[mapserver-commits] r7897 - trunk/mapserver/mapscript/php3
svn at osgeo.org
svn at osgeo.org
Thu Sep 4 13:22:23 EDT 2008
Author: Assefa
Date: 2008-09-04 13:22:22 -0400 (Thu, 04 Sep 2008)
New Revision: 7897
trunk/mapserver/mapscript/php3/README
trunk/mapserver/mapscript/php3/mapscript_i.c
trunk/mapserver/mapscript/php3/php_mapscript.c
trunk/mapserver/mapscript/php3/php_mapscript.h
add metadata functions on the class object #2579
Modified: trunk/mapserver/mapscript/php3/README
--- trunk/mapserver/mapscript/php3/README 2008-09-04 03:31:29 UTC (rev 7896)
+++ trunk/mapserver/mapscript/php3/README 2008-09-04 17:22:22 UTC (rev 7897)
@@ -995,6 +995,16 @@
echo $class->numstyles; : will echo 1
+ int getMetaData(string name)
+ Fetch class metadata entry by name. Returns "" if no entry
+ matches the name. Note that the search is case sensitive.
+ int setMetaData(string name, string value)
+ Set a metadata entry for the class. Returns MS_SUCCESS/MS_FAILURE.
+ int removeMetaData(string name)
+ Remove a metadata entry for the class. Returns MS_SUCCESS/MS_FAILURE.
ImageObj Class:
Modified: trunk/mapserver/mapscript/php3/mapscript_i.c
--- trunk/mapserver/mapscript/php3/mapscript_i.c 2008-09-04 03:31:29 UTC (rev 7896)
+++ trunk/mapserver/mapscript/php3/mapscript_i.c 2008-09-04 17:22:22 UTC (rev 7897)
@@ -697,6 +697,21 @@
return msDeleteStyle(self, index);
+char *classObj_getMetaData(classObj *self, char *name) {
+ return(msLookupHashTable(&(self->metadata), name));
+int classObj_setMetaData(classObj *self, char *name, char *value) {
+ if (msInsertHashTable(&(self->metadata), name, value) == NULL)
+ return MS_FAILURE;
+ return MS_SUCCESS;
+int classObj_removeMetaData(classObj *self, char *name) {
+ return(msRemoveHashTable(&(self->metadata), name));
* class extensions for pointObj, useful many places
Modified: trunk/mapserver/mapscript/php3/php_mapscript.c
--- trunk/mapserver/mapscript/php3/php_mapscript.c 2008-09-04 03:31:29 UTC (rev 7896)
+++ trunk/mapserver/mapscript/php3/php_mapscript.c 2008-09-04 17:22:22 UTC (rev 7897)
@@ -233,6 +233,10 @@
DLEXPORT void php3_ms_class_moveStyleDown(INTERNAL_FUNCTION_PARAMETERS);
DLEXPORT void php3_ms_class_deleteStyle(INTERNAL_FUNCTION_PARAMETERS);
+DLEXPORT void php3_ms_class_getMetaData(INTERNAL_FUNCTION_PARAMETERS);
+DLEXPORT void php3_ms_class_setMetaData(INTERNAL_FUNCTION_PARAMETERS);
+DLEXPORT void php3_ms_class_removeMetaData(INTERNAL_FUNCTION_PARAMETERS);
DLEXPORT void php3_ms_label_setProperty(INTERNAL_FUNCTION_PARAMETERS);
DLEXPORT void php3_ms_label_setBinding(INTERNAL_FUNCTION_PARAMETERS);
DLEXPORT void php3_ms_label_removeBinding(INTERNAL_FUNCTION_PARAMETERS);
@@ -815,6 +819,9 @@
{"movestyleup", php3_ms_class_moveStyleUp, NULL},
{"movestyledown", php3_ms_class_moveStyleDown, NULL},
{"deletestyle", php3_ms_class_deleteStyle, NULL},
+ {"getmetadata", php3_ms_class_getMetaData, NULL},
+ {"setmetadata", php3_ms_class_setMetaData, NULL},
+ {"removemetadata", php3_ms_class_removeMetaData, NULL},
{NULL, NULL, NULL}
@@ -9564,9 +9571,136 @@
+ * class->getMetaData()
+/* {{{ proto string class.getMetaData(string name)
+ Return MetaData entry by name, or empty string if not found. */
+ classObj *self;
+ pval *pThis, *pName;
+ char *pszValue = NULL;
+#ifdef PHP4
+ HashTable *list=NULL;
+#endif
+#ifdef PHP4
+ pThis = getThis();
+#else
+ getThis(&pThis);
+#endif
+ if (pThis == NULL ||
+ getParameters(ht, 1, &pName) != SUCCESS)
+ WRONG_PARAM_COUNT;
+ convert_to_string(pName);
+ self = (classObj *)_phpms_fetch_handle(pThis, PHPMS_GLOBAL(le_msclass),
+ list TSRMLS_CC);
+ if (self == NULL ||
+ (pszValue = classObj_getMetaData(self, pName->value.str.val)) == NULL)
+ pszValue = "";
+ RETURN_STRING(pszValue, 1);
+ * class->setMetaData()
+/* {{{ proto int class.setMetaData(string name, string value)
+ Set MetaData entry by name. Returns MS_SUCCESS/MS_FAILURE */
+ classObj *self;
+ pval *pThis, *pName, *pValue;
+ int nStatus = MS_FAILURE;
+#ifdef PHP4
+#endif
+#ifdef PHP4
+#else
+ getThis(&pThis);
+#endif
+ getParameters(ht, 2, &pName, &pValue) != SUCCESS)
+ convert_to_string(pValue);
+ list TSRMLS_CC);
+ (nStatus = classObj_setMetaData(self,
+ pName->value.str.val,
+ pValue->value.str.val)) != MS_SUCCESS)
+ _phpms_report_mapserver_error(E_ERROR);
+ RETURN_LONG(nStatus);
+ * class->removeMetaData()
+/* {{{ proto int class.removeMetaData(string name)
+ Remove MetaData entry by name. Returns MS_SUCCESS/MS_FAILURE */
+ classObj *self;
+ list TSRMLS_CC);
+ (nStatus = classObj_removeMetaData(self,
+ pName->value.str.val)) != MS_SUCCESS)
* PHP function wrappers - colorObj class
Modified: trunk/mapserver/mapscript/php3/php_mapscript.h
--- trunk/mapserver/mapscript/php3/php_mapscript.h 2008-09-04 03:31:29 UTC (rev 7896)
+++ trunk/mapserver/mapscript/php3/php_mapscript.h 2008-09-04 17:22:22 UTC (rev 7897)
@@ -200,6 +200,9 @@
int classObj_moveStyleUp(classObj *self, int index);
int classObj_moveStyleDown(classObj *self, int index);
int classObj_deleteStyle(classObj *self, int index);
+char *classObj_getMetaData(classObj *self, char *name);
+int classObj_setMetaData(classObj *self, char *name, char *value);
+int classObj_removeMetaData(classObj *self, char *name);
pointObj *pointObj_new();
void pointObj_destroy(pointObj *self);
More information about the mapserver-commits
