[mapserver-commits] r8134 - in trunk/mapserver: . mapscript/php3
svn at osgeo.org
svn at osgeo.org
Fri Nov 28 15:21:03 EST 2008
Author: aboudreault
Date: 2008-11-28 15:21:03 -0500 (Fri, 28 Nov 2008)
New Revision: 8134
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapscript/php3/mapscript_i.c
trunk/mapserver/mapscript/php3/php_mapscript.c
trunk/mapserver/mapscript/php3/php_mapscript.h
Added removeLayer function to mapObj in PHP/MapScript. (#762)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2008-11-28 18:56:28 UTC (rev 8133)
+++ trunk/mapserver/HISTORY.TXT 2008-11-28 20:21:03 UTC (rev 8134)
@@ -12,6 +12,8 @@
Current Version (5.3-dev, SVN trunk):
+- Added removeLayer function to mapObj in PHP/MapScript. (#762)
- Exposed PIXELS value via URL configuration
- Add Support for SLD TextSymbolizer HALO and ANGLE (#2806)
Modified: trunk/mapserver/mapscript/php3/mapscript_i.c
--- trunk/mapserver/mapscript/php3/mapscript_i.c 2008-11-28 18:56:28 UTC (rev 8133)
+++ trunk/mapserver/mapscript/php3/mapscript_i.c 2008-11-28 20:21:03 UTC (rev 8134)
@@ -343,6 +343,11 @@
return -1;
+layerObj *mapObj_removeLayer(mapObj *self, int layerindex)
+ return msRemoveLayer(self, layerindex);
* class extensions for layerObj, always within the context of a map
@@ -363,8 +368,18 @@
void layerObj_destroy(layerObj *self) {
- return; // map deconstructor takes care of it
+ /* if the layer has a parent_map, let's the map object destroy it */
+ if ((self->map == NULL) && (self->refcount == 1)) {
+ /* if there is no other PHP Object that use this C layer object, delete it */
+ freeLayer(self);
+ free(self);
+ self = NULL;
+ } else
+ MS_REFCNT_DECR(self);
+ return;
int layerObj_open(layerObj *self) {
return msLayerOpen(self);
Modified: trunk/mapserver/mapscript/php3/php_mapscript.c
--- trunk/mapserver/mapscript/php3/php_mapscript.c 2008-11-28 18:56:28 UTC (rev 8133)
+++ trunk/mapserver/mapscript/php3/php_mapscript.c 2008-11-28 20:21:03 UTC (rev 8134)
@@ -75,6 +75,7 @@
static void php_ms_free_map(zend_rsrc_list_entry *rsrc TSRMLS_DC);
static void php_ms_free_image(zend_rsrc_list_entry *rsrc TSRMLS_DC);
+DLEXPORT void php3_ms_free_layer(layerObj *pLayer);
DLEXPORT void php3_ms_free_point(pointObj *pPoint);
DLEXPORT void php3_ms_free_line(lineObj *pLine);
DLEXPORT void php3_ms_free_shape(shapeObj *pShape);
@@ -169,6 +170,7 @@
DLEXPORT void php3_ms_map_OWSDispatch(INTERNAL_FUNCTION_PARAMETERS);
DLEXPORT void php3_ms_map_insertLayer(INTERNAL_FUNCTION_PARAMETERS);
+DLEXPORT void php3_ms_map_removeLayer(INTERNAL_FUNCTION_PARAMETERS);
DLEXPORT void php3_ms_img_saveImage(INTERNAL_FUNCTION_PARAMETERS);
DLEXPORT void php3_ms_img_saveWebImage(INTERNAL_FUNCTION_PARAMETERS);
@@ -707,6 +709,7 @@
{"loadowsparameters", php3_ms_map_loadOWSParameters, NULL},
{"owsdispatch", php3_ms_map_OWSDispatch, NULL},
{"insertlayer", php3_ms_map_insertLayer, NULL},
+ {"removelayer", php3_ms_map_removeLayer, NULL},
{NULL, NULL, NULL}
@@ -1010,10 +1013,9 @@
PHPMS_GLOBAL(le_msimg) =
zend_register_list_destructors_ex(php_ms_free_image, NULL,
"imageObj", module_number);
- PHPMS_GLOBAL(le_mslayer)=
- zend_register_list_destructors_ex(NULL, NULL,
- "layerObj", module_number);
+ PHPMS_GLOBAL(le_mslayer)= register_list_destructors(php3_ms_free_layer,
+ NULL);
PHPMS_GLOBAL(le_msclass)= register_list_destructors(php3_ms_free_stub,
NULL);
PHPMS_GLOBAL(le_mslabel)= register_list_destructors(php3_ms_free_stub,
@@ -1410,6 +1412,11 @@
msFreeImage(image);
+ layerObj_destroy(pLayer);
DLEXPORT void php3_ms_free_rect(rectObj *pRect)
rectObj_destroy(pRect);
@@ -6043,8 +6050,7 @@
list TSRMLS_CC);
poLayer = (layerObj *)_phpms_fetch_handle(pLyr,
PHPMS_GLOBAL(le_mslayer),
- list TSRMLS_CC);
+ list TSRMLS_CC);
if (self == NULL || poLayer == NULL ||
(iReturn = mapObj_insertLayer(self, poLayer, nLyrIndex) ) < 0)
@@ -6061,10 +6067,55 @@
+ * map->removelayer()
+ * Remove layer from map object
+/* {{{ proto int map.removeLayer(int layer_index)
+ Returns layerObj removed on sucess, else null. */
+ pval *pThis;
+ long layerIndex = 0;
+ mapObj *self=NULL;
+ layerObj *poLayer=NULL;
+ HashTable *list=NULL;
+ pThis = getThis();
+ if (pThis == NULL ||
+ (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "l", &layerIndex)
+ == FAILURE))
+ return;
+ self = (mapObj *)_phpms_fetch_handle(pThis, PHPMS_GLOBAL(le_msmap),
+ list TSRMLS_CC);
+ if (self == NULL ||
+ (poLayer = mapObj_removeLayer(self, layerIndex)) == NULL)
+ _phpms_report_mapserver_error(E_ERROR);
+ /* Update mapObj members */
+ _phpms_set_property_long(pThis, "numlayers",
+ self->numlayers, E_ERROR TSRMLS_CC);
+ /* Return layer object */
+ _phpms_build_layer_object(poLayer, (int)NULL, list, return_value TSRMLS_CC);
* PHP function wrappers - image class
@@ -6500,12 +6551,10 @@
_phpms_object_init(return_value, layer_id, php_layer_class_functions,
PHP4_CLASS_ENTRY(layer_class_entry_ptr) TSRMLS_CC);
-#ifdef PHP4
- zend_list_addref(parent_map_id);
+ if (parent_map_id != (int)NULL)
+ zend_list_addref(parent_map_id);
add_property_resource(return_value, "_map_handle_", parent_map_id);
-#else
- add_property_long(return_value, "_map_handle_", parent_map_id);
-#endif
+ MS_REFCNT_INCR(player);
/* read-only properties */
add_property_long(return_value, "numclasses", player->numclasses);
Modified: trunk/mapserver/mapscript/php3/php_mapscript.h
--- trunk/mapserver/mapscript/php3/php_mapscript.h 2008-11-28 18:56:28 UTC (rev 8133)
+++ trunk/mapserver/mapscript/php3/php_mapscript.h 2008-11-28 20:21:03 UTC (rev 8134)
@@ -127,6 +127,7 @@
char *wmtver_string);
int mapObj_OWSDispatch(mapObj *self, cgiRequestObj *req );
int mapObj_insertLayer(mapObj *self, layerObj *layer, int index);
+layerObj *mapObj_removeLayer(mapObj *self, int layerindex);
layerObj *layerObj_new(mapObj *map);
void layerObj_destroy(layerObj* self);
More information about the mapserver-commits
