[mapserver-commits] r8055 - trunk/docs/howto
svn at osgeo.org
svn at osgeo.org
Sun Nov 23 14:52:15 EST 2008
Author: hobu
Date: 2008-11-23 14:52:15 -0500 (Sun, 23 Nov 2008)
New Revision: 8055
trunk/docs/howto/cgi-wrapper-script.txt
convert to ReST. Thanks crschmidt\!
Modified: trunk/docs/howto/cgi-wrapper-script.txt
--- trunk/docs/howto/cgi-wrapper-script.txt 2008-11-23 19:37:58 UTC (rev 8054)
+++ trunk/docs/howto/cgi-wrapper-script.txt 2008-11-23 19:52:15 UTC (rev 8055)
@@ -1,22 +1,66 @@
-<p>If you want to avoid having to specify the 'map' parameter in your MapServer URLs, one solution is to use a "wrapper". Basically, a wrapper is a CGI program that receives an incoming CGI request, modifies the request parameters in some way, and then hands off the actual processing to another CGI program (e.g. MapServer).</p>
-<p>The following shell script is a wrapper for CGI GET requests that should be generic enough to run on any OS with /bin/sh:</p>
-<pre>
-#!/bin/sh
-MAPSERV="/path/to/my/mapserv"
-MAPFILE="/path/to/my/mapfile.map"
-if [ "${REQUEST_METHOD}" = "GET" ]; then
- if [ -z "${QUERY_STRING}" ]; then
- QUERY_STRING="map=${MAPFILE}"
- else
- QUERY_STRING="map=${MAPFILE}&${QUERY_STRING}"
- fi
- exec ${MAPSERV}
-else
- echo "Sorry, I only understand GET requests."
-fi
-exit 1
-# End of Script
-</pre>
-<p>You should set the MAPSERV and MAPFILE variables as appropriate for your configuration. MAPSERV points to your MapServer executable, and MAPFILE points to the mapfile you want MapServer to use. Both variables should be absolute file paths that your webserver has permission to access, although they need not (and probably should not) be in web-accessible locations. Then put the script in your web server's cgi-bin directory, and make it executable.</p>
-<p>Although this script only sets the 'map' parameter, it is easily modified to set any number of other MapServer parameters as well. For example, if you want to force your MapServer to 'map' mode, you can simply add 'mode=map' to the front of the QUERY_STRING variable. Just remember to separate your parameters with ampersands ('&').</p>
-<p>Finally, note that the script only works for GET requests, which has always been good enough for me. I haven't ever needed POST capability, so I don't know offhand how to modify the script to handle POST requests. Maybe someone else can chime in with a solution.</p>
\ No newline at end of file
+ A Simple CGI Wrapper Script
+:Author: Steven Monai
+:Revision: $Revision$
+:Date: $Date$
+:Last Updated: 2006/01/26
+.. sectnum::
+.. contents:: Table of Contents
+ :depth: 2
+ :backlinks: top
+Introduction
+This document presents a simple shell script that can be used to "wrap" the
+MapServer CGI, in order to avoid having to specify the 'map' parameter (or any
+other chosen parameters) in your MapServer URLs.
+Script Information
+If you want to avoid having to specify the 'map' parameter in your MapServer
+URLs, one solution is to use a "wrapper". Basically, a wrapper is a CGI program
+that receives an incoming CGI request, modifies the request parameters in some
+way, and then hands off the actual processing to another CGI program (e.g.
+MapServer).
+The following shell script is a wrapper for CGI GET requests that should be
+generic enough to run on any OS with /bin/sh:
+ #!/bin/sh
+ MAPSERV="/path/to/my/mapserv"
+ MAPFILE="/path/to/my/mapfile.map"
+ if [ "${REQUEST_METHOD}" = "GET" ]; then
+ if [ -z "${QUERY_STRING}" ]; then
+ QUERY_STRING="map=${MAPFILE}"
+ else
+ QUERY_STRING="map=${MAPFILE}&${QUERY_STRING}"
+ fi
+ exec ${MAPSERV}
+ else
+ echo "Sorry, I only understand GET requests."
+ fi
+ exit 1
+ # End of Script
+You should set the MAPSERV and MAPFILE variables as appropriate for your
+configuration. MAPSERV points to your MapServer executable, and MAPFILE points
+to the mapfile you want MapServer to use. Both variables should be absolute
+file paths that your webserver has permission to access, although they need not
+(and probably should not) be in web-accessible locations. Then put the script
+in your web server's cgi-bin directory, and make it executable.
+Although this script only sets the 'map' parameter, it is easily modified to
+set any number of other MapServer parameters as well. For example, if you want
+to force your MapServer to 'map' mode, you can simply add 'mode=map' to the
+front of the QUERY_STRING variable. Just remember to separate your parameters
+with ampersands ('&').
+Finally, note that the script only works for GET requests.
More information about the mapserver-commits
