[mapserver-commits] r7952 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Oct 3 17:57:08 EDT 2008
Author: pramsey
Date: 2008-10-03 17:57:08 -0400 (Fri, 03 Oct 2008)
New Revision: 7952
trunk/mapserver/mapgd.c
trunk/mapserver/mapogcfilter.c
trunk/mapserver/mapogcsos.c
Remove C++ style comments and hi-bit characters.
Modified: trunk/mapserver/mapgd.c
--- trunk/mapserver/mapgd.c 2008-10-03 21:52:15 UTC (rev 7951)
+++ trunk/mapserver/mapgd.c 2008-10-03 21:57:08 UTC (rev 7952)
@@ -918,7 +918,7 @@
edge[nvert].dx = point2->y == point1->y ? 0 : (point2->x - point1->x) / (point2->y - point1->y);
- edge[nvert].s = MS_NINT( p->line[l].point[i].y ); //ceil( p->line[l].point[i].y - 0.5 );
+ edge[nvert].s = MS_NINT( p->line[l].point[i].y ); /* ceil( p->line[l].point[i].y - 0.5 ); */
edge[nvert].x = point1->x ;
edge[nvert].i = nvert;
edge[nvert].l = l;
Modified: trunk/mapserver/mapogcfilter.c
--- trunk/mapserver/mapogcfilter.c 2008-10-03 21:52:15 UTC (rev 7951)
+++ trunk/mapserver/mapogcfilter.c 2008-10-03 21:57:08 UTC (rev 7952)
@@ -1050,7 +1050,7 @@
return msQueryByRect(map, lp->index, sQueryRect);
- //return MS_SUCCESS;
+ /* return MS_SUCCESS; */
int FLTIsSimpleFilter(FilterEncodingNode *psNode)
@@ -1527,7 +1527,7 @@
/* <Filter> */
/* <BBOX> */
/* <PropertyName>Geometry</PropertyName> */
-/* <gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#4326”>*/
+/* <gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">*/
/* <gml:coordinates>13.0983,31.5899 35.5472,42.8143</gml:coordinates>*/
/* </gml:Box> */
/* </BBOX> */
@@ -2355,7 +2355,7 @@
/* eg 1: <Filter> */
/* <BBOX> */
/* </gml:Box> */
/* </BBOX> */
@@ -2365,7 +2365,7 @@
/* <AND> */
/* <BBOX> */
/* </gml:Box> */
/* </BBOX> */
Modified: trunk/mapserver/mapogcsos.c
--- trunk/mapserver/mapogcsos.c 2008-10-03 21:52:15 UTC (rev 7951)
+++ trunk/mapserver/mapogcsos.c 2008-10-03 21:57:08 UTC (rev 7952)
@@ -756,7 +756,7 @@
"observedProperty_id");
if (pszValue)
- //psNode= xmlNewChild(psObsNode, psNsOm, BAD_CAST "observedProperty", BAD_CAST pszValue);
+ /* psNode= xmlNewChild(psObsNode, psNsOm, BAD_CAST "observedProperty", BAD_CAST pszValue); */
msSOSAddPropertyNode(psNsSwe, psNsXLink, psObsNode, lp, psNsGml);
@@ -2363,7 +2363,7 @@
return msSOSException(map, "offering_timeextent", "InvalidParameterValue");
- if (n == 2) // end time is empty. It is going to be set as "now
+ if (n == 2) /* end time is empty. It is going to be set as "now" */
pszEndTime = tokens[1];
psNode = xmlAddChild(psRootNode, msSOSAddTimeNode(xmlNewNs(NULL, BAD_CAST pszOMNamespaceUri, BAD_CAST pszOMNamespacePrefix), tokens[0], pszEndTime));
More information about the mapserver-commits
