[mapserver-commits] r7946 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Oct 3 12:26:01 EDT 2008
Author: tbonfort
Date: 2008-10-03 12:26:00 -0400 (Fri, 03 Oct 2008)
New Revision: 7946
trunk/mapserver/mapdraw.c
don't draw label background if we're using angle follow. (#2726)
fix a bug that could happen when using a background color and force true and position auto
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c 2008-10-03 15:42:20 UTC (rev 7945)
+++ trunk/mapserver/mapdraw.c 2008-10-03 16:26:00 UTC (rev 7946)
@@ -2218,8 +2218,18 @@
} /* next position */
- if(labelPtr->force) cachePtr->status = MS_TRUE; /* draw in spite of collisions based on last position, need a *best* position */
+ if(labelPtr->force) {
+ /*billboard wasn't initialized if no non-coliding position was found*/
+ if(!cachePtr->status && MS_VALID_COLOR(labelPtr->backgroundcolor))
+ get_metrics_line(&(cachePtr->point), positions[npositions-1], r,
+ (marker_offset_x + labelPtr->offsetx),
+ (marker_offset_y + labelPtr->offsety),
+ labelPtr->angle, 1, billboard.line);
+ cachePtr->status = MS_TRUE; /* draw in spite of collisions based on last position, need a *best* position */
} else { /* explicit position */
cachePtr->status = MS_TRUE; /* assume label *can* be drawn */
@@ -2254,7 +2264,8 @@
msDrawMarkerSymbol(&map->symbolset, image, &(cachePtr->point), &(cachePtr->styles[i]), layerPtr->scalefactor);
- if(MS_VALID_COLOR(labelPtr->backgroundcolor)) {
+ /*draw the background, only if we're not using FOLLOW labels*/
+ if(!cachePtr->labelpath && MS_VALID_COLOR(labelPtr->backgroundcolor)) {
styleObj style;
initStyle(&style);
More information about the mapserver-commits
