[mapserver-commits] r7974 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sat Oct 11 11:08:09 EDT 2008
Author: tbonfort
Date: 2008-10-11 11:08:09 -0400 (Sat, 11 Oct 2008)
New Revision: 7974
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapagg.cpp
don't draw an artificial outline around polygons
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2008-10-11 14:42:45 UTC (rev 7973)
+++ trunk/mapserver/HISTORY.TXT 2008-10-11 15:08:09 UTC (rev 7974)
@@ -11,6 +11,10 @@
Current Version (5.3-dev, SVN trunk):
+- stop drawing an artificial outline around polygons to ensure
+ continuity - users needing this feature will have to explicitely
+ add an outlinecolor of the same color as the fill color
- added formatoption QUANTIZE_NEW to force going through the pngquant
quantization algorithm instead of the GD one for imagemode RGB (the
GD one can be kind of buggy)
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp 2008-10-11 14:42:45 UTC (rev 7973)
+++ trunk/mapserver/mapagg.cpp 2008-10-11 15:08:09 UTC (rev 7974)
@@ -1804,12 +1804,7 @@
if(style->symbol == 0 || symbol->type==MS_SYMBOL_SIMPLE) {
// simply draw a solid fill and outline of the specified colors
- if(MS_VALID_COLOR(style->outlinecolor))
- ren->renderPathSolid(*polygons,agg_color,agg_ocolor,style->width);
- //use outline width without scalefactor applied
- else
- //draw a one pixel outline of the same color as the fill to avoid a faint outline
- ren->renderPathSolid(*polygons,agg_color,agg_color,1);
+ ren->renderPathSolid(*polygons,agg_color,agg_ocolor,style->width);
else {
switch(symbol->type) {
@@ -1865,12 +1860,7 @@
int ph = MS_NINT(symbol->sizey*d);
if((pw <= 1) && (ph <= 1)) {
//use a solid fill if the symbol is too small
- ren->renderPathSolid(*polygons,agg_color,agg_ocolor,width);
- else
- //render a one pixel outline of the same color as the fill to prevent a
- //faint due to antialiasing with contiguous polygons
+ ren->renderPathSolid(*polygons,agg_color,agg_ocolor,width);
break;
agg::path_storage path = imageVectorSymbolAGG(symbol,d);
@@ -1894,13 +1884,7 @@
//draw an outline on the shape
//TODO: change this as outlinecolor should be used for the symbol, not the shape
- agg::rgba8 *oc=NULL;
- if(agg_ocolor.a)
- oc=&agg_ocolor;
- else if(agg_bcolor.a)
- oc=&agg_bcolor; /*avoid faint outline*/
- if(oc!=NULL)
- ren->renderPathSolid(*polygons,AGG_NO_COLOR,*oc,1);
+ ren->renderPathSolid(*polygons,AGG_NO_COLOR,agg_ocolor,1);
if(bRotated) { // free the rotated symbol
msFreeSymbol(symbol);
@@ -1921,10 +1905,7 @@
int pw = MS_NINT(symbol->sizex*d);
if((ph <= 1) && (pw <= 1)) { /* No sense using a tile, just fill solid */
- else
else {
agg::path_storage path;
@@ -1944,13 +1925,7 @@
- if(agg_ocolor.a)
- oc=&agg_ocolor;
- oc=&agg_bcolor;
- if(oc!=NULL)
break;
@@ -1961,9 +1936,9 @@
double gap=(symbol->gap>0)?symbol->gap*size:0;
ren->renderPathTruetypeTiled(*polygons,font,(unsigned int)((unsigned char)symbol->character[0]),size,
gap,agg_color,agg_bcolor,agg_ocolor);
- //if a background was specified, draw an outline of the color
- //to avoid faint outlines in contiguous polygons
- ren->renderPathSolid(*polygons,AGG_NO_COLOR,agg_bcolor,1);
+ //FIXME: allow drawing an outline on the polygon to avoid
+ //faint outlines
+ //ren->renderPathSolid(*polygons,AGG_NO_COLOR,agg_bcolor,1);
break;
case MS_SYMBOL_CARTOLINE:
More information about the mapserver-commits
