[mapserver-commits] r8126 - trunk/docs/rfc
svn at osgeo.org
svn at osgeo.org
Wed Nov 26 14:55:13 EST 2008
Author: hobu
Date: 2008-11-26 14:55:13 -0500 (Wed, 26 Nov 2008)
New Revision: 8126
trunk/docs/rfc/ms-rfc-1.txt
trunk/docs/rfc/ms-rfc-10.txt
trunk/docs/rfc/ms-rfc-11.txt
trunk/docs/rfc/ms-rfc-12.txt
trunk/docs/rfc/ms-rfc-13.txt
trunk/docs/rfc/ms-rfc-14.txt
trunk/docs/rfc/ms-rfc-15.txt
trunk/docs/rfc/ms-rfc-16.txt
trunk/docs/rfc/ms-rfc-17.txt
trunk/docs/rfc/ms-rfc-18.txt
trunk/docs/rfc/ms-rfc-19.txt
trunk/docs/rfc/ms-rfc-2.txt
trunk/docs/rfc/ms-rfc-21.txt
trunk/docs/rfc/ms-rfc-22a.txt
trunk/docs/rfc/ms-rfc-23.txt
trunk/docs/rfc/ms-rfc-24-FIRSTDRAFT.txt
trunk/docs/rfc/ms-rfc-24.txt
trunk/docs/rfc/ms-rfc-25.txt
trunk/docs/rfc/ms-rfc-26.txt
trunk/docs/rfc/ms-rfc-27.txt
trunk/docs/rfc/ms-rfc-28.txt
trunk/docs/rfc/ms-rfc-29.txt
trunk/docs/rfc/ms-rfc-3.txt
trunk/docs/rfc/ms-rfc-30.txt
trunk/docs/rfc/ms-rfc-31.txt
trunk/docs/rfc/ms-rfc-32.txt
trunk/docs/rfc/ms-rfc-33.txt
trunk/docs/rfc/ms-rfc-34.txt
trunk/docs/rfc/ms-rfc-35.txt
trunk/docs/rfc/ms-rfc-36.txt
trunk/docs/rfc/ms-rfc-37.txt
trunk/docs/rfc/ms-rfc-38.txt
trunk/docs/rfc/ms-rfc-39.txt
trunk/docs/rfc/ms-rfc-4.txt
trunk/docs/rfc/ms-rfc-40.txt
trunk/docs/rfc/ms-rfc-41.txt
trunk/docs/rfc/ms-rfc-42.txt
trunk/docs/rfc/ms-rfc-43.txt
trunk/docs/rfc/ms-rfc-44.txt
trunk/docs/rfc/ms-rfc-45.txt
trunk/docs/rfc/ms-rfc-46.txt
trunk/docs/rfc/ms-rfc-47.txt
trunk/docs/rfc/ms-rfc-48.txt
trunk/docs/rfc/ms-rfc-5.txt
trunk/docs/rfc/ms-rfc-6.txt
trunk/docs/rfc/ms-rfc-7.1.txt
trunk/docs/rfc/ms-rfc-7.txt
trunk/docs/rfc/ms-rfc-8.txt
trunk/docs/rfc/ms-rfc-9.txt
set properties
Modified: trunk/docs/rfc/ms-rfc-1.txt
--- trunk/docs/rfc/ms-rfc-1.txt 2008-11-26 17:20:46 UTC (rev 8125)
+++ trunk/docs/rfc/ms-rfc-1.txt 2008-11-26 19:55:13 UTC (rev 8126)
@@ -6,7 +6,7 @@
:Author: Frank Warmerdam, Independent
:Contact: warmerdam at pobox.com
:Last Edited: $Date$
-:Status: Superceeded by RFC 23
+:Status: Superseded by RFC 23
Summary
Property changes on: trunk/docs/rfc/ms-rfc-1.txt
___________________________________________________________________
- Author Date Id Revision
+ Id Rev Author Date
Property changes on: trunk/docs/rfc/ms-rfc-10.txt
Property changes on: trunk/docs/rfc/ms-rfc-11.txt
Property changes on: trunk/docs/rfc/ms-rfc-12.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-13.txt
Property changes on: trunk/docs/rfc/ms-rfc-14.txt
Modified: trunk/docs/rfc/ms-rfc-15.txt
--- trunk/docs/rfc/ms-rfc-15.txt 2008-11-26 17:20:46 UTC (rev 8125)
+++ trunk/docs/rfc/ms-rfc-15.txt 2008-11-26 19:55:13 UTC (rev 8126)
@@ -5,7 +5,7 @@
:Date: 2006/05/01
:Author: Tamas Szekeres
:Contact: szekerest at gmail.com
-:Last Edited: $Date: 2006/04/30 21:41:38 $
+:Last Edited: $Date$
:Status: Preliminary
:Version: Not assigned yet
Property changes on: trunk/docs/rfc/ms-rfc-15.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-16.txt
Property changes on: trunk/docs/rfc/ms-rfc-17.txt
Property changes on: trunk/docs/rfc/ms-rfc-18.txt
Property changes on: trunk/docs/rfc/ms-rfc-19.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-2.txt
Property changes on: trunk/docs/rfc/ms-rfc-21.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-22a.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-23.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-24-FIRSTDRAFT.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-24.txt
Property changes on: trunk/docs/rfc/ms-rfc-25.txt
+ text/x-rst
Modified: trunk/docs/rfc/ms-rfc-26.txt
--- trunk/docs/rfc/ms-rfc-26.txt 2008-11-26 17:20:46 UTC (rev 8125)
+++ trunk/docs/rfc/ms-rfc-26.txt 2008-11-26 19:55:13 UTC (rev 8126)
@@ -1,7 +1,7 @@
:Date: 2007/04/21
:Author: Steve Lime, Havard Tveite
:Contact: steve.lime at dnr.state.mn.us, havard.tveite at umb.no
-:Last Edited: $Date: 2007/04/21 $
:Status: Draft
Mapserver terminology is mostly good and consistent, with a few exceptions. The two that generate the most confusion and TRANSPARENCY (layerObj) and various scale referencing parameters (e.g. MINSCALE).
Property changes on: trunk/docs/rfc/ms-rfc-26.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-27.txt
Property changes on: trunk/docs/rfc/ms-rfc-28.txt
Property changes on: trunk/docs/rfc/ms-rfc-29.txt
Property changes on: trunk/docs/rfc/ms-rfc-3.txt
Property changes on: trunk/docs/rfc/ms-rfc-30.txt
Property changes on: trunk/docs/rfc/ms-rfc-31.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-32.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-33.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-34.txt
Property changes on: trunk/docs/rfc/ms-rfc-35.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-36.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-37.txt
- Id Rev Date
Property changes on: trunk/docs/rfc/ms-rfc-38.txt
- Id Rev Date
Property changes on: trunk/docs/rfc/ms-rfc-39.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-4.txt
Property changes on: trunk/docs/rfc/ms-rfc-40.txt
Property changes on: trunk/docs/rfc/ms-rfc-41.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-42.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-43.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-44.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-45.txt
Property changes on: trunk/docs/rfc/ms-rfc-46.txt
Property changes on: trunk/docs/rfc/ms-rfc-47.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-48.txt
Property changes on: trunk/docs/rfc/ms-rfc-5.txt
Property changes on: trunk/docs/rfc/ms-rfc-6.txt
Modified: trunk/docs/rfc/ms-rfc-7.1.txt
--- trunk/docs/rfc/ms-rfc-7.1.txt 2008-11-26 17:20:46 UTC (rev 8125)
+++ trunk/docs/rfc/ms-rfc-7.1.txt 2008-11-26 19:55:13 UTC (rev 8126)
@@ -5,7 +5,7 @@
:Date: 2008/07/02
:Author: Frank Warmerdam and Tom Kralidis
:Contact: warmerdam at pobox.com and tomkralidis at hotmail.com
-:Last Edited: $Date: 2008-07-02 09:05:32 -0400 (Wed, 02 Jul 2008) $
:Status: Adopted
(Note: this RFC obsoletes RFC 7)
Property changes on: trunk/docs/rfc/ms-rfc-7.1.txt
+ text/x-rst
Property changes on: trunk/docs/rfc/ms-rfc-7.txt
Property changes on: trunk/docs/rfc/ms-rfc-8.txt
Property changes on: trunk/docs/rfc/ms-rfc-9.txt
More information about the mapserver-commits
