[mapserver-commits] r7954 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sat Oct 4 06:59:35 EDT 2008
Author: tbonfort
Date: 2008-10-04 06:59:35 -0400 (Sat, 04 Oct 2008)
New Revision: 7954
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapagg.cpp
trunk/mapserver/mapdraw.c
trunk/mapserver/mapgd.c
trunk/mapserver/mapgraticule.c
trunk/mapserver/mapimagemap.c
trunk/mapserver/maplabel.c
trunk/mapserver/maplegend.c
trunk/mapserver/mappdf.c
trunk/mapserver/mapprimitive.c
trunk/mapserver/mapscale.c
trunk/mapserver/mapserver.h
trunk/mapserver/mapsvg.c
* refactor msGetLabelSizeEx (now merged with msGetLabelSize) (#2390)
* native label size computation for AGG when using angle follow (#2357)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2008-10-04 01:25:54 UTC (rev 7953)
+++ trunk/mapserver/HISTORY.TXT 2008-10-04 10:59:35 UTC (rev 7954)
@@ -11,9 +11,12 @@
Current Version (5.3-dev, SVN trunk):
+- refactor msGetLabelSizeEx (now merged with msGetLabelSize) (#2390)
-- memory leak in msInsertLayer, from Ned Horning (#2784)
+- native label size computation for AGG when using angle follow (#2357)
+- memory leak in msInsertLayer, from Ned Harding (#2784)
- label size computation refactoring (#2390)
- don't draw label background if we're using angle follow. (#2726)
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp 2008-10-04 01:25:54 UTC (rev 7953)
+++ trunk/mapserver/mapagg.cpp 2008-10-04 10:59:35 UTC (rev 7954)
@@ -675,9 +675,8 @@
return MS_SUCCESS;
- int getLabelSize(char *string, char *font, double size, rectObj *rect) {
+ int getLabelSize(char *string, char *font, double size, rectObj *rect, double **advances) {
if(!m_feng.load_font(font, 0, agg::glyph_ren_outline)) {
msSetError(MS_TTFERR, "AGG error loading font (%s)", "getLabelSize()", font);
return MS_FAILURE;
@@ -686,7 +685,10 @@
m_feng.height(size);
m_feng.resolution(96);
m_feng.flip_y(true);
- int unicode;
+ int unicode,curGlyph=1,numglyphs;
+ if(advances) {
+ numglyphs=msGetNumGlyphs(string);
const agg::glyph_cache* glyph;
string+=msUTF8ToUniChar(string, &unicode);
glyph=m_fman.glyph(unicode);
@@ -698,8 +700,16 @@
else
return MS_FAILURE;
+ if(advances) {
+ *advances = (double*)malloc(numglyphs*sizeof(double));
+ (*advances)[0]=glyph->advance_x;
double fx=glyph->advance_x,fy=glyph->advance_y;
while(*string) {
+ if(advances) {
+ if(*string=='\r' || *string=='\n')
+ (*advances)[curGlyph++]=-fx;
if(*string=='\r') {fx=0;string++;continue;}
if(*string=='\n') {fx=0;fy+=ceil(size*LINESPACE);string++;continue;}
@@ -714,15 +724,18 @@
fx += glyph->advance_x;
fy += glyph->advance_y;
+ if(advances) {
+ double x,y;
+ x=glyph->advance_x;
+ m_fman.add_kerning(&x,&y);
+ (*advances)[curGlyph++]=x;
- /*rect->minx--;
- rect->miny--;
- rect->maxx++;
- rect->maxy++;*/
return MS_SUCCESS;
///render a freetype string
///@param x,y the lower left corner where to start the string, or the center of
/// the character if isMarker is true
@@ -1235,7 +1248,7 @@
if(!font) return;
double x,y;
rectObj bounds;
- if(ren->getLabelSize(symbol->character,font,size,&bounds)!=MS_SUCCESS)
+ if(ren->getLabelSize(symbol->character,font,size,&bounds,NULL)!=MS_SUCCESS)
return;
x = p->x + ox - bounds.minx - (bounds.maxx-bounds.minx)/2.;
y = p->y + oy - bounds.maxy + (bounds.maxy-bounds.miny)/2.;
@@ -1496,7 +1509,7 @@
msSetError(MS_TTFERR, "Requested font (%s) not found.", "msDrawTextAGG()", label.font);
return;
- if(ren->getLabelSize(symbol->character, font, label.size, &label_rect) != MS_SUCCESS)
+ if(ren->getLabelSize(symbol->character, font, label.size, &label_rect,NULL) != MS_SUCCESS)
return;
label_width = (int) label_rect.maxx - (int) label_rect.minx;
@@ -2032,9 +2045,9 @@
-int msGetTruetypeTextBBoxAGG(imageObj *img, char *font, int size, char *string, rectObj *rect) {
+int msGetTruetypeTextBBoxAGG(imageObj *img, char *font, int size, char *string, rectObj *rect, double **advances) {
AGGMapserverRenderer* ren = getAGGRenderer(img);
- return ren->getLabelSize(string, font, size, rect);
+ return ren->getLabelSize(string, font, size, rect,advances);
int msGetRasterTextBBoxAGG(imageObj *img, int size, char *string, rectObj *rect) {
@@ -2341,7 +2354,7 @@
if (label.type == MS_TRUETYPE) label.size = height;
marker.x = dstX + MS_NINT(width / 2.0);
marker.y = dstY + MS_NINT(height / 2.0);
- if(msGetLabelSize(image, (char*)"Aa", &label, &label_rect, &map->fontset, 1.0, MS_FALSE) != -1)
+ if(msGetLabelSize(image, (char*)"Aa", &label, &label_rect, &map->fontset, 1.0, MS_FALSE,NULL) != -1)
pointObj label_point = get_metrics(&marker, MS_CC, label_rect, 0, 0, label.angle, 0, NULL);
msDrawTextAGG(image, label_point, (char*)"Aa", &label, &map->fontset, 1.0);
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c 2008-10-04 01:25:54 UTC (rev 7953)
+++ trunk/mapserver/mapdraw.c 2008-10-04 10:59:35 UTC (rev 7954)
@@ -1413,7 +1413,7 @@
msTransformShape(&annoshape, map->extent, map->cellsize, image);
if(layer->class[c]->label.autofollow == MS_TRUE ) {
- annopath = msPolylineLabelPath(&annoshape, layer->class[c]->label.minfeaturesize, &(map->fontset), shape->text, &(layer->class[c]->label), layer->scalefactor, &status);
+ annopath = msPolylineLabelPath(image,&annoshape, layer->class[c]->label.minfeaturesize, &(map->fontset), shape->text, &(layer->class[c]->label), layer->scalefactor, &status);
} else {
annocallret = msPolylineLabelPoint(&annoshape, &annopnt, layer->class[c]->label.minfeaturesize, &angle, &length);
@@ -1434,7 +1434,7 @@
/* Determine the label path if it has not been computed above */
if(bLabelNoClip == MS_FALSE)
- annopath = msPolylineLabelPath(shape, layer->class[c]->label.minfeaturesize, &(map->fontset), shape->text, &(layer->class[c]->label), layer->scalefactor, &status);
+ annopath = msPolylineLabelPath(image,shape, layer->class[c]->label.minfeaturesize, &(map->fontset), shape->text, &(layer->class[c]->label), layer->scalefactor, &status);
if( annopath ) {
labelObj label = layer->class[c]->label;
@@ -1614,7 +1614,7 @@
if(layer->class[c]->label.autofollow == MS_TRUE) {
} else {
@@ -1644,7 +1644,7 @@
layer->class[c]->label.position = MS_CC; /* Force all label positions to MS_CC regardless if a path is computed */
if (bLabelNoClip == MS_FALSE)
if(annopath) {
@@ -1992,7 +1992,7 @@
initStyle(&style);
- if(msGetLabelSize(image, string, label, &r, &(map->fontset), scalefactor, MS_FALSE) == -1) return(-1);
+ if(msGetLabelSize(image, string, label, &r, &(map->fontset), scalefactor, MS_FALSE,NULL) == -1) return(-1);
if(label->position != MS_XY) {
pointObj p;
@@ -2151,7 +2151,7 @@
if(!cachePtr->text || strlen(cachePtr->text) == 0)
continue; /* not an error, just don't want to do anything */
- if(msGetLabelSize(image,cachePtr->text, labelPtr, &r, &(map->fontset), layerPtr->scalefactor, MS_TRUE) == -1)
+ if(msGetLabelSize(image,cachePtr->text, labelPtr, &r, &(map->fontset), layerPtr->scalefactor, MS_TRUE,NULL) == -1)
return(-1);
if(labelPtr->autominfeaturesize && ((r.maxx-r.minx) > cachePtr->featuresize))
continue; /* label too large relative to the feature */
Modified: trunk/mapserver/mapgd.c
--- trunk/mapserver/mapgd.c 2008-10-04 01:25:54 UTC (rev 7953)
+++ trunk/mapserver/mapgd.c 2008-10-04 10:59:35 UTC (rev 7954)
@@ -3230,7 +3230,7 @@
- if(msGetLabelSize(NULL,"Aa", &label, &label_rect, &map->fontset, 1.0, MS_FALSE) != -1)
+ if(msGetLabelSize(NULL,"Aa", &label, &label_rect, &map->fontset, 1.0, MS_FALSE,NULL) != -1)
msDrawTextGD(img, label_point, "Aa", &label, &map->fontset, 1.0);
Modified: trunk/mapserver/mapgraticule.c
--- trunk/mapserver/mapgraticule.c 2008-10-04 01:25:54 UTC (rev 7953)
+++ trunk/mapserver/mapgraticule.c 2008-10-04 10:59:35 UTC (rev 7954)
@@ -630,7 +630,7 @@
if(pLayer->transform)
msTransformShapeToPixel(pShape, pLayer->map->extent, pLayer->map->cellsize);
- if(msGetLabelSize(NULL, pShape->text, &pLayer->class[0]->label, &rectLabel, &pLayer->map->fontset, 1.0, MS_FALSE) != 0)
+ if(msGetLabelSize(NULL, pShape->text, &pLayer->class[0]->label, &rectLabel, &pLayer->map->fontset, 1.0, MS_FALSE,NULL) != 0)
return MS_FAILURE; /* msSetError already called */
switch( ePosition ) {
Modified: trunk/mapserver/mapimagemap.c
--- trunk/mapserver/mapimagemap.c 2008-10-04 01:25:54 UTC (rev 7953)
+++ trunk/mapserver/mapimagemap.c 2008-10-04 10:59:35 UTC (rev 7954)
@@ -1850,7 +1850,7 @@
if(cachePtr->label.type == MS_TRUETYPE)
cachePtr->label.size = (int)(cachePtr->label.size*layerPtr->scalefactor);
- if(msGetLabelSize(img,cachePtr->text, labelPtr, &r, &(map->fontset), layerPtr->scalefactor, MS_TRUE) == -1)
+ if(msGetLabelSize(img,cachePtr->text, labelPtr, &r, &(map->fontset), layerPtr->scalefactor, MS_TRUE,NULL) == -1)
return(-1);
Modified: trunk/mapserver/maplabel.c
--- trunk/mapserver/maplabel.c 2008-10-04 01:25:54 UTC (rev 7953)
+++ trunk/mapserver/maplabel.c 2008-10-04 10:59:35 UTC (rev 7954)
@@ -192,7 +192,7 @@
* that the integer rounding for such a number of spaces will be negligeable
* compared to the actual size of thoses spaces */
if(msGetLabelSize(image, " ", label,&label_rect,
- &map->fontset, 1.0, MS_FALSE)==-1) {
+ &map->fontset, 1.0, MS_FALSE,NULL)==-1) {
/*error computing label size, we can't continue*/
/*free the previously allocated split text*/
@@ -230,7 +230,7 @@
/*length in pixels of the longest line*/
maxlinelength=0;
for(i=0;i<numlines;i++) {
- msGetLabelSize(image, textlines[i], label, &label_rect, &map->fontset, 1.0, MS_FALSE);
+ msGetLabelSize(image, textlines[i], label, &label_rect, &map->fontset, 1.0, MS_FALSE, NULL);
textlinelengths[i] = label_rect.maxx-label_rect.minx;
if(maxlinelength<textlinelengths[i])
maxlinelength=textlinelengths[i];
@@ -642,26 +642,63 @@
#endif
-int msGetTruetypeTextBBox(imageObj *img, char *font, int size, char *string, rectObj *rect) {
+int msGetTruetypeTextBBox(imageObj *img, char *font, int size, char *string, rectObj *rect, double **advances) {
#ifdef USE_GD_FT
#ifdef USE_AGG
if(img!=NULL && MS_RENDERER_AGG(img->format)) {
- return msGetTruetypeTextBBoxAGG(img,font,size,string,rect);
+ return msGetTruetypeTextBBoxAGG(img,font,size,string,rect,advances);
} else
#endif
int bbox[8];
- char *error = gdImageStringFT(NULL, bbox, 0, font, size, 0, 0, 0, string);
- if(error) {
- msSetError(MS_TTFERR, error, "msGetTruetypeTextBBox()");
- return(MS_FAILURE);
+ char *error;
+ if(advances) {
+#if defined (GD_HAS_FTEX_XSHOW)
+ char *s;
+ int k;
+ gdFTStringExtra strex;
+ strex.flags = gdFTEX_XSHOW;
+ error = gdImageStringFTEx(NULL, bbox, 0, font, size, 0, 0, 0, string, &strex);
+ if(error) {
+ msSetError(MS_TTFERR, error, "gdImageStringFTEx()");
+ return(MS_FAILURE);
- rect->minx = bbox[0];
- rect->miny = bbox[5];
- rect->maxx = bbox[2];
- rect->maxy = bbox[1];
- return MS_SUCCESS;
+ *advances = (double*)malloc( strlen(string) * sizeof(double) );
+ s = strex.xshow;
+ k = 0;
+ while ( *s && k < strlen(string) ) {
+ (*advances)[k++] = atof(s);
+ while ( *s && *s != ' ')
+ s++;
+ if ( *s == ' ' )
+ s++;
+ gdFree(strex.xshow); /* done with character advances */
+ rect->minx = bbox[0];
+ rect->miny = bbox[5];
+ rect->maxx = bbox[2];
+ rect->maxy = bbox[1];
+ return MS_SUCCESS;
+#else
+ msSetError(MS_TTFERR, "gdImageStringFTEx support is not available or is not current enough (requires 2.0.29 or higher).", "msGetTruetypeTextBBox()");
+ return(-1);
+#endif
+ } else {
+ error = gdImageStringFT(NULL, bbox, 0, font, size, 0, 0, 0, string);
+ if(error) {
+ msSetError(MS_TTFERR, error, "msGetTruetypeTextBBox()");
#else
/*shouldn't happen*/
@@ -705,7 +742,7 @@
/* assumes an angle of 0 regardless of what's in the label object */
-int msGetLabelSize(imageObj *img, char *string, labelObj *label, rectObj *rect, fontSetObj *fontset, double scalefactor, int adjustBaseline)
+int msGetLabelSize(imageObj *img, char *string, labelObj *label, rectObj *rect, fontSetObj *fontset, double scalefactor, int adjustBaseline, double **advances)
int size;
if(label->type == MS_TRUETYPE) {
@@ -725,7 +762,7 @@
return(-1);
- if(msGetTruetypeTextBBox(img,font,size,string,rect)!=MS_SUCCESS)
+ if(msGetTruetypeTextBBox(img,font,size,string,rect,advances)!=MS_SUCCESS)
return MS_FAILURE;
/* bug 1449 fix (adjust baseline) */
@@ -738,7 +775,7 @@
else {
rectObj rect2; /*bbox of first line only*/
char* firstLine = msGetFirstLine(string);
- msGetTruetypeTextBBox(img,font,size,firstLine,&rect2);
+ msGetTruetypeTextBBox(img,font,size,firstLine,&rect2,NULL);
label->offsety += MS_NINT(((rect2.miny+rect2.maxy) + size) / 2);
label->offsetx += MS_NINT(rect2.minx / 2);
free(firstLine);
@@ -755,73 +792,6 @@
return(0);
- * Return the size of the label, plus an array of individual character
- * offsets, as calculated by gdImageStringFTEx(). The callee is
- * responsible for freeing *offsets.
-int msGetLabelSizeEx(char *string, labelObj *label, rectObj *rect, fontSetObj *fontset, double scalefactor, int adjustBaseline, double **offsets)
-#if defined (USE_GD_FT) && defined (GD_HAS_FTEX_XSHOW)
- int size;
- char *s;
- int k;
- int bbox[8];
- char *error=NULL, *font=NULL;
- gdFTStringExtra strex;
- size = MS_NINT(label->size*scalefactor);
- size = MS_MAX(size, label->minsize);
- size = MS_MIN(size, label->maxsize);
- font = msLookupHashTable(&(fontset->fonts), label->font);
- if(!font) {
- if(label->font)
- msSetError(MS_TTFERR, "Requested font (%s) not found.", "msGetLabelSizeEx()", label->font);
- else
- msSetError(MS_TTFERR, "Requested font (NULL) not found.", "msGetLabelSizeEx()");
- return(-1);
- strex.flags = gdFTEX_XSHOW;
- error = gdImageStringFTEx(NULL, bbox, 0, font, size, 0, 0, 0, string, &strex);
- if(error) {
- msSetError(MS_TTFERR, error, "msGetLabelSizeEx()");
- return(-1);
- *offsets = (double*)malloc( strlen(string) * sizeof(double) );
- s = strex.xshow;
- k = 0;
- while ( *s && k < strlen(string) ) {
- (*offsets)[k++] = atof(s);
- while ( *s && *s != ' ')
- s++;
- if ( *s == ' ' )
- s++;
- gdFree(strex.xshow); /* done with character advances */
- /* bug 1449 fix (adjust baseline) */
- if(adjustBaseline) {
- label->offsety += MS_NINT(((bbox[5] + bbox[1]) + size) / 2);
- label->offsetx += MS_NINT(bbox[0] / 2);
-#else
- msSetError(MS_TTFERR, "TrueType font support is not available or is not current enough (requires 2.0.29 or higher).", "msGetLabelSizeEx()");
- return(-1);
-#endif
gdFontPtr msGetBitmapFont(int size)
switch(size) { /* set the font to use */
@@ -1088,7 +1058,7 @@
label.outlinecolor = style->outlinecolor;
label.antialias = symbol->antialias;
- if(msGetLabelSize(NULL,symbol->character, &label, &label_rect, symbolset->fontset, scalefactor, MS_FALSE) == -1)
+ if(msGetLabelSize(NULL,symbol->character, &label, &label_rect, symbolset->fontset, scalefactor, MS_FALSE,NULL) == -1)
return(-1);
Modified: trunk/mapserver/maplegend.c
--- trunk/mapserver/maplegend.c 2008-10-04 01:25:54 UTC (rev 7953)
+++ trunk/mapserver/maplegend.c 2008-10-04 10:59:35 UTC (rev 7954)
@@ -190,7 +190,7 @@
else
transformedText = strdup(lp->class[j]->name);
- if(transformedText == NULL || msGetLabelSize(NULL,transformedText, &map->legend.label, &rect, &(map->fontset), 1.0, MS_FALSE) != 0) { /* something bad happened */
+ if(transformedText == NULL || msGetLabelSize(NULL,transformedText, &map->legend.label, &rect, &(map->fontset), 1.0, MS_FALSE,NULL) != 0) { /* something bad happened */
if(transformedText) msFree(transformedText);
return MS_FAILURE;
@@ -297,7 +297,7 @@
cur->pred = head;
head = cur;
- if(cur->transformedText==NULL || msGetLabelSize(NULL,cur->transformedText, &map->legend.label, &rect, &(map->fontset), 1.0, MS_FALSE) != 0) { /* something bad happened, free allocated mem */
+ if(cur->transformedText==NULL || msGetLabelSize(NULL,cur->transformedText, &map->legend.label, &rect, &(map->fontset), 1.0, MS_FALSE,NULL) != 0) { /* something bad happened, free allocated mem */
while(cur) {
if(cur->transformedText!=cur->theclass->name)
free(cur->transformedText);
Modified: trunk/mapserver/mappdf.c
--- trunk/mapserver/mappdf.c 2008-10-04 01:25:54 UTC (rev 7953)
+++ trunk/mapserver/mappdf.c 2008-10-04 10:59:35 UTC (rev 7954)
@@ -451,7 +451,7 @@
pointObj p;
rectObj r;
- if(msGetLabelSize(image,string, label, &r, fontset, scalefactor, MS_FALSE) == -1) return(-1);
+ if(msGetLabelSize(image,string, label, &r, fontset, scalefactor, MS_FALSE,NULL) == -1) return(-1);
p = get_metrics(&labelPnt, label->position, r,
label->offsetx,
label->offsety,
@@ -534,7 +534,7 @@
if(strlen(cachePtr->text) == 0)
return(-1);
Modified: trunk/mapserver/mapprimitive.c
--- trunk/mapserver/mapprimitive.c 2008-10-04 01:25:54 UTC (rev 7953)
+++ trunk/mapserver/mapprimitive.c 2008-10-04 10:59:35 UTC (rev 7954)
@@ -1204,7 +1204,7 @@
* polyline must be converted to image coordinates before calling this
* function.
-labelPathObj* msPolylineLabelPath(shapeObj *p, int min_length, fontSetObj *fontset, char *string, labelObj *label, double scalefactor, int *status)
+labelPathObj* msPolylineLabelPath(imageObj *img,shapeObj *p, int min_length, fontSetObj *fontset, char *string, labelObj *label, double scalefactor, int *status)
double line_length, max_line_length, segment_length, total_length, distance_along_segment;
double fwd_line_length, rev_line_length, text_length, text_start_length;
@@ -1290,7 +1290,7 @@
goto FAILURE;
/* determine the total length of the text */
- if (msGetLabelSizeEx(string, label, &bbox, fontset, scalefactor, MS_FALSE, &offsets) == MS_FAILURE) {
+ if (msGetLabelSize(img,string, label, &bbox, fontset, scalefactor, MS_FALSE, &offsets) == MS_FAILURE) {
*status = MS_FAILURE;
goto FAILURE;
Modified: trunk/mapserver/mapscale.c
--- trunk/mapserver/mapscale.c 2008-10-04 01:25:54 UTC (rev 7953)
+++ trunk/mapserver/mapscale.c 2008-10-04 10:59:35 UTC (rev 7954)
@@ -311,7 +311,7 @@
p.x = ox + j*isx; /* + MS_NINT(fontPtr->w/2); */
p.y = oy + map->scalebar.height + MS_NINT(VSPACING*fontPtr->h);
if(msGetLabelSize(NULL,label,&(map->scalebar.label), &r,
- &(map->fontset), 1, MS_FALSE) == -1) return(NULL);
+ &(map->fontset), 1, MS_FALSE,NULL) == -1) return(NULL);
p2 = get_metrics(&p, MS_CC, r, 0,0, 0, 0, NULL);
msDrawTextGD(image->img.gd, p2, label, &(map->scalebar.label), &(map->fontset), 1.0);
@@ -324,7 +324,7 @@
p.x = ox; /* + MS_NINT(fontPtr->w/2); */
p2 = get_metrics(&p, MS_CR, r, 0,0, 0, 0, NULL);
@@ -344,7 +344,7 @@
@@ -360,7 +360,7 @@
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2008-10-04 01:25:54 UTC (rev 7953)
+++ trunk/mapserver/mapserver.h 2008-10-04 10:59:35 UTC (rev 7954)
@@ -1701,8 +1701,7 @@
MS_DLL_EXPORT int msInitFontSet(fontSetObj *fontset);
MS_DLL_EXPORT int msFreeFontSet(fontSetObj *fontset);
MS_DLL_EXPORT char *msTransformLabelText(mapObj *map, imageObj* image, labelObj *label, char *text);
-MS_DLL_EXPORT int msGetLabelSize(imageObj *img, char *string, labelObj *label, rectObj *rect, fontSetObj *fontSet, double scalefactor, int adjustBaseline);
-MS_DLL_EXPORT int msGetLabelSizeEx(char *string, labelObj *label, rectObj *rect, fontSetObj *fontSet, double scalefactor, int adjustBaseline, double **offsets);
+MS_DLL_EXPORT int msGetLabelSize(imageObj *img, char *string, labelObj *label, rectObj *rect, fontSetObj *fontSet, double scalefactor, int adjustBaseline,double **advances);
MS_DLL_EXPORT int msAddLabel(mapObj *map, int layerindex, int classindex, int shapeindex, int tileindex, pointObj *point, labelPathObj *labelpath, char *string, double featuresize, labelObj *label);
MS_DLL_EXPORT void msTestLabelCacheCollisions(labelCacheObj *labelcache, labelObj *labelPtr, int mapwidth, int mapheight, int buffer, labelCacheMemberObj *cachePtr, int current_priority, int current_label);
MS_DLL_EXPORT labelCacheMemberObj *msGetLabelCacheMember(labelCacheObj *labelcache, int i);
@@ -1731,7 +1730,7 @@
MS_DLL_EXPORT void msTransformPixelToShape(shapeObj *shape, rectObj extent, double cellsize);
MS_DLL_EXPORT void msImageCartographicPolyline(gdImagePtr im, shapeObj *p, styleObj *style, symbolObj *symbol, int c, double size, double scalefactor);
MS_DLL_EXPORT int msPolylineLabelPoint(shapeObj *p, pointObj *lp, int min_length, double *angle, double *length);
-MS_DLL_EXPORT labelPathObj* msPolylineLabelPath(shapeObj *p, int min_length, fontSetObj *fontset, char *string, labelObj *label, double scalefactor, int *status);
+MS_DLL_EXPORT labelPathObj* msPolylineLabelPath(imageObj *img, shapeObj *p, int min_length, fontSetObj *fontset, char *string, labelObj *label, double scalefactor, int *status);
MS_DLL_EXPORT int msPolygonLabelPoint(shapeObj *p, pointObj *lp, int min_dimension);
MS_DLL_EXPORT int msAddLine(shapeObj *p, lineObj *new_line);
MS_DLL_EXPORT int msAddLineDirectly(shapeObj *p, lineObj *new_line);
@@ -1947,7 +1946,7 @@
MS_DLL_EXPORT void msDrawMarkerSymbolAGG(symbolSetObj *symbolset, imageObj *image, pointObj *p, styleObj *style, double scalefactor);
MS_DLL_EXPORT void msDrawLineSymbolAGG(symbolSetObj *symbolset, imageObj *image, shapeObj *p, styleObj *style, double scalefactor);
MS_DLL_EXPORT void msDrawShadeSymbolAGG(symbolSetObj *symbolset, imageObj *image,shapeObj *p, styleObj *style, double scalefactor);
-int msGetTruetypeTextBBoxAGG(imageObj *img, char *font, int size, char *string, rectObj *rect);
+int msGetTruetypeTextBBoxAGG(imageObj *img, char *font, int size, char *string, rectObj *rect, double **advances);
int msGetRasterTextBBoxAGG(imageObj *img, int size, char *string, rectObj *rect);
MS_DLL_EXPORT int msDrawTextAGG(imageObj *imgage, pointObj labelPnt, char *string, labelObj *label, fontSetObj *fontset, double scalefactor);
MS_DLL_EXPORT int msDrawTextLineAGG(imageObj *image, char *string, labelObj *label, labelPathObj *labelpath, fontSetObj *fontset, double scalefactor);
Modified: trunk/mapserver/mapsvg.c
--- trunk/mapserver/mapsvg.c 2008-10-04 01:25:54 UTC (rev 7953)
+++ trunk/mapserver/mapsvg.c 2008-10-04 10:59:35 UTC (rev 7954)
@@ -1179,7 +1179,7 @@
- if(msGetLabelSize(image, cachePtr->text, labelPtr, &r, &(map->fontset), layerPtr->scalefactor, MS_TRUE) == -1)
+ if(msGetLabelSize(image, cachePtr->text, labelPtr, &r, &(map->fontset), layerPtr->scalefactor, MS_TRUE,NULL) == -1)
return(-1);
More information about the mapserver-commits
