[mapserver-commits] r8058 - trunk/docs/howto
svn at osgeo.org
svn at osgeo.org
Sun Nov 23 15:02:50 EST 2008
Author: hobu
Date: 2008-11-23 15:02:50 -0500 (Sun, 23 Nov 2008)
New Revision: 8058
trunk/docs/howto/agg-rendering-specifics.txt
tweak ReST
Modified: trunk/docs/howto/agg-rendering-specifics.txt
--- trunk/docs/howto/agg-rendering-specifics.txt 2008-11-23 19:54:44 UTC (rev 8057)
+++ trunk/docs/howto/agg-rendering-specifics.txt 2008-11-23 20:02:50 UTC (rev 8058)
@@ -1,14 +1,23 @@
+ AGG Rendering Specifics
-:Author: Thomas Bonfort
-:Contact: thomas.bonfort(at)gmail
+:Author: Thomas Bonfort
+:Contact: thomas.bonfort at gmail
+:Revision: $Revision$
+:Date: $Date$
:Last Updated: 2007/08/21
+.. sectnum::
+.. contents:: Table of Contents
+ :depth: 2
+ :backlinks: top
Introduction
-Mapserver 5.0 will be released with a new rendering backend. This howto details the changes and new functionality that this adds to map creation. This howto supposes
+Mapserver 5.0 will be released with a new rendering backend. This howto details
+the changes and new functionality that this adds to map creation. This howto supposes
you already now the basics of mapfile syntax. If not, you should probably be reading
`the mapfile syntax </docs/reference/mapfile>`__.
@@ -45,10 +54,11 @@
IMAGEMODE RGB
END
-png output, with number of colors reduced with quantization . ( **Note**: this functionality
-is not supported with RGBA images, that is outputformats with IMAGEMODE RGBA,
-or maps with TRANSPARENT ON ) :
+png output, with number of colors reduced with quantization . (
+.. note:: this functionality is not supported with RGBA images, that
+is outputformats with IMAGEMODE RGBA, or maps with TRANSPARENT ON.
OUTPUTFORMAT
@@ -62,11 +72,12 @@
New Features
-* All rendering is now done antialiased by default. All ANTIALIAS keywords are now ignored, as well as
- TRANSPARENCY ALPHA. Pixmaps and fonts are now all drawn respecting the image's internal alpha channel
- (unless a backgroundcolor is specified).
-* As with GD in ver. 4.10, using a SYMBOL of type ELLIPSE to draw thick lines isn't mandatory anymore.
- To draw a thick line just use:
+* All rendering is now done antialiased by default. All ANTIALIAS keywords
+ are now ignored, as well as TRANSPARENCY ALPHA. Pixmaps and fonts are now
+ all drawn respecting the image's internal alpha channel (unless a
+ backgroundcolor is specified).
+* As with GD in ver. 4.10, using a SYMBOL of type ELLIPSE to draw thick
+ lines isn't mandatory anymore. To draw a thick line just use:
@@ -75,31 +86,38 @@
COLOR 0 0 255
END
-* A line symbolizer has been added, that works with vector or pixmap symbols, to draw textured lines.
- This happens by default if a line's style is given a symbol of type vector or pixmap. To enable "shield"
- symbolization, i.e. a marker placed only on some points of the line, you must add a GAP parameter to your
- symbol definition. This GAP value is scaled w.r.t the style's SIZE parameter. Specify a positive gap value
- for symbols always facing north (optionally rotated by the ANGLE of the current style), or a negative
- value for symbols that should follow the line orientation
+* A line symbolizer has been added, that works with vector or pixmap
+ symbols, to draw textured lines. This happens by default if a line's style
+ is given a symbol of type vector or pixmap. To enable "shield" symbolization,
+ i.e. a marker placed only on some points of the line, you must add a GAP
+ parameter to your symbol definition. This GAP value is scaled w.r.t the
+ style's SIZE parameter. Specify a positive gap value for symbols always
+ facing north (optionally rotated by the ANGLE of the current style), or
+ a negative value for symbols that should follow the line orientation
.. image:: /docs/howto/agg-rendering-specifics/linesymbolization.png
* This happens by default if a line's style is given a symbol of type vector
- or pixmap. To enable "shield" symbolization, i.e. a marker placed only on some points of the line, you
- must add a GAP parameter to your symbol definition. This GAP value is scaled w.r.t the style's SIZE parameter
- - specify a positive gap value for symbols always facing north (optionally rotated by the ANGLE of the
- current style), or a negative value for symbols that should follow the line orientation
+ or pixmap. To enable "shield" symbolization, i.e. a marker placed only on
+ some points of the line, you must add a GAP parameter to your symbol
+ definition. This GAP value is scaled w.r.t the style's SIZE parameter -
+ specify a positive gap value for symbols always facing north (optionally
+ rotated by the ANGLE of the current style), or a negative value for symbols
+ that should follow the line orientation
* Pixmap and font symbols can now be rotated without loosing their transparency
-* For POLYGON layers with no specific SYMBOL, the WIDTH keyword specifies the width of the outline, if an
- OUTLINECOLOR was specified. This is a shorthand that avoids having to create multiple styles for basic
- rendering, and will provide a marginal performance gain. Note that in this case, the width of the outline
- is /not/ scale dependent.
+* For POLYGON layers with no specific SYMBOL, the WIDTH keyword specifies the
+ width of the outline, if an OUTLINECOLOR was specified. This is a shorthand
+ that avoids having to create multiple styles for basic rendering, and will
+ provide a marginal performance gain. Note that in this case, the width of
+ the outline is /not/ scale dependent.
Modified Behavior
-* When specifying a SYMBOL for a polygon shape, the GAP parameter of the symbol is used as a separation between
- each rendered symbol. This works for symbols of type vector, pixmap and ellipse. For example a symbol defined by
+* When specifying a SYMBOL for a polygon shape, the GAP parameter of the
+ symbol is used as a separation between each rendered symbol. This works for
+ symbols of type vector, pixmap and ellipse. For example a symbol defined by
SYMBOL
@@ -120,4 +138,5 @@
.. image:: solid-symbol-gap
* layers of type CIRCLE support hatch type symbol filling
-* the ENCODING keyword for labels is now enforced. If unset, mapserver will treat your label text byte-by-byte (resulting in corrupt special characters).
\ No newline at end of file
+* the ENCODING keyword for labels is now enforced. If unset, mapserver will
+ treat your label text byte-by-byte (resulting in corrupt special characters).
More information about the mapserver-commits
