[mapserver-commits] r7982 - trunk/mapserver/rfc
Tue Oct 14 16:04:12 EDT 2008
Author: tbonfort
Date: 2008-10-14 16:04:12 -0400 (Tue, 14 Oct 2008)
New Revision: 7982
   trunk/mapserver/rfc/ms-rfc-45.txt
add file references
Modified: trunk/mapserver/rfc/ms-rfc-45.txt
--- trunk/mapserver/rfc/ms-rfc-45.txt	2008-10-14 15:43:48 UTC (rev 7981)
+++ trunk/mapserver/rfc/ms-rfc-45.txt	2008-10-14 20:04:12 UTC (rev 7982)
@@ -1,6 +1,3 @@
-.. sectnum::
 :Date: 2008/08/26
 :Authors: Stephen Lime, Håvard Tveite, Thomas Bonfort
 :Contact: Steve.Lime at DNR.State.MN.US
@@ -10,12 +7,13 @@
 (*partiallly derived in part from a document prepared by Håvard and discussions with other developers working on cartographic output*)
-Proposed Changes
+1. Proposed Changes
-Scale Dependant Rendering
+.. _1:
+1.1. Scale Dependant Rendering
 - All symbols can be scaled. When SYMBOLSCALEDENOM is given for a layer, the
   layer and all of its symbols (height, width, line widths, line patterns, line
   dashes, ...) are scaled.
@@ -28,14 +26,16 @@
   CLASS->STYLE->MAXSIZE. By using these MINSIZE/MAXSIZE, one can ensure that a
   symbol will never be rendered smaller/larger than the given sizes.
-Precise Symbol Placement
+1.2. Precise Symbol Placement
 Harmonize the placement of symbols relative to the feature (point or line)
 being drawn.
-Fractional values for sizes
+.. _2:
+1.2.1. Fractional values for sizes
 All symbols sizes and symbol geometries should be specified and
 represented as double - AGG supports fractional line widths so users
 should be able to set them explicitly. GD could either round or
@@ -50,8 +50,10 @@
 - LABEL->SIZE/MINSIZE/MAXSIZE - labelObj.size/minsize/maxsize
 - LABEL->OFFSET - labelObj.offsetx and labelObj.offsety
-CENTER/ORIGIN [x y]
+.. _3:
+1.2.2. CENTER/ORIGIN [x y]
 Defines the centre of the symbol using decimal pixels (x axis increasing to
 the right, y axis increasing downwards).
@@ -60,9 +62,11 @@
 - Default value is the centre of the symbol's bounding box.
 - Applies to TYPE ellipse, vector, pixmap, truetype.
-ANGLE [double|attribute] [DEFAULT|CLOCKWISE|COMPASS]
+.. _4:
+1.2.3. ANGLE [double|attribute] [DEFAULT|CLOCKWISE|COMPASS]
 - STYLE-> ANGLE [double|attribute] [DEFAULT|CLOCKWISE|COMPASS]
 - LABEL-> ANGLE [double|auto|follow|attribute] [DEFAULT|CLOCKWISE|COMPASS]
@@ -79,8 +83,8 @@
 The default would be reference direction east and counter-clockwise rotation.
 If possible, something like:
-Modes of operation
+a. Modes of operation
 - DEFAULT reference direction to the right (east), counter-clockwise direction
   of rotation.
 - CLOCKWISE reference direction to the right (east), clockwise direction of
@@ -88,8 +92,8 @@
 - COMPASS reference direction to the north, clockwise direction of rotation
   (compass directions).
-Behavior
+b. Behavior
 - For symbols of Type HATCH, this is the angle of the hatched lines.
 - For points, this specifies the rotation of a symbol around its defined
   CENTER.
@@ -101,24 +105,30 @@
   defining symbol. For its use with hatched lines, see Example#8 in the SYMBOL
   examples.
-Stable rendering for tile generation
+1.2.4. Stable rendering for tile generation
 *how and with what keywords?*
-polygon fill symbols
+.. _5:
+a. polygon fill symbols
 give hatches and vector fills a stable geographical coordinate origin (0,0) to
 better support tiling and continuous rendering of neighbouring polygons
-labelling
+.. _6:
+b. labelling
 TODO
-Keywords moved from SYMBOL to STYLE
+1.3. Keywords moved from SYMBOL to STYLE
-FIXME GAP [double]+ END
+.. _7:
+1.3.1. FIXME GAP [double]+ END
 Gap between point symbols when rendered on a linear geometry (used eg. for
 shields)
@@ -141,26 +151,36 @@
   the line. When placing the symbol on the line, the symbol is oriented in such
   a way that the symbol's x-axis is directed along the line.
+.. _8:
-DASHPATTERN ([double on] [double off])+ END
+1.3.2. DASHPATTERN ([double on] [double off])+ END
 - renamed from STYLE
 - the distances are scaled
-more to come?
+1.3.3. more to come?
-New Functionnality
+2. New Functionnality
-add MINSCALEDENOM/MAXSCALEDENOM parameters to styleObj
+.. _14:
+2.1. add attribute binding for WIDTH in styleObj
+.. _9:
+2.2. add MINSCALEDENOM/MAXSCALEDENOM parameters to styleObj
 this would allow doing things like removing outlines or the hollow portions of
 "tube" line work based on scale.
-add LABELMETHOD to layerObj
+.. _10:
+2.3. add LABELMETHOD to layerObj
 (or perhaps just method to labelObj?)
 - this would allow users to choose label placement algorithms that meet their
@@ -170,13 +190,17 @@
 - The default would be the improved placement in D2.
-add LABEL to layersObj
+.. _11:
+2.4. add LABEL to layersObj
 so that a default can be defined for all classes (sort of like templates). A
 class label would take precedent.
-add OUTLINEWIDTH to styleObj
+.. _12:
+2.5. add OUTLINEWIDTH to styleObj for line types
 eg for drawing road lines with a cached outline
 - It is currently impossible to have scale dependant road networks with a fixed
@@ -185,9 +209,10 @@
 - This would also be a shorthand to be able to specify an outline for linear
   networks, without having to specify two style blocks.
+.. _2.6:
-add TYPE to styleObj for line and polygon types
+2.6. add TYPE to styleObj for line and polygon types
 modifies how the current shape is interpreted. Applies to line and polygon
 layers (for now: any ideas for applying this to point layers?)
@@ -205,21 +230,21 @@
   - default angle is direction of first/last segment
-Files Affected
+3. Files Affected
-* maplexer.l: C4, C5
-* mapgd.c: B1, C2, C3, C4
-* mapagg.cpp: B1, C2, C3, C4
-* mapfile.c: B1, C1, C2, C3, C4, C5, C6, D1
-* mapdraw.c: C1, C5, C6, D1
+* maplexer.l: 2.6_, 10_
+* mapgd.c: B1, C2, C3, C4, 1_, 2_?, 3_ 7_, 8_, 5_, 4_?
+* mapagg.cpp: B1, C2, C3, C4, 1_, 2_, 3_, 7_, 8_, 5_, 4_
+* mapfile.c: 2.6_, 12_, 11_, 10_, 9_, 6_, 5_, 4_, 3_, 2_, 1_
+* mapdraw.c: 2.6_, 12_, 11_, 10_, 9_, 4_ C1, C5, C6, D1
 * mapprimitive.c: C5, D2
-Bug IDs
+4. Bug IDs
 Individual modifications will be tracked with their own tickets which will
 be listed here.
- - B1: http://trac.osgeo.org/mapserver/ticket/2766
+ - 2_: http://trac.osgeo.org/mapserver/ticket/2766
