on: trunk/docs/references/vector_data/oracle_spatial.txt
Property changes on: trunk/docs/references/vector_data/pgeo.txt
Property changes on: trunk/docs/references/vector_data/postgis.txt
Property changes on: trunk/docs/references/vector_data/sdts.txt
Property changes on: trunk/docs/references/vector_data/shapefiles.txt
Property changes on: trunk/docs/references/vector_data/tiger.txt
Property changes on: trunk/docs/references/vector_data/wfs.txt
