[mapserver-commits] r7940 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Oct 1 16:58:57 EDT 2008
Author: pramsey
Date: 2008-10-01 16:58:57 -0400 (Wed, 01 Oct 2008)
New Revision: 7940
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapraster.c
Make layer->data test a little more lenient (#2783)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2008-10-01 09:11:30 UTC (rev 7939)
+++ trunk/mapserver/HISTORY.TXT 2008-10-01 20:58:57 UTC (rev 7940)
@@ -12,6 +12,8 @@
Current Version (5.3-dev, SVN trunk):
+- tileindexed rasters when DATA is manipulated via mapscript work (#2783)
- styleObj width now supports attribute binding
- RFC40 implementation: label text wrapping and alignment (#2383)
Modified: trunk/mapserver/mapraster.c
--- trunk/mapserver/mapraster.c 2008-10-01 09:11:30 UTC (rev 7939)
+++ trunk/mapserver/mapraster.c 2008-10-01 20:58:57 UTC (rev 7940)
@@ -1398,7 +1398,7 @@
if(status == MS_DONE) break; /* no more tiles/images */
- if(layer->data == NULL) /* assume whole filename is in attribute field */
+ if(layer->data == NULL || strlen(layer->data) == 0 ) /* assume whole filename is in attribute field */
strcpy( tilename, tshp.values[tileitemindex] );
else
sprintf(tilename, "%s/%s", tshp.values[tileitemindex], layer->data);
More information about the mapserver-commits
