[mapserver-commits] r8041 - in trunk/docs: howto references/mapfile
svn at osgeo.org
svn at osgeo.org
Fri Nov 21 15:22:18 EST 2008
Author: hobu
Date: 2008-11-21 15:22:18 -0500 (Fri, 21 Nov 2008)
New Revision: 8041
Added:
trunk/docs/references/mapfile/expressions.txt
Removed:
trunk/docs/howto/msexpressions.txt
move the expressions howto into the mapfile reference
Deleted: trunk/docs/howto/msexpressions.txt
--- trunk/docs/howto/msexpressions.txt 2008-11-21 20:21:32 UTC (rev 8040)
+++ trunk/docs/howto/msexpressions.txt 2008-11-21 20:22:18 UTC (rev 8041)
@@ -1,424 +0,0 @@
- Expressions
-:Author: Dirk Tilger
-:Contact: dirk at MIRIUP.DE
-:Author: Umberto Nicoletti
-:Contact: umberto.nicoletti at gmail.com
-:Revision: $Revision$
-:Date: $Date$
-:Last Updated: 2007/07/09
-.. sectnum::
-.. contents::
- :depth: 2
- :backlinks: top
-Introduction
-As of version 4.6.1, expressions are used in two places. They're used to filter
-layers for specific records in the dataset and they're used in CLASS EXPRESSIONS
-to specify to which items this CLASS does apply to.
-Expression Types
-Expression are used to match attribute values with certain logical checks.
-There are three different types of expressions you can use with MapServer:
- * String comparisons: A single attribute is compared with a string value.
- * Regular expressions: A single attribute is matched with a regular expression.
- * Logical "MapServer expressions": One or more attributes are compared using
- logical expressions.
-String comparison
-String comparison means as the name suggests that attribute values are checked
-if they are equal to some value. String comparison are the simplest form of
-MapServer expressions and the fastest option.
-To use a string comparison for filtering a LAYER, both FILTERITEM and FILTER
-must be set. FILTERITEM is set to the attribute name. FILTER is set to the
-value for comparison. The same rule applies to CLASSITEM and EXPRESSION
-in the CLASS object.
-Example for a simple string comparison filter::
- FILTER "2005"
- FILTERITEM "year"
-would match all records that have the attribute "year" set to "2005".
-The rendered map would appear as if the dataset would only contain those items
-that have the "year" set to "2005".
-Similarly, a classification for the items matched above would be done
-by setting the CLASSITEM in the layer and the EXPRESSION in the class::
- LAYER
- NAME "example"
- CLASSITEM "year"
- CLASS
- NAME "year-2005"
- EXPRESSION "2005"
- END
- END
-For a reason explained later on the values for both CLASSITEM and FILTERITEM
-should start neither with an '/' nor with a '(' character.
-Regular expression comparison
-Regular expressions are a standard text pattern matching mechanism from the
-UNIX world. The functionality of regular expression matching is provided by
-the operating system on UNIX systems and therefore slightly operating system
-dependent. However their minimum set of features are those defined by the POSIX
-standard. The documentation of the particular regular expression library is
-usually in the "regex" manual page ("man regex").
-Regular expression with MapServer work similarly to string comparison, but
-allow more complex operation. They are slower than pure string comparisons,
-but might be still faster than logical expression. As with the string
-comparison use regular expressions, a FILTERITEM or a CLASSITEM has to
-defined, respectively.
-A regular expression typically consists of characters with special meanings
-and characters that are interpreted as they are. Alphanumeric characters
-(A-Z, a-z and 0-9) are taken as they are. Characters with special means are:
- * **.** will match a single character
- * **[** and **]** are used for grouping. For example *[A-Z]* would
- match the characters A,B,C,...,X,Y,Z.
- * **{**,**}**,**\*** are used to specify how often something should match.
- * **^** matches the beginning, **$** matches the end of the value.
- * The backslash **\\** is used to take away the special meaning.
- For example *\\$* would match the dollar sign.
-The following LAYER configuration would have all records rendered on the
-map that have "hotel" in the attribute named "placename":
-LAYER
- NAME "regexp-example"
- FILTERITEM "placename"
- FILTER /hotel/
-END
-.. note::
- Note that the regular expression is case-sensitive, thus records having
- "Hotel" in them would not have matched.
-Example: Match records that have a value for the current century
-(as of 2005 ;) in the attribute "year"
-FILTERITEM "year"
-FILTER /^20[0-9][0-9]/
-Example: Match all the records that are either purely numerical or empty
-FILTER /^[0-9]*$/
-.. note::
- When you experience frequently segmentation faults when working with
- MapServer and regular expressions, it might be that your current
- working environment is linked against more than one regular expression
- library. This can happen when MapServer is linked with components that
- bring their own copy, like the Apache httpd or PHP. In these cases
- the author has made best experiences with making all those components
- using the regular expression library of the operating system (i.e. the
- one in libc). That involved editing the build files of some of the
- components, however.
-"MapServer expressions"
-MapServer expressions are the most complex and depending how they are written
-can become quite slow. They can match any of the attributes and thus allow
-filtering and classification depending on more than one attribute. Besides
-pure logical operations there are also expressions allow also certain
-arithmetic, string- and time operations.
-To be able to use a MapServer expression for a FILTER or EXPRESSION value,
-the expression has to be finally of a logical value.
-Logical expressions
-Syntactically, a logical expression is everything encapsulated in round
-brackets. Logical expressions take logical values as their input and
-return logical values. A logical expression is either 'true' or 'false'.
- * ( ( ... ) AND ( ... ) )
- ... will become true when both of the two logical expressions in the
- innermost brackets are true.
- * ( ( ... ) OR ( ... ) )
- ... will become true when at least one of the two logical expressions
- in the innermost brackets is true.
- * NOT ( ... )
- ... will become true, when the logical expression in the brackets
- becomes false.
-String operations that result in a logical value
-Syntactically, a sting is something encapsulated in double-quotes.
- * ( "String1" eq "String2" )
- ( "String1" == "String2" )
- ( "String1" = "String2" )
- ... will become true when both strings are equal. This operation is
- identical to the MapServer string comparison described earlier.
- * ( "String1" != "String2" )
- ( "String1" ne "String2" )
- ... will become true when both strings are not equal.
- * ( "String1" < "String2" )
- ( "String1" lt "String2" )
- ... will become true when "String1" is lexicographically
- smaller than "String2"
- * ( "String1" > "String2" )
- ( "String1" gt "String2" )
- larger than "String2".
- * ( "String1" <= "String2" )
- ( "String1" le "String2" )
- ... will become true when "String1" is not lexicographically larger
- than "String2"
- * ( "String1" >= "String2" )
- ( "String1" ge "String2" )
- ... will become true when "String1" is not lexicographically smaller
- than "String2".
- * ( "String1" IN "token1,token2,...,tokenN" )
- ... will become true when "String1" is in equal one of the given tokens.
-.. note::
-The separator for those tokens is the comma. That means that you must not add
-unnecessary white space to the list and that you cannot compare to tokens
-that have a comma in it.
- * ( "String1" =~ /regexp/ )
- ... will become true, when "String1" matches the regular expression
- "regexp". This operation is identical to the regular expression matching
- described earlier.
-String operations that return string values
-There is only one operation for strings that returns a string value:
- * "String1" + "String2
- ... will return "String1String2", thus the two string concatenated to
- each other.
-Arithmetic expressions returning logical values
-The basic element for the arithmetic operation is the number. There are
-some purely arithmetic operations that are returning numbers as their value.
-They will be covered in the next section.
- * ( n1 eq n2 )
- ( n1 == n2 )
- ( n1 = n2 )
- ... will become true when both numbers are equal.
- * ( n1 != n2 )
- ( n1 ne n2 )
- ... will become true when both numbers are not equal.
- * ( n1 < n2 )
- ( n1 lt n2 )
- ... will become true when n1 is smaller than n2
- * ( n1 > n2 )
- ( n1 gt n2 )
- ... will become true when n1 is larger than n2.
- * ( n1 <= n2 )
- ( n1 le n2 )
- ... will become true when n1 is smaller or equal n2
- * ( n1 >= n2 )
- ( n1 ge n2 )
- ... will become true when n1 is larger or equal n2.
- * ( n1 IN "number1,number2,...,numberN" )
- ... will become true when n1 is equal to one of the given numbers.
-Arithmetic expression returning a number
-As stated in the previous section, MapServer can do purely numerical
-operations with numbers.
- * n1 + n2
- ... will become the sum of n1 and n2
- * n1 - n2
- ... will become n2 subtracted from n1
- * n1 \* n2
- ... will become n1 multiplicated with n2
- * n1 / n2>
- ... will become n1 divided by n2
- * -n1
- ... will become n1 with negated sign
- * n1 ^ n2
- ... will become n1 by a power of n2
- * length ( "String1" )
- ... will become the number of characters of "String1"
-.. note::
-When the numerical operations above are used like logical operations,
-the following rule applies: values equal to zero will be taken as
-'false' and everything else will be 'true'. That means the expression
-( 6 + 5 )
-would evaluate as true, but
-( 5 - 5 )
-would evaluate as false.
-Temporal expressions
-MapServer uses an internal time type to do comparison. To convert a keys
-value into this time type it will check the list below from the top down if
-the specified time matches and if so, it will do the conversion.
- * YYYY-MM-DDTHH:MM:SSZ ('Z' and 'T' being the characters itself)</i>
- * YYYY-MM-DDTHH:MM:SS ('T' being the character itself)</i>
- * YYYY-MM-DD HH:MM:SS
- * YYYY-MM-DDTHH:MM ('T' being the character itself)</i>
- * YYYY-MM-DDTHH ('T' being the character itself)</i>
- * YYYY-MM-DD HH
- * YYYY-MM-DD
- * YYYY-MM
- * YYYY
- * THH:MM:SSZ ('Z' and 'T' being the characters itself)</i>
- * THH:MM:SS
-For temporal values obtained this way, the following operations are supported:
- * ( n1 eq n2 )
- ( n1 == n2 )
- ( n1 = n2 )
- ... will become true when both times are equal.
- * ( t1 != t2 )
- ( t1 ne t2 )
- ... will become true when both times are not equal.
- * ( n1 < n2 )
- ( n1 lt n2 )
- ... will become true when t1 is earlier than t2
- * ( n1 > n2 )
- ( n1 gt n2 )
- ... will become true when t1 is later than t2.
- * ( t1 <= t2 )
- ( t1 le t2 )
- ... will become true when t1 is earlier or same t2
- * ( n1 >= n2 )
- ( n1 ge n2 )
- ... will become true when t1 is later or same t2.
-How the attributes are referenced
-To make a meaningful use of the expressions above, we need to get the attribute
-values into the expressions. That is done by enclosing the attribute key
-into square brackets, like this: [KEY]. Then before the expression is evaluated
-every occurrence of "[KEY]" will be replaced by the value for attribute "KEY".
-Example: how a simple string comparison would be evaluated. The filter is set to:
-FILTER ( "[BUILDING_NAME]" == "National Museum" )
-There is a attribute "BUILDING_NAME" and its value is "National Government
-Building". Thus the expression actually evaluated is...
-"National Government Building" == "National Museum" )
-...and as such should be false.
-Some layers do not really come with metadata. For raster layers for example
-special attributes have been defined that can be used for classification:
- * [PIXEL]
- ... will become the pixel value as number
- * [RED], [GREEN], [BLUE]
- ... will become the color value for the red, green and blue component
- in the pixel value, respectively.
-Quotes escaping in strings
-.. note::
-Quotes escaping is not supported in MapServer versions lower than 5.0.
-Starting with MapServer 5.0, if your dataset contains double-quotes, you
-can use a C-like escape sequence in the expression string. For example if your
-key *"NAME"* has the value *'National "hero" statue'* you could write the
-FILTER expression as follows:
-FILTER ( "[NAME]" == "National \"hero\" statue" )
-to escape a single quote use the following sequence instead:
-FILTER ( "[NAME]" == "National \'hero\' statue" )
Copied: trunk/docs/references/mapfile/expressions.txt (from rev 8039, trunk/docs/howto/msexpressions.txt)
--- trunk/docs/references/mapfile/expressions.txt (rev 0)
+++ trunk/docs/references/mapfile/expressions.txt 2008-11-21 20:22:18 UTC (rev 8041)
@@ -0,0 +1,424 @@
+ Expressions
+:Author: Dirk Tilger
+:Contact: dirk at MIRIUP.DE
+:Author: Umberto Nicoletti
+:Contact: umberto.nicoletti at gmail.com
+:Revision: $Revision$
+:Date: $Date$
+:Last Updated: 2007/07/09
+.. sectnum::
+.. contents::
+ :depth: 2
+ :backlinks: top
+Introduction
+As of version 4.6.1, expressions are used in two places. They're used to filter
+layers for specific records in the dataset and they're used in CLASS EXPRESSIONS
+to specify to which items this CLASS does apply to.
+Expression Types
+Expression are used to match attribute values with certain logical checks.
+There are three different types of expressions you can use with MapServer:
+ * String comparisons: A single attribute is compared with a string value.
+ * Regular expressions: A single attribute is matched with a regular expression.
+ * Logical "MapServer expressions": One or more attributes are compared using
+ logical expressions.
+String comparison
+String comparison means as the name suggests that attribute values are checked
+if they are equal to some value. String comparison are the simplest form of
+MapServer expressions and the fastest option.
+To use a string comparison for filtering a LAYER, both FILTERITEM and FILTER
+must be set. FILTERITEM is set to the attribute name. FILTER is set to the
+value for comparison. The same rule applies to CLASSITEM and EXPRESSION
+in the CLASS object.
+Example for a simple string comparison filter::
+ FILTER "2005"
+ FILTERITEM "year"
+would match all records that have the attribute "year" set to "2005".
+The rendered map would appear as if the dataset would only contain those items
+that have the "year" set to "2005".
+Similarly, a classification for the items matched above would be done
+by setting the CLASSITEM in the layer and the EXPRESSION in the class::
+ LAYER
+ NAME "example"
+ CLASSITEM "year"
+ CLASS
+ NAME "year-2005"
+ EXPRESSION "2005"
+ END
+ END
+For a reason explained later on the values for both CLASSITEM and FILTERITEM
+should start neither with an '/' nor with a '(' character.
+Regular expression comparison
+Regular expressions are a standard text pattern matching mechanism from the
+UNIX world. The functionality of regular expression matching is provided by
+the operating system on UNIX systems and therefore slightly operating system
+dependent. However their minimum set of features are those defined by the POSIX
+standard. The documentation of the particular regular expression library is
+usually in the "regex" manual page ("man regex").
+Regular expression with MapServer work similarly to string comparison, but
+allow more complex operation. They are slower than pure string comparisons,
+but might be still faster than logical expression. As with the string
+comparison use regular expressions, a FILTERITEM or a CLASSITEM has to
+defined, respectively.
+A regular expression typically consists of characters with special meanings
+and characters that are interpreted as they are. Alphanumeric characters
+(A-Z, a-z and 0-9) are taken as they are. Characters with special means are:
+ * **.** will match a single character
+ * **[** and **]** are used for grouping. For example *[A-Z]* would
+ match the characters A,B,C,...,X,Y,Z.
+ * **{**,**}**,**\*** are used to specify how often something should match.
+ * **^** matches the beginning, **$** matches the end of the value.
+ * The backslash **\\** is used to take away the special meaning.
+ For example *\\$* would match the dollar sign.
+The following LAYER configuration would have all records rendered on the
+map that have "hotel" in the attribute named "placename":
+LAYER
+ NAME "regexp-example"
+ FILTERITEM "placename"
+ FILTER /hotel/
+END
+.. note::
+ Note that the regular expression is case-sensitive, thus records having
+ "Hotel" in them would not have matched.
+Example: Match records that have a value for the current century
+(as of 2005 ;) in the attribute "year"
+FILTERITEM "year"
+FILTER /^20[0-9][0-9]/
+Example: Match all the records that are either purely numerical or empty
+FILTER /^[0-9]*$/
+.. note::
+ When you experience frequently segmentation faults when working with
+ MapServer and regular expressions, it might be that your current
+ working environment is linked against more than one regular expression
+ library. This can happen when MapServer is linked with components that
+ bring their own copy, like the Apache httpd or PHP. In these cases
+ the author has made best experiences with making all those components
+ using the regular expression library of the operating system (i.e. the
+ one in libc). That involved editing the build files of some of the
+ components, however.
+"MapServer expressions"
+MapServer expressions are the most complex and depending how they are written
+can become quite slow. They can match any of the attributes and thus allow
+filtering and classification depending on more than one attribute. Besides
+pure logical operations there are also expressions allow also certain
+arithmetic, string- and time operations.
+To be able to use a MapServer expression for a FILTER or EXPRESSION value,
+the expression has to be finally of a logical value.
+Logical expressions
+Syntactically, a logical expression is everything encapsulated in round
+brackets. Logical expressions take logical values as their input and
+return logical values. A logical expression is either 'true' or 'false'.
+ * ( ( ... ) AND ( ... ) )
+ ... will become true when both of the two logical expressions in the
+ innermost brackets are true.
+ * ( ( ... ) OR ( ... ) )
+ ... will become true when at least one of the two logical expressions
+ in the innermost brackets is true.
+ * NOT ( ... )
+ ... will become true, when the logical expression in the brackets
+ becomes false.
+String operations that result in a logical value
+Syntactically, a sting is something encapsulated in double-quotes.
+ * ( "String1" eq "String2" )
+ ( "String1" == "String2" )
+ ( "String1" = "String2" )
+ ... will become true when both strings are equal. This operation is
+ identical to the MapServer string comparison described earlier.
+ * ( "String1" != "String2" )
+ ( "String1" ne "String2" )
+ ... will become true when both strings are not equal.
+ * ( "String1" < "String2" )
+ ( "String1" lt "String2" )
+ ... will become true when "String1" is lexicographically
+ smaller than "String2"
+ * ( "String1" > "String2" )
+ ( "String1" gt "String2" )
+ larger than "String2".
+ * ( "String1" <= "String2" )
+ ( "String1" le "String2" )
+ ... will become true when "String1" is not lexicographically larger
+ than "String2"
+ * ( "String1" >= "String2" )
+ ( "String1" ge "String2" )
+ ... will become true when "String1" is not lexicographically smaller
+ than "String2".
+ * ( "String1" IN "token1,token2,...,tokenN" )
+ ... will become true when "String1" is in equal one of the given tokens.
+.. note::
+The separator for those tokens is the comma. That means that you must not add
+unnecessary white space to the list and that you cannot compare to tokens
+that have a comma in it.
+ * ( "String1" =~ /regexp/ )
+ ... will become true, when "String1" matches the regular expression
+ "regexp". This operation is identical to the regular expression matching
+ described earlier.
+String operations that return string values
+There is only one operation for strings that returns a string value:
+ * "String1" + "String2
+ ... will return "String1String2", thus the two string concatenated to
+ each other.
+Arithmetic expressions returning logical values
+The basic element for the arithmetic operation is the number. There are
+some purely arithmetic operations that are returning numbers as their value.
+They will be covered in the next section.
+ * ( n1 eq n2 )
+ ( n1 == n2 )
+ ( n1 = n2 )
+ ... will become true when both numbers are equal.
+ * ( n1 != n2 )
+ ( n1 ne n2 )
+ ... will become true when both numbers are not equal.
+ * ( n1 < n2 )
+ ( n1 lt n2 )
+ ... will become true when n1 is smaller than n2
+ * ( n1 > n2 )
+ ( n1 gt n2 )
+ ... will become true when n1 is larger than n2.
+ * ( n1 <= n2 )
+ ( n1 le n2 )
+ ... will become true when n1 is smaller or equal n2
+ * ( n1 >= n2 )
+ ( n1 ge n2 )
+ ... will become true when n1 is larger or equal n2.
+ * ( n1 IN "number1,number2,...,numberN" )
+ ... will become true when n1 is equal to one of the given numbers.
+Arithmetic expression returning a number
+As stated in the previous section, MapServer can do purely numerical
+operations with numbers.
+ * n1 + n2
+ ... will become the sum of n1 and n2
+ * n1 - n2
+ ... will become n2 subtracted from n1
+ * n1 \* n2
+ ... will become n1 multiplicated with n2
+ * n1 / n2>
+ ... will become n1 divided by n2
+ * -n1
+ ... will become n1 with negated sign
+ * n1 ^ n2
+ ... will become n1 by a power of n2
+ * length ( "String1" )
+ ... will become the number of characters of "String1"
+.. note::
+When the numerical operations above are used like logical operations,
+the following rule applies: values equal to zero will be taken as
+'false' and everything else will be 'true'. That means the expression
+( 6 + 5 )
+would evaluate as true, but
+( 5 - 5 )
+would evaluate as false.
+Temporal expressions
+MapServer uses an internal time type to do comparison. To convert a keys
+value into this time type it will check the list below from the top down if
+the specified time matches and if so, it will do the conversion.
+ * YYYY-MM-DDTHH:MM:SSZ ('Z' and 'T' being the characters itself)</i>
+ * YYYY-MM-DDTHH:MM:SS ('T' being the character itself)</i>
+ * YYYY-MM-DD HH:MM:SS
+ * YYYY-MM-DDTHH:MM ('T' being the character itself)</i>
+ * YYYY-MM-DDTHH ('T' being the character itself)</i>
+ * YYYY-MM-DD HH
+ * YYYY-MM-DD
+ * YYYY-MM
+ * YYYY
+ * THH:MM:SSZ ('Z' and 'T' being the characters itself)</i>
+ * THH:MM:SS
+For temporal values obtained this way, the following operations are supported:
+ * ( n1 eq n2 )
+ ( n1 == n2 )
+ ( n1 = n2 )
+ ... will become true when both times are equal.
+ * ( t1 != t2 )
+ ( t1 ne t2 )
+ ... will become true when both times are not equal.
+ * ( n1 < n2 )
+ ( n1 lt n2 )
+ ... will become true when t1 is earlier than t2
+ * ( n1 > n2 )
+ ( n1 gt n2 )
+ ... will become true when t1 is later than t2.
+ * ( t1 <= t2 )
+ ( t1 le t2 )
+ ... will become true when t1 is earlier or same t2
+ * ( n1 >= n2 )
+ ( n1 ge n2 )
+ ... will become true when t1 is later or same t2.
+How the attributes are referenced
+To make a meaningful use of the expressions above, we need to get the attribute
+values into the expressions. That is done by enclosing the attribute key
+into square brackets, like this: [KEY]. Then before the expression is evaluated
+every occurrence of "[KEY]" will be replaced by the value for attribute "KEY".
+Example: how a simple string comparison would be evaluated. The filter is set to:
+FILTER ( "[BUILDING_NAME]" == "National Museum" )
+There is a attribute "BUILDING_NAME" and its value is "National Government
+Building". Thus the expression actually evaluated is...
+"National Government Building" == "National Museum" )
+...and as such should be false.
+Some layers do not really come with metadata. For raster layers for example
+special attributes have been defined that can be used for classification:
+ * [PIXEL]
+ ... will become the pixel value as number
+ * [RED], [GREEN], [BLUE]
+ ... will become the color value for the red, green and blue component
+ in the pixel value, respectively.
+Quotes escaping in strings
+.. note::
+Quotes escaping is not supported in MapServer versions lower than 5.0.
+Starting with MapServer 5.0, if your dataset contains double-quotes, you
+can use a C-like escape sequence in the expression string. For example if your
+key *"NAME"* has the value *'National "hero" statue'* you could write the
+FILTER expression as follows:
+FILTER ( "[NAME]" == "National \"hero\" statue" )
+to escape a single quote use the following sequence instead:
+FILTER ( "[NAME]" == "National \'hero\' statue" )
More information about the mapserver-commits
