[mapserver-commits] r8085 - in trunk/docs: images references/mapfile/symbology
Mon Nov 24 19:06:34 EST 2008
Author: hobu
Date: 2008-11-24 19:06:34 -0500 (Mon, 24 Nov 2008)
New Revision: 8085
Added:
   trunk/docs/images/carto-elements.png
   trunk/docs/images/linesymbolization.png
Removed:
   trunk/docs/images/carto-elements.png.png
   trunk/docs/images/linesymbolization.png.png
   trunk/docs/references/mapfile/symbology/construction.txt
fix up locations of images for cartosymbols doc
Copied: trunk/docs/images/carto-elements.png (from rev 8082, trunk/docs/images/carto-elements.png.png)
(Binary files differ)
Deleted: trunk/docs/images/carto-elements.png.png
Copied: trunk/docs/images/linesymbolization.png (from rev 8082, trunk/docs/images/linesymbolization.png.png)
Deleted: trunk/docs/images/linesymbolization.png.png
Modified: trunk/docs/references/mapfile/symbology/construction.txt
--- trunk/docs/references/mapfile/symbology/construction.txt	2008-11-24 20:35:44 UTC (rev 8084)
+++ trunk/docs/references/mapfile/symbology/construction.txt	2008-11-25 00:06:34 UTC (rev 8085)
@@ -115,7 +115,7 @@
 **Figure1: Structure of Cartographic Symbols`**
-.. image:: /docs/howto/cartosymbols/carto-elements.png
+.. image:: ../../../images/carto-elements.png
    :height: 400
    :width: 600
@@ -146,7 +146,7 @@
 **Figure2: Schema showing interaction of MAP and SYMBOL file**
-.. image:: /docs/howto/cartosymbols/map-symbolfile-interaction/
+.. image:: ../../../images/map-symbolfile-interaction.png
 Using Cartographic Symbols in UMN MapServer
@@ -233,7 +233,7 @@
 **Figure3: Construction of Point Symbols**
-.. image:: /docs/howto/cartosymbols/point-symbols/
+.. image:: ../../../images/point-symbols.png
    :height: 400
    :width: 600
@@ -251,7 +251,7 @@
 **Figure4: Construction of Line Symbols**
-.. image:: /docs/howto/cartosymbols/line-symbols/
+.. image:: ../../../images/line-symbols.png
    :height: 400
    :width: 600
@@ -292,7 +292,7 @@
 |                                  |    END                          |
 |                                  |  END                            |
-|  .. image:: /docs/howto/cartosymbols/railway/                      |
+|  .. image:: ../../../images/railway.png                            |
 The STYLE parameter can be used for elements of the SYMBOL file with the
@@ -341,7 +341,7 @@
 |                                |                               |    END                         |                               |
 |                                |                               |  END                           |                               |
-| .. image:: /docs/howto/cartosymbols/symbol-offset-1/           | .. image:: /docs/howto/cartosymbols/symbol-offset-1/           |
+| .. image:: ../../../images/symbol-offset-1.png                 | .. image:: ../../../images/symbol-offset-1.png                 |
 |    :align: right                                               |    :align: right                                               |
@@ -391,7 +391,7 @@
 |                                |    END                        |
 |                                |  END                          |
-| .. image:: /docs/howto/cartosymbols/crosshatch/                |
+| .. image:: ../../../images/crosshatch.png                      |
 |    :align: right                                               |
@@ -427,13 +427,13 @@
 **Figure5: Raster image for a regular polygon symbol fill**
-.. image:: /docs/howto/cartosymbols/polygon-symbol-fill/
+.. image:: ../../../images/polygon-symbol-fill.png
    :height: 400
    :width: 600
 **Figure6: Raster image for a hatched fill**
-.. image:: /docs/howto/cartosymbols/hatch-symbol-fill/
+.. image:: ../../../images/hatch-symbol-fill.png
    :height: 400
    :width: 600
@@ -473,11 +473,11 @@
 |    STYLE                       |    TRANSPARENT 8                                |
 |      SYMBOL "in_the_star"      |  END                                            |
 |      COLOR 0 0 0               |                                                 |
-|      OUTLINECOLOR 0 0 0        |.. image:: /docs/howto/cartosymbols/star-symbol/ |
+|      OUTLINECOLOR 0 0 0        |.. image:: ../../../images/star-symbol.png       |
 |    END                         |   :align: left                                  |
 |  END                           |                                                 |
-| .. image:: /docs/howto/cartosymbols/horizontal-area-symbol/                      |
+| .. image:: ../../../images/horizontal-area-symbol.png                            |
 |    :align: right        |
@@ -495,10 +495,10 @@
 |      OUTLINECOLOR 0 0 0        |    TRANSPARENT 13                               |
 |    END                         |  END                                            |
 |  END                           |                                                 |
-|                                |.. image:: /docs/howto/cartosymbols/dot-symbol/  |
+|                                |.. image:: ../../../images/dot-symbol.png        |
 |                                |   :align: left                                  |
-| .. image:: /docs/howto/cartosymbols/diagonal-area-symbol/                        |
+| .. image:: ../../../images/diagonal-area-symbol.png                              |
 |    :align: right        |
@@ -516,11 +516,11 @@
 |    STYLE                       |    TRANSPARENT 2                                |
 |      SYMBOL "in_hatch"         |  END                                            |
 |      COLOR 0 0 0               |                                                 |
-|      OUTLINECOLOR 0 0 0        |.. image:: /docs/howto/cartosymbols/hatch/       |
+|      OUTLINECOLOR 0 0 0        |.. image:: ../../../images/hatch.png             |
 |  END                           |                                                 |
-| .. image:: /docs/howto/cartosymbols/hatch-symbol/                                |
+| .. image:: ../../../images/hatch-symbol.png                                      |
 |    :align: right        |
@@ -565,10 +565,10 @@
 (see the following figure).  Default is 'not set' but do not specify the string
 'not set', just omit the parameter LINEJOIN.
-.. image:: /docs/howto/cartosymbols/linejoin/
+.. image:: ../../../images/linejoin.png
 Miter
-  follow line borders untill they intersect, fill the resulting area.
+  follow line borders until they intersect, fill the resulting area.
 Round
   see above
@@ -579,7 +579,7 @@
 None
   Lines will not be connected but drawn with LINECAPP 'butt' at the respective ends.
-.. image:: /docs/howto/cartosymbols/miter-linejoin/
+.. image:: ../../../images/miter-linejoin.png
 LINEJOINMAXSIZE
@@ -645,10 +645,10 @@
 |                                |  END                                            |
-| .. image:: /docs/howto/cartosymbols/truetype-character-clockwise/                |
+| .. image:: ../../../images/truetype-character-clockwise.png                      |
 |    :align: left        |
 |    :alt: clockwise                                                               |
-| .. image:: /docs/howto/cartosymbols/truetype-character-cc/                       |
+| .. image:: ../../../images/truetype-character-cc.png                             |
 |    :align: right        |
 |    :alt: counterclockwise                                                        |
@@ -675,20 +675,20 @@
 Basic Symbols
-.. image:: /docs/howto/cartosymbols/point-symbol-examples/
+.. image:: ../../../images/point-symbol-examples.png
-.. image:: /docs/howto/cartosymbols/line-symbol-examples/
+.. image:: ../../../images/line-symbol-examples.png
-.. image:: /docs/howto/cartosymbols/pattern-symbol-examples/
+.. image:: ../../../images/pattern-symbol-examples.png
 Complex Symbols
-.. image:: /docs/howto/cartosymbols/point-symbol-complex/
+.. image:: ../../../images/point-symbol-complex.png
-.. image:: /docs/howto/cartosymbols/line-symbol-complex/
+.. image:: ../../../images/line-symbol-complex.png
-.. image:: /docs/howto/cartosymbols/pattern-symbol-complex/
+.. image:: ../../../images/pattern-symbol-complex.png
 Current Problems / Open Issues
@@ -724,7 +724,7 @@
 |                                |    END                                          |
 |                                |  END                                            |
-| .. image:: /docs/howto/cartosymbols/cross-fill-example/                          |
+| .. image:: ../../../images/cross-fill-example.png                                |
 |    :align: right        |
@@ -752,7 +752,7 @@
 |                                |    FILLED TRUE                                  |
 |                                |  END                                            |
-| .. image:: /docs/howto/cartosymbols/irregular-line-pattern/                      |
+| .. image:: ../../../images/irregular-line-pattern.png                            |
 |    :align: right        |
@@ -773,28 +773,3 @@
 You can also view the `discussion paper for the improvement of the MapServer Graphic-Kernel`_ (sorry as yet German only).
 .. _`Discussion paper for the improvement of the MapServer Graphic-Kernel`: http://www.mapmedia.de/dokumente/umn_signaturen_howto/DiskussionsPaper-UMNGraphikKernel.pdf
-About This Document
-Copyright Information
-Copyright (c) 2005, Jeff McKenna.
-This documentation is covered by the same Open Source license as the MapServer
-software itself.  See MapServer's `License and Credits`__ page for the complete
-text.
-__ http://ms.gis.umn.edu/License
-Disclaimer
-No liability for the contents of this document can be accepted.
-Use the concepts, examples and other content at your own risk.
-As this is a new edition of this document, there may be errors
-and inaccuracies that may be damaging to your system.
-Although this is highly unlikely, the author(s) do not take any
-responsibility for that:  proceed with caution.
