[mapserver-commits] r7990 - branches/branch-5-2/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Oct 22 13:46:57 EDT 2008
Author: pramsey
Date: 2008-10-22 13:46:56 -0400 (Wed, 22 Oct 2008)
New Revision: 7990
branches/branch-5-2/mapserver/HISTORY.TXT
branches/branch-5-2/mapserver/maprasterquery.c
raster query fix for tileindex with relative paths (#2722)
Modified: branches/branch-5-2/mapserver/HISTORY.TXT
--- branches/branch-5-2/mapserver/HISTORY.TXT 2008-10-20 17:27:55 UTC (rev 7989)
+++ branches/branch-5-2/mapserver/HISTORY.TXT 2008-10-22 17:46:56 UTC (rev 7990)
@@ -13,6 +13,8 @@
Current Version (SVN branch-5-2)
+- raster query fix for tileindex with relative paths (#2722)
- Fix for the access violation caused by msMSSQL2008LayerGetShape (#2795)
- Fixed msMSSQL2008LayerGetItems to retrieve the column names properly (#2791)
Modified: branches/branch-5-2/mapserver/maprasterquery.c
--- branches/branch-5-2/mapserver/maprasterquery.c 2008-10-20 17:27:55 UTC (rev 7989)
+++ branches/branch-5-2/mapserver/maprasterquery.c 2008-10-22 17:46:56 UTC (rev 7990)
@@ -667,6 +667,8 @@
char szPath[MS_MAXPATHLEN];
rectObj searchrect;
rasterLayerInfo *rlinfo = NULL;
+ char tiAbsFilePath[MS_MAXPATHLEN];
+ char *tiAbsDirPath = NULL;
/* Get the layer info. */
@@ -771,10 +773,20 @@
msGDALInitialize();
+ ** If using a tileindex then build the path relative to that file if SHAPEPATH is not set.
+ if(layer->tileindex && !map->shapepath) {
+ msBuildPath(tiAbsFilePath, map->mappath, layer->tileindex); /* absolute path to tileindex file */
+ tiAbsDirPath = msGetPath(tiAbsFilePath); /* tileindex file's directory */
+ msBuildPath(szPath, tiAbsDirPath, filename);
+ free(tiAbsDirPath);
+ } else {
+ msBuildPath3(szPath, map->mappath, map->shapepath, filename);
msAcquireLock( TLOCK_GDAL );
- hDS = GDALOpen(
- msBuildPath3( szPath, map->mappath, map->shapepath, filename ),
- GA_ReadOnly );
+ hDS = GDALOpen(szPath, GA_ReadOnly );
if( hDS == NULL )
More information about the mapserver-commits
