[mapserver-commits] r8036 - trunk/docs/howto
svn at osgeo.org
svn at osgeo.org
Fri Nov 21 11:58:37 EST 2008
Author: hobu
Date: 2008-11-21 11:58:37 -0500 (Fri, 21 Nov 2008)
New Revision: 8036
Added:
trunk/docs/howto/ogc_mapcontext.txt
Removed:
trunk/docs/howto/mapcontext.txt
rename mapcontext file
Deleted: trunk/docs/howto/mapcontext.txt
--- trunk/docs/howto/mapcontext.txt 2008-11-21 16:58:08 UTC (rev 8035)
+++ trunk/docs/howto/mapcontext.txt 2008-11-21 16:58:37 UTC (rev 8036)
@@ -1,492 +0,0 @@
- OGC Map Context
-:Author: Jeff McKenna
-:Contact: jeffmckenna at gmail.com
-:Revision: $Revision$
-:Date: $Date$
-:Last Updated: 2008/03/20
-.. sectnum::
-.. contents::
- :depth: 2
- :backlinks: top
-Introduction
-The term 'map context' comes from the Open Geospatial Constortium's (OGC)
-`Web Map Context Specification v1.0.0`_, which coincides with the OGC `Web Map Server
-Specification (WMS) v1.1.1`_. A map context is a XML document that describes the
-appearance of layers from one or more WMS servers, and can be transferred between
-clients while maintaining startup views, the state of the view (and its layers),
-and storing additional layer information.
-Support for OGC Web Map Context was added to MapServer in version 3.7/4.0. This
-allows client applications to load and save a map configuration in a standard XML format.
-MapServer can read context documents of versions 0.1.2, 0.1.4, 0.1.7, 1.0.0, 1.1.0 and
-can export contents in versions 0.1.4, 0.1.7, 1.0.0, 1.1.0. Web Map Context 1.1.0
-support was added to MapServer 4.10
-This document assumes that you are already familiar with certain aspects of MapServer:
-- MapServer application development and setting up `mapfiles`_.
-- Familiarity with the WMS spec would be an asset. Please see the following section
- for links to associated sources.
-Links to WMS / Map Context Related Information
-- `MapServer WMS Client howto`_
-- `Open Geospatial Consortium (OGC)`_ home page
-- `WMS 1.1.1 specification`_
-- `Map Context 1.0.0 specification`_
-- `MapServer OGC Web Services Workshop`_
-Implementing a Web Map Context
-Special Build Considerations
-Map Context support requires PROJ4, GDAL/OGR and PHP support libraries.
-Build/install the above libraries on your system and then build MapServer with the
-*'--with-wmsclient --with-proj --with-ogr --with-gdal --with-php'* configure options.
-Also make sure that your build uses the *USE_WMS_LYR* and *USE_OGR* flags. For more
-details on MapServer compilation see the appropriate howto: `Unix`_ / `Windows`_
-Windows users can use `MS4W`_, which is ready for Map Context use.
-Map Context Mapfile
-A map context document can ONLY contain WMS layers (e.g. CONNECTIONTYPE WMS).
-Please refer to the `MapServer WMS Client howto`_ for more information on declaring
-WMS layers.
-MapFile Metadata
-The following mapfile metadata are used by MapServer to handle map context information:
-(Note that some parameters have width, height, format, and href, and some only
-have format and href. This is because width and height are only used for images
-and parameters that do not have them are text or html. For consistency with the
-spec MapServer supports height and width for all parameters, but they should only
-be used for images)
-Web Object Metadata
-- *ows_schemas_location* : Location of XML schema document. Default is
- http://schemas.opengeospatial.net. See http://ogc.dmsolutions.ca for an example
- of a valid schema tree.
-- *wms_abstract* : A blurb of text providing more information about the WMS server.
-- *wms_address* : If provided must also then provide wms_addresstype,
- wms_city, wms_stateorprovince, wms_postcode, and wms_country)
-- *wms_addresstype* : If provided must also then provide wms_address,
-- *wms_city* : If provided must also then provide wms_address,
- wms_addresstype, wms_stateorprovince, wms_postcode, and wms_country)
-- *wms_contactelectronicmailaddress* : contact Email address.
-- *wms_contactfacsimiletelephone* : contact facsimile telephone number.
-- *wms_contactorganization* :
-- *wms_contactperson* :
-- *wms_contactposition* :
-- *wms_contactvoicetelephone* : contact voice telephone number.
-- *wms_context_fid* : the feature id of the context. Set to 0 when saving if not
- specified.
-- *wms_context_version* : the version of the map context specification.
-- *wms_country* : If provided must also then provide wms_address, wms_city,
- wms_stateorprovince, wms_postcode, and wms_addresstype.
-- *wms_descriptionurl_format* : Format of the webpage which contains relevant
- information to the view.
-- *wms_descriptionurl_href* : Reference to a webpage which contains relevant
-- *wms_keywordlist* : A comma-separated list of keywords or keyword phrases to
- help catalog searching.
-- *wms_logourl_width* : Width of the context logo.
-- *wms_logourl_height* : Height of the context logo.
-- *wms_logourl_format* : Format of the context logo.
-- *wms_logourl_href* : Location of the context logo.
-- *wms_postcode* : If provided must also then provide wms_address,
- wms_city, wms_stateorprovince, wms_addresstype, and wms_country.
-- *wms_stateorprovince* : If provided must also then provide
- wms_address, wms_city, wms_addresstype, wms_postcode, and wms_country.
-- *wms_title* : (**Required**) A human-readable name for this Layer (this metadata does not
- exist beyond version 0.1.4)
-Layer Object Metadata
-- *wms_dataurl_href* : Link to an online resource where data corresponding to the
- layer can be found.
-- *wms_dataurl_format* : Format of the online resource where data corresponding
- to the layer can be found.
-- *wms_dimension* : Current dimension used. (added in MapServer 4.10)
-- *wms_dimensionlist* : List of available dimensions. (added in MapServer 4.10)
-- *wms_dimension_%s_default* : Default dimension value. (added in MapServer 4.10) MapServer will check for wms_time and wms_timedefault metadata when this is not specified.
- %s = the name of the dimension.
-- *wms_dimension_%s_multiplevalues* : Multiple dimension values. (added in MapServer 4.10)
-- *wms_dimension_%s_nearestvalue* : Nearest dimension value. The default value is 0. (added in MapServer 4.10)
-- *wms_dimension_%s_units* : Units for the dimension values. The default value is ISO8601. (added in MapServer 4.10)
-- *wms_dimension_%s_unitsymbol* : Symbol for dimension units. The default value is t. (added in MapServer 4.10)
-- *wms_dimension_%s_uservalue* : User dimension value. (added in MapServer 4.10) MapServer will check for wms_time and wms_timedefault metadata when this is not specified.
-- *wms_format* : Current format used.
-- *wms_formatlist* : List of available formats for this layer.
-- *wms_metadataurl_href* : Link to an online resource where descriptive metadata
- of the corresponding layer can be found.
-- *wms_metadataurl_format* : Format of the online resource where descriptive
- metadata of the corresponding layer can be found.
-- *wms_name* : Name of the WMS layer on the server.
-- *wms_onlineresource* : (**Required**) URL to access the server.
-- *wms_server_version* : The version of the web map server specification.
-- *wms_stylelist* : Current style used.
-- *wms_style_%s_legendurl_width* : Width of an image describing the style.
- %s = the name of the style.
-- *wms_style_%s_legendurl_height* : Height of an image describing the style.
-- *wms_style_%s_legendurl_format* : Format of an image describing the style.
-- *wms_style_%s_legendurl_href* : Location of an image describing the style.
-- *wms_style_%s_sld* : URL to the SLD document of this style. %s = the name
- of the style.
-- *wms_style_%s_sld_body* : SLD_BODY document of this style. %s = the name of the style.
-- *wms_style_%s_title* : Title of the layer. %s = the name of the style.
-- *wms_title* : (**Required**) A human-readable name for this Layer.
-Sample Map Context Mapfile
- NAME WMS_CONTEXT
- STATUS ON
- SIZE 400 300
- SYMBOLSET ../etc/symbols.sym
- EXTENT -2200000 -712631 3072800 3840000
- UNITS METERS
- SHAPEPATH "../data"
- IMAGECOLOR 255 255 255
- FONTSET ../etc/fonts.txt
- WEB
- IMAGEPATH "/ms4w/tmp/ms_tmp/"
- IMAGEURL "/ms_tmp/"
- METADATA
- "wms_abstract" "Demo for map context document. Blah blah..."
- "wms_title" "Map Context demo" #### REQUIRED
- END
- END
- PROJECTION
- "init=epsg:42304"
- END
- LAYER
- NAME "prov_bound"
- TYPE RASTER
- STATUS ON
- CONNECTION "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?"
- CONNECTIONTYPE WMS
- METADATA
- "wms_name" "prov_bound"
- "wms_server_version" "1.1.1"
- "wms_format" "image/gif"
- "wms_srs" "EPSG:42304"
- "wms_title" "Canadian boundaries" #### REQUIRED
- "wms_onlineresource" "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?" #### REQUIRED
- "wms_dimensionlist" "time,width"
- "wms_dimension" "time"
- "wms_dimension_time_unitsymbol" "t"
- "wms_dimension_time_units" "ISO8601"
- "wms_dimension_time_uservalue" "1310"
- "wms_dimension_time_default" "1310"
- "wms_dimension_time_multiplevalues" "1310,1410"
- "wms_dimension_time_nearestvalue" "0"
- END
- END
- LAYER
- NAME popplace
- TYPE RASTER
- STATUS ON
- METADATA
- "wms_name" "popplace"
- "wms_format" "image/png"
- "wms_title" "Canadian Cities" #### REQUIRED
- END
- END # Layer
- END # Map File
-Testing Map Context Support
-1. The first thing to do is to save your mapfile using the saveMapContext function
- available from the PHP/Mapscript library (see the `Map Object functions`_). An
- example script is shown below:
- <?php
- dl("php_mapscript.dll");
- $oMap = ms_newMapObj("gmap_wms_context.map");
- $oMap->saveMapContext("gmap_wms_context_output.xml");
-2. Scan the XML output to look for *<!-- WARNING: ... -->* comments. Then make
- the necessary changes to fix every warning that you encounter. At the end of
- this you should have a mapfile compatible with the Map Context specification.
-3. Now you can load your new Map Context document into an application using the
- *loadMapContext* function from the PHP/Mapscript library (see the
- `Map Object functions`_).
-Sample Map Context Document
-The following is a sample Map Context document:
- <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
- <ViewContext version="1.1.0" id="WMS_CONTEXT" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ogc="http://www.opengis.net/ogc" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://www.opengis.net/context" xmlns:sld="http://www.opengis.net/sld" xsi:schemaLocation="http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd">
- <General>
- <Window width="400" height="300"/>
- <!-- Bounding box corners and spatial reference system -->
- <BoundingBox SRS="EPSG:42304" minx="-2200000.000000" miny="-712631.000000" maxx="3072800.000000" maxy="3840000.000000"/>
- <!-- Title of Context -->
- <Title>Map Context demo</Title>
- <Abstract>Demo for map context document. Blah blah...</Abstract>
- <ContactInformation>
- </ContactInformation>
- </General>
- <LayerList>
- <Layer queryable="0" hidden="0">
- <Server service="OGC:WMS" version="1.1.1" title="Canadian boundaries">
- <OnlineResource xlink:type="simple" xlink:href="http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?"/>
- </Server>
- <Name>prov_bound</Name>
- <Title>Canadian boundaries</Title>
- <SRS>EPSG:42304</SRS>
- <FormatList>
- <Format current="1">image/gif</Format>
- </FormatList>
- <DimensionList>
- <Dimension name="time" units="ISO8601" unitSymbol="t" userValue="1310" default="1310" multipleValues="1310,1410" nearestValue="0" current="1"/>
- </DimensionList>
- </Layer>
- <Server service="OGC:WMS" version="1.1.1" title="Canadian Cities">
- </Server>
- <Name>popplace</Name>
- <Title>Canadian Cities</Title>
- <FormatList>
- <Format current="1">image/png</Format>
- </FormatList>
- </DimensionList>
- </Layer>
- </LayerList>
- </ViewContext>
-Map Context Support Through CGI
-MapServer CGI allows you to load a map context through the use of a CONTEXT parameter,
-and you can point this parameter to a locally stored context file or a context file
-accessible through a URL. For more information on MapServer CGI see the
-`CGI Reference`_.
-Support for Local Map Context Files
-There is a new cgi parameter called *CONTEXT* that is used to specify a local context
-file. The user can then use MapServer to request a map using the following syntax:
- http://localhost/mapserver.cgi?MODE=map&MAP=/path/to/mapfile.map&CONTEXT=
- /path/to/contextfile.xml&LAYERS=layer_name1 layers_name2
-Note that all layers created from a context file have their status set to ON. To
-be able to display layers, the user needs to add the LAYERS argument in the URL.
-Support for Context Files Accessed Through a URL
-The syntax of using a web accessible context file would be similar to accessing
-a local context file:
- http://URL/path/to/contextfile.xml&LAYERS=layers_name1 layer_name2
-Due to security concerns loading a file from a URL is disabled by default. To enable
-this functionality, the user needs to set a CONFIG parameter called *CGI_CONTEXT_URL*
-in the default mapfile that will allow this functionality. Here is an example of a
-map file with the CONFIG parameter:
- # Start of map file
- NAME map-context
- STATUS ON
- SIZE 400 300
- UNITS METERS
- IMAGETYPE png
- CONFIG "CGI_CONTEXT_URL" "1"
- WEB
- END
- LAYER
- END
- END
-Default Mapfile
-To smoothly run a MapServer CGI application with a Map Context, the application
-administrator needs to provide a default mapfile with at least the basic required
-parameters that will be used with the Context file. This default mapfile can contain
-as little information as the imagepath and imageurl or contain a list of layers.
-Information coming from the context (e.g.: layers, width, height, ...) would either
-be appended or will replace values found in the mapfile.
-Here is an example of a default map file containing the minimum required parameters:
- NAME CGI-CONTEXT-DEMO
- STATUS ON
- SIZE 400 300
- UNITS METERS
- IMAGETYPE png
- # Start of web interface definition
- WEB
- MINSCALE 2000000
- MAXSCALE 50000000
- # On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
- # of the drive where the .MAP file resides.
- END
- END # Map File
-About This Document
-Copyright Information
-Copyright (c) 2005, Jeff McKenna.
-This documentation is covered by the same Open Source license as the MapServer
-software itself. See MapServer's `License and Credits`__ page for the complete
-text.
-__ http://mapserver.gis.umn.edu/license.html
-Disclaimer
-No liability for the contents of this document can be accepted.
-Use the concepts, examples and other content at your own risk.
-As this is a new edition of this document, there may be errors
-and inaccuracies that may be damaging to your system.
-Although this is highly unlikely, the author(s) do not take any
-responsibility for that: proceed with caution.
-.. #### rST Link Section ####
-.. _`Web Map Context Specification v1.0.0`: http://www.opengeospatial.org/docs/03-036r2.pdf
-.. _`Map Context 1.0.0 specification`: http://www.opengeospatial.org/docs/03-036r2.pdf
-.. _`MapServer WMS Client howto`: http://mapserver.gis.umn.edu/docs/howto/wms_client/
-.. _`Web Map Server Specification (WMS) v1.1.1`: http://www.opengeospatial.org/docs/01-068r2.pdf
-.. _`WMS 1.1.1 specification`: http://www.opengeospatial.org/docs/01-068r2.pdf
-.. _`MapServer OGC Web Services Workshop`: http://ms-ogc-workshop.maptools.org/
-.. _`mapfiles`: http://mapserver.gis.umn.edu/docs/reference/mapfile
-.. _`Open Geospatial Consortium (OGC)`: http://www.opengeospatial.org/
-.. _`Unix`: http://mapserver.gis.umn.edu/docs/howto/compiling_on_unix/
-.. _`Windows`: http://mapserver.gis.umn.edu/docs/howto/win32_compiling/
-.. _`MS4W`: http://www.maptools.org/ms4w/
-.. _`Map Object functions`: http://mapserver.gis.umn.edu/docs/reference/phpmapscript-class/classes/mapobj/
-.. _`CGI Reference`: http://mapserver.gis.umn.edu/docs/reference/cgiedu/docs/reference/cgi
\ No newline at end of file
Copied: trunk/docs/howto/ogc_mapcontext.txt (from rev 8035, trunk/docs/howto/mapcontext.txt)
--- trunk/docs/howto/ogc_mapcontext.txt (rev 0)
+++ trunk/docs/howto/ogc_mapcontext.txt 2008-11-21 16:58:37 UTC (rev 8036)
@@ -0,0 +1,492 @@
+ OGC Map Context
+:Author: Jeff McKenna
+:Contact: jeffmckenna at gmail.com
+:Revision: $Revision$
+:Date: $Date$
+:Last Updated: 2008/03/20
+.. sectnum::
+.. contents::
+ :depth: 2
+ :backlinks: top
+Introduction
+The term 'map context' comes from the Open Geospatial Constortium's (OGC)
+`Web Map Context Specification v1.0.0`_, which coincides with the OGC `Web Map Server
+Specification (WMS) v1.1.1`_. A map context is a XML document that describes the
+appearance of layers from one or more WMS servers, and can be transferred between
+clients while maintaining startup views, the state of the view (and its layers),
+and storing additional layer information.
+Support for OGC Web Map Context was added to MapServer in version 3.7/4.0. This
+allows client applications to load and save a map configuration in a standard XML format.
+MapServer can read context documents of versions 0.1.2, 0.1.4, 0.1.7, 1.0.0, 1.1.0 and
+can export contents in versions 0.1.4, 0.1.7, 1.0.0, 1.1.0. Web Map Context 1.1.0
+support was added to MapServer 4.10
+This document assumes that you are already familiar with certain aspects of MapServer:
+- MapServer application development and setting up `mapfiles`_.
+- Familiarity with the WMS spec would be an asset. Please see the following section
+ for links to associated sources.
+Links to WMS / Map Context Related Information
+- `MapServer WMS Client howto`_
+- `Open Geospatial Consortium (OGC)`_ home page
+- `WMS 1.1.1 specification`_
+- `Map Context 1.0.0 specification`_
+- `MapServer OGC Web Services Workshop`_
+Implementing a Web Map Context
+Special Build Considerations
+Map Context support requires PROJ4, GDAL/OGR and PHP support libraries.
+Build/install the above libraries on your system and then build MapServer with the
+*'--with-wmsclient --with-proj --with-ogr --with-gdal --with-php'* configure options.
+Also make sure that your build uses the *USE_WMS_LYR* and *USE_OGR* flags. For more
+details on MapServer compilation see the appropriate howto: `Unix`_ / `Windows`_
+Windows users can use `MS4W`_, which is ready for Map Context use.
+Map Context Mapfile
+A map context document can ONLY contain WMS layers (e.g. CONNECTIONTYPE WMS).
+Please refer to the `MapServer WMS Client howto`_ for more information on declaring
+WMS layers.
+MapFile Metadata
+The following mapfile metadata are used by MapServer to handle map context information:
+(Note that some parameters have width, height, format, and href, and some only
+have format and href. This is because width and height are only used for images
+and parameters that do not have them are text or html. For consistency with the
+spec MapServer supports height and width for all parameters, but they should only
+be used for images)
+Web Object Metadata
+- *ows_schemas_location* : Location of XML schema document. Default is
+ http://schemas.opengeospatial.net. See http://ogc.dmsolutions.ca for an example
+ of a valid schema tree.
+- *wms_abstract* : A blurb of text providing more information about the WMS server.
+- *wms_address* : If provided must also then provide wms_addresstype,
+ wms_city, wms_stateorprovince, wms_postcode, and wms_country)
+- *wms_addresstype* : If provided must also then provide wms_address,
+- *wms_city* : If provided must also then provide wms_address,
+ wms_addresstype, wms_stateorprovince, wms_postcode, and wms_country)
+- *wms_contactelectronicmailaddress* : contact Email address.
+- *wms_contactfacsimiletelephone* : contact facsimile telephone number.
+- *wms_contactorganization* :
+- *wms_contactperson* :
+- *wms_contactposition* :
+- *wms_contactvoicetelephone* : contact voice telephone number.
+- *wms_context_fid* : the feature id of the context. Set to 0 when saving if not
+ specified.
+- *wms_context_version* : the version of the map context specification.
+- *wms_country* : If provided must also then provide wms_address, wms_city,
+ wms_stateorprovince, wms_postcode, and wms_addresstype.
+- *wms_descriptionurl_format* : Format of the webpage which contains relevant
+ information to the view.
+- *wms_descriptionurl_href* : Reference to a webpage which contains relevant
+- *wms_keywordlist* : A comma-separated list of keywords or keyword phrases to
+ help catalog searching.
+- *wms_logourl_width* : Width of the context logo.
+- *wms_logourl_height* : Height of the context logo.
+- *wms_logourl_format* : Format of the context logo.
+- *wms_logourl_href* : Location of the context logo.
+- *wms_postcode* : If provided must also then provide wms_address,
+ wms_city, wms_stateorprovince, wms_addresstype, and wms_country.
+- *wms_stateorprovince* : If provided must also then provide
+ wms_address, wms_city, wms_addresstype, wms_postcode, and wms_country.
+- *wms_title* : (**Required**) A human-readable name for this Layer (this metadata does not
+ exist beyond version 0.1.4)
+Layer Object Metadata
+- *wms_dataurl_href* : Link to an online resource where data corresponding to the
+ layer can be found.
+- *wms_dataurl_format* : Format of the online resource where data corresponding
+ to the layer can be found.
+- *wms_dimension* : Current dimension used. (added in MapServer 4.10)
+- *wms_dimensionlist* : List of available dimensions. (added in MapServer 4.10)
+- *wms_dimension_%s_default* : Default dimension value. (added in MapServer 4.10) MapServer will check for wms_time and wms_timedefault metadata when this is not specified.
+ %s = the name of the dimension.
+- *wms_dimension_%s_multiplevalues* : Multiple dimension values. (added in MapServer 4.10)
+- *wms_dimension_%s_nearestvalue* : Nearest dimension value. The default value is 0. (added in MapServer 4.10)
+- *wms_dimension_%s_units* : Units for the dimension values. The default value is ISO8601. (added in MapServer 4.10)
+- *wms_dimension_%s_unitsymbol* : Symbol for dimension units. The default value is t. (added in MapServer 4.10)
+- *wms_dimension_%s_uservalue* : User dimension value. (added in MapServer 4.10) MapServer will check for wms_time and wms_timedefault metadata when this is not specified.
+- *wms_format* : Current format used.
+- *wms_formatlist* : List of available formats for this layer.
+- *wms_metadataurl_href* : Link to an online resource where descriptive metadata
+ of the corresponding layer can be found.
+- *wms_metadataurl_format* : Format of the online resource where descriptive
+ metadata of the corresponding layer can be found.
+- *wms_name* : Name of the WMS layer on the server.
+- *wms_onlineresource* : (**Required**) URL to access the server.
+- *wms_server_version* : The version of the web map server specification.
+- *wms_stylelist* : Current style used.
+- *wms_style_%s_legendurl_width* : Width of an image describing the style.
+ %s = the name of the style.
+- *wms_style_%s_legendurl_height* : Height of an image describing the style.
+- *wms_style_%s_legendurl_format* : Format of an image describing the style.
+- *wms_style_%s_legendurl_href* : Location of an image describing the style.
+- *wms_style_%s_sld* : URL to the SLD document of this style. %s = the name
+ of the style.
+- *wms_style_%s_sld_body* : SLD_BODY document of this style. %s = the name of the style.
+- *wms_style_%s_title* : Title of the layer. %s = the name of the style.
+- *wms_title* : (**Required**) A human-readable name for this Layer.
+Sample Map Context Mapfile
+ NAME WMS_CONTEXT
+ STATUS ON
+ SIZE 400 300
+ SYMBOLSET ../etc/symbols.sym
+ EXTENT -2200000 -712631 3072800 3840000
+ UNITS METERS
+ SHAPEPATH "../data"
+ IMAGECOLOR 255 255 255
+ FONTSET ../etc/fonts.txt
+ WEB
+ IMAGEPATH "/ms4w/tmp/ms_tmp/"
+ IMAGEURL "/ms_tmp/"
+ METADATA
+ "wms_abstract" "Demo for map context document. Blah blah..."
+ "wms_title" "Map Context demo" #### REQUIRED
+ END
+ END
+ PROJECTION
+ "init=epsg:42304"
+ END
+ LAYER
+ NAME "prov_bound"
+ TYPE RASTER
+ STATUS ON
+ CONNECTION "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?"
+ CONNECTIONTYPE WMS
+ METADATA
+ "wms_name" "prov_bound"
+ "wms_server_version" "1.1.1"
+ "wms_format" "image/gif"
+ "wms_srs" "EPSG:42304"
+ "wms_title" "Canadian boundaries" #### REQUIRED
+ "wms_onlineresource" "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?" #### REQUIRED
+ "wms_dimensionlist" "time,width"
+ "wms_dimension" "time"
+ "wms_dimension_time_unitsymbol" "t"
+ "wms_dimension_time_units" "ISO8601"
+ "wms_dimension_time_uservalue" "1310"
+ "wms_dimension_time_default" "1310"
+ "wms_dimension_time_multiplevalues" "1310,1410"
+ "wms_dimension_time_nearestvalue" "0"
+ END
+ END
+ LAYER
+ NAME popplace
+ TYPE RASTER
+ STATUS ON
+ METADATA
+ "wms_name" "popplace"
+ "wms_format" "image/png"
+ "wms_title" "Canadian Cities" #### REQUIRED
+ END
+ END # Layer
+ END # Map File
+Testing Map Context Support
+1. The first thing to do is to save your mapfile using the saveMapContext function
+ available from the PHP/Mapscript library (see the `Map Object functions`_). An
+ example script is shown below:
+ <?php
+ dl("php_mapscript.dll");
+ $oMap = ms_newMapObj("gmap_wms_context.map");
+ $oMap->saveMapContext("gmap_wms_context_output.xml");
+2. Scan the XML output to look for *<!-- WARNING: ... -->* comments. Then make
+ the necessary changes to fix every warning that you encounter. At the end of
+ this you should have a mapfile compatible with the Map Context specification.
+3. Now you can load your new Map Context document into an application using the
+ *loadMapContext* function from the PHP/Mapscript library (see the
+ `Map Object functions`_).
+Sample Map Context Document
+The following is a sample Map Context document:
+ <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
+ <ViewContext version="1.1.0" id="WMS_CONTEXT" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ogc="http://www.opengis.net/ogc" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://www.opengis.net/context" xmlns:sld="http://www.opengis.net/sld" xsi:schemaLocation="http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd">
+ <General>
+ <Window width="400" height="300"/>
+ <!-- Bounding box corners and spatial reference system -->
+ <BoundingBox SRS="EPSG:42304" minx="-2200000.000000" miny="-712631.000000" maxx="3072800.000000" maxy="3840000.000000"/>
+ <!-- Title of Context -->
+ <Title>Map Context demo</Title>
+ <Abstract>Demo for map context document. Blah blah...</Abstract>
+ <ContactInformation>
+ </ContactInformation>
+ </General>
+ <LayerList>
+ <Layer queryable="0" hidden="0">
+ <Server service="OGC:WMS" version="1.1.1" title="Canadian boundaries">
+ <OnlineResource xlink:type="simple" xlink:href="http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?"/>
+ </Server>
+ <Name>prov_bound</Name>
+ <Title>Canadian boundaries</Title>
+ <SRS>EPSG:42304</SRS>
+ <FormatList>
+ <Format current="1">image/gif</Format>
+ </FormatList>
+ <DimensionList>
+ <Dimension name="time" units="ISO8601" unitSymbol="t" userValue="1310" default="1310" multipleValues="1310,1410" nearestValue="0" current="1"/>
+ </DimensionList>
+ </Layer>
+ <Server service="OGC:WMS" version="1.1.1" title="Canadian Cities">
+ </Server>
+ <Name>popplace</Name>
+ <Title>Canadian Cities</Title>
+ <FormatList>
+ <Format current="1">image/png</Format>
+ </FormatList>
+ </DimensionList>
+ </Layer>
+ </LayerList>
+ </ViewContext>
+Map Context Support Through CGI
+MapServer CGI allows you to load a map context through the use of a CONTEXT parameter,
+and you can point this parameter to a locally stored context file or a context file
+accessible through a URL. For more information on MapServer CGI see the
+`CGI Reference`_.
+Support for Local Map Context Files
+There is a new cgi parameter called *CONTEXT* that is used to specify a local context
+file. The user can then use MapServer to request a map using the following syntax:
+ http://localhost/mapserver.cgi?MODE=map&MAP=/path/to/mapfile.map&CONTEXT=
+ /path/to/contextfile.xml&LAYERS=layer_name1 layers_name2
+Note that all layers created from a context file have their status set to ON. To
+be able to display layers, the user needs to add the LAYERS argument in the URL.
+Support for Context Files Accessed Through a URL
+The syntax of using a web accessible context file would be similar to accessing
+a local context file:
+ http://URL/path/to/contextfile.xml&LAYERS=layers_name1 layer_name2
+Due to security concerns loading a file from a URL is disabled by default. To enable
+this functionality, the user needs to set a CONFIG parameter called *CGI_CONTEXT_URL*
+in the default mapfile that will allow this functionality. Here is an example of a
+map file with the CONFIG parameter:
+ # Start of map file
+ NAME map-context
+ STATUS ON
+ SIZE 400 300
+ UNITS METERS
+ IMAGETYPE png
+ CONFIG "CGI_CONTEXT_URL" "1"
+ WEB
+ END
+ LAYER
+ END
+ END
+Default Mapfile
+To smoothly run a MapServer CGI application with a Map Context, the application
+administrator needs to provide a default mapfile with at least the basic required
+parameters that will be used with the Context file. This default mapfile can contain
+as little information as the imagepath and imageurl or contain a list of layers.
+Information coming from the context (e.g.: layers, width, height, ...) would either
+be appended or will replace values found in the mapfile.
+Here is an example of a default map file containing the minimum required parameters:
+ NAME CGI-CONTEXT-DEMO
+ STATUS ON
+ SIZE 400 300
+ UNITS METERS
+ IMAGETYPE png
+ # Start of web interface definition
+ WEB
+ MINSCALE 2000000
+ MAXSCALE 50000000
+ # On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
+ # of the drive where the .MAP file resides.
+ END
+ END # Map File
+About This Document
+Copyright Information
+Copyright (c) 2005, Jeff McKenna.
+This documentation is covered by the same Open Source license as the MapServer
+software itself. See MapServer's `License and Credits`__ page for the complete
+text.
+__ http://mapserver.gis.umn.edu/license.html
+Disclaimer
+No liability for the contents of this document can be accepted.
+Use the concepts, examples and other content at your own risk.
+As this is a new edition of this document, there may be errors
+and inaccuracies that may be damaging to your system.
+Although this is highly unlikely, the author(s) do not take any
+responsibility for that: proceed with caution.
+.. #### rST Link Section ####
+.. _`Web Map Context Specification v1.0.0`: http://www.opengeospatial.org/docs/03-036r2.pdf
+.. _`Map Context 1.0.0 specification`: http://www.opengeospatial.org/docs/03-036r2.pdf
+.. _`MapServer WMS Client howto`: http://mapserver.gis.umn.edu/docs/howto/wms_client/
+.. _`Web Map Server Specification (WMS) v1.1.1`: http://www.opengeospatial.org/docs/01-068r2.pdf
+.. _`WMS 1.1.1 specification`: http://www.opengeospatial.org/docs/01-068r2.pdf
+.. _`MapServer OGC Web Services Workshop`: http://ms-ogc-workshop.maptools.org/
+.. _`mapfiles`: http://mapserver.gis.umn.edu/docs/reference/mapfile
+.. _`Open Geospatial Consortium (OGC)`: http://www.opengeospatial.org/
+.. _`Unix`: http://mapserver.gis.umn.edu/docs/howto/compiling_on_unix/
+.. _`Windows`: http://mapserver.gis.umn.edu/docs/howto/win32_compiling/
+.. _`MS4W`: http://www.maptools.org/ms4w/
+.. _`Map Object functions`: http://mapserver.gis.umn.edu/docs/reference/phpmapscript-class/classes/mapobj/
+.. _`CGI Reference`: http://mapserver.gis.umn.edu/docs/reference/cgiedu/docs/reference/cgi
More information about the mapserver-commits
