[mapserver-commits] r7984 - trunk/mapserver/rfc
svn at osgeo.org
svn at osgeo.org
Fri Oct 17 12:09:54 EDT 2008
Author: pramsey
Date: 2008-10-17 12:09:54 -0400 (Fri, 17 Oct 2008)
New Revision: 7984
trunk/mapserver/rfc/ms-rfc-47.txt
Updates reflecting mailing list comments. (#2785)
Modified: trunk/mapserver/rfc/ms-rfc-47.txt
--- trunk/mapserver/rfc/ms-rfc-47.txt 2008-10-15 17:37:13 UTC (rev 7983)
+++ trunk/mapserver/rfc/ms-rfc-47.txt 2008-10-17 16:09:54 UTC (rev 7984)
@@ -30,6 +30,8 @@
A map-level configuration option will be added, CONFIG "ON_MISSING_DATA" "[ACTION]", with the following valid actions: "IGNORE", "LOG", "FAIL". The default map-level behavior will be "FAIL", unless Mapserver is compiled with --ignore-missing-data, in which case it will be "LOG". This will preserve the current behavior for all legacy mapfiles and compile set-ups.
+In the case of "LOG" behavior, the logging will only occur if the mapfile is set up for logging: DEBUG is set and MS_ERRORFILE is set. Documentation must note that DEBUG and MS_ERRORFILE need to be set.
At the same time, this ticket (#2722) can probably be tracked down and resolved.
Mapscript Implications
More information about the mapserver-commits
