[mapserver-commits] r7959 - branches/branch-5-2/mapserver
Sun Oct 5 04:09:29 EDT 2008
Author: tbonfort
Date: 2008-10-05 04:09:29 -0400 (Sun, 05 Oct 2008)
New Revision: 7959
   branches/branch-5-2/mapserver/HISTORY.TXT
   branches/branch-5-2/mapserver/maputil.c
fix some integer rounding errors in the agg line offseter (#2659)
Modified: branches/branch-5-2/mapserver/HISTORY.TXT
--- branches/branch-5-2/mapserver/HISTORY.TXT	2008-10-05 08:03:12 UTC (rev 7958)
+++ branches/branch-5-2/mapserver/HISTORY.TXT	2008-10-05 08:09:29 UTC (rev 7959)
@@ -12,6 +12,8 @@
 Current Version (SVN branch-5-2)
+- fix some integer rounding errors in the agg line offseter (#2659)
 - fix a bug with shapes with duplicate end points. was causing NaNs
   in the angle follow placement code (#2695)
Modified: branches/branch-5-2/mapserver/maputil.c
--- branches/branch-5-2/mapserver/maputil.c	2008-10-05 08:03:12 UTC (rev 7958)
+++ branches/branch-5-2/mapserver/maputil.c	2008-10-05 08:09:29 UTC (rev 7959)
@@ -1467,7 +1467,7 @@
 shapeObj* msOffsetPolyline(shapeObj *p, int offsetx, int offsety) {
     int i, j, first,idx;
-    int ox=0, oy=0, limit;
+    double ox=0, oy=0, limit;
     double dx,dy,dx0=0, dy0=0,x, y, x0=0.0, y0=0.0, k=0.0, k0=0.0, q=0.0, q0=0.0;
     float par=(float)0.71;
     shapeObj *ret = (shapeObj*)malloc(sizeof(shapeObj));
@@ -1495,15 +1495,15 @@
                     ox=(dy>0) ? -offsetx : offsetx;
                 } else {
-                    k = (double)dy/(double)dx;
+                    k = dy/dx;
                     if(MS_ABS(k)<0.5) {
                         oy = (dx>0) ? offsetx : -offsetx;
                     } else {
                         if (MS_ABS(k)<2.1) {
-                            oy = (int) ((dx>0) ? offsetx*par : -offsetx*par);
-                            ox = (int) ((dy>0) ? -offsetx*par : offsetx*par);
+                            oy = (dx>0) ? offsetx*par : -offsetx*par;
+                            ox = (dy>0) ? -offsetx*par : offsetx*par;
                         } else
-                            ox = (int)((dy>0) ? -offsetx : offsetx);
+                            ox = (dy>0) ? -offsetx : offsetx;
                     q = p->line[i].point[j-1].y+oy - k*(p->line[i].point[j-1].x+ox);
